Human Clutched April 23, 2012 Share April 23, 2012 u mean dash board can be sprayed ? ↡ Advertisement Link to post Share on other sites More sharing options...
GoofRider Neutral Newbie April 23, 2012 Share April 23, 2012 u mean dash board can be sprayed ? yup.. if you have the $$ ka-ching!! Link to post Share on other sites More sharing options...
SGXora Clutched April 23, 2012 Share April 23, 2012 will need to drop by too to do balancing. slight steering wobble at 120km --realised it on way back from melaka yesterday. An interesting thing happen to my exora in melaka... radiator fan blades(black color) de-attached from the motor assy. luckily only a 10mm nut/washer in the centre holding it- Came off. ---had it replaced & everything fine. suspect factory didnt tighten it properly.. You bros, better just do a manual check on yours to check if fan blade is wobbling or loose. (there are 2 fans behind the radiator- the bigger one on the rh side when standing infront of the car looking -the smaller one on the lh side is the a/con fan-check it too!). NOTE! Do not do this when engine is running or ignition s/w turned on. Very Dangerous-- can get fingers cutted off! thank for the info, bro steering wobble = all the while i thought it's normal when speed reach 120KM, i have this encounter everytime the speed reach 120KM but it will back to steady once hit above 125-130KM Link to post Share on other sites More sharing options...
Noirmubin Clutched April 23, 2012 Share April 23, 2012 (edited) will need to drop by too to do balancing. slight steering wobble at 120km --realised it on way back from melaka yesterday. An interesting thing happen to my exora in melaka... radiator fan blades(black color) de-attached from the motor assy. luckily only a 10mm nut/washer in the centre holding it- Came off. ---had it replaced & everything fine. suspect factory didnt tighten it properly.. You bros, better just do a manual check on yours to check if fan blade is wobbling or loose. (there are 2 fans behind the radiator- the bigger one on the rh side when standing infront of the car looking -the smaller one on the lh side is the a/con fan-check it too!). NOTE! Do not do this when engine is running or ignition s/w turned on. Very Dangerous-- can get fingers cutted off! Thanks for the advice. Are you going to the UBI tyre shop to do balancing? Edited April 23, 2012 by Noirmubin Link to post Share on other sites More sharing options...
Shorty Turbocharged April 23, 2012 Share April 23, 2012 i'm planning to do EO change n wheel aligntment next mth. anyone else doing any of the 2? i tot of going to a shop in jb. Link to post Share on other sites More sharing options...
SGXora Clutched April 24, 2012 Share April 24, 2012 i'm planning to do EO change n wheel aligntment next mth. anyone else doing any of the 2? i tot of going to a shop in jb. what is EO?? Link to post Share on other sites More sharing options...
Shorty Turbocharged April 24, 2012 Share April 24, 2012 what is EO?? alamak...engine oil la. hehe. Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 24, 2012 Share April 24, 2012 alamak...engine oil la. hehe. no lar............its Engine Overhaul Link to post Share on other sites More sharing options...
Panhard 1st Gear April 25, 2012 Share April 25, 2012 Thanks for the advice. Are you going to the UBI tyre shop to do balancing? will try find some time this weekend to do it. Link to post Share on other sites More sharing options...
Noirmubin Clutched April 25, 2012 Share April 25, 2012 what is EO?? which shop, bro? Link to post Share on other sites More sharing options...
Sham0192 Neutral Newbie April 26, 2012 Share April 26, 2012 Hi bros, I'm in a process of quiring an OPC Exora with a dealer...if it fit the bill i will grab it....but i think the mthly installment won't be cheap as my normal plate Matrix since the recent increas of COE...this agent had 2 units..one is SKA & SJZ plate.... Link to post Share on other sites More sharing options...
Nasiroo25 Neutral Newbie April 26, 2012 Share April 26, 2012 Smart choice Link to post Share on other sites More sharing options...
Noirmubin Clutched April 27, 2012 Share April 27, 2012 Hi bros, I'm in a process of quiring an OPC Exora with a dealer...if it fit the bill i will grab it....but i think the mthly installment won't be cheap as my normal plate Matrix since the recent increas of COE...this agent had 2 units..one is SKA & SJZ plate.... Cool Bro..welcome to the club! Just wondering the new Exora Bold is coming soon...maybe you ccan consider that too? Link to post Share on other sites More sharing options...
Sham0192 Neutral Newbie April 27, 2012 Share April 27, 2012 Cool Bro..welcome to the club! Just wondering the new Exora Bold is coming soon...maybe you ccan consider that too? I'm contemplating now...cos I believe Bold will be available around May/ June? But with COE is sky high now....I believe Bold will be tag at 100k?...I guess Bold is otw to our shore. http://paultan.org/2011/12/15/proton-exora...ter-on-the-nse/ Link to post Share on other sites More sharing options...
GoofRider Neutral Newbie April 27, 2012 Share April 27, 2012 Cool Bro..welcome to the club! Just wondering the new Exora Bold is coming soon...maybe you ccan consider that too? i think for our local dealer, they would onyl take in the second or third batch of Bold model, to avoid any discrepency of the engines or problems. so won't be so soon.. maybe in June or July.. Link to post Share on other sites More sharing options...
Sham0192 Neutral Newbie April 27, 2012 Share April 27, 2012 I had the detail for both ride the SKA plate is $79800 with omv $14128 while the SJZ plate is 74800 with omv $14127. I'd roughly calculated based on 1.88% interest rate...my mthly will be around 830 - 860 for an opc car? Link to post Share on other sites More sharing options...
Iz_Exora Clutched April 27, 2012 Share April 27, 2012 Bro, I am a newbie here. Just acquire an Exora early April. SJT (OPC) plate. Link to post Share on other sites More sharing options...
Shorty Turbocharged April 27, 2012 Share April 27, 2012 I had the detail for both ride the SKA plate is $79800 with omv $14128 while the SJZ plate is 74800 with omv $14127. I'd roughly calculated based on 1.88% interest rate...my mthly will be around 830 - 860 for an opc car? wat a rip off. dunno how much they inflate the price. i think sjz was sold at ard 60+k. cos the SJW ones were sold at 60k. now after 2 yrs...still can sell at 74k. ↡ Advertisement Link to post Share on other sites More sharing options...
Vincar to distribute Proton’s first electric vehicle in Singapore
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Proton X50
Proton X50
Proton eMas 5 previewed – rebadged Geome Xingyuan, RWD, 250 to 325 km WLTP
Proton overseas
Proton overseas
New Proton Perdona.
New Proton Perdona.
Proton To Introduce smart Electric Vehicles In Malaysia
