Computer Experts Needed! - Convert NTFS to FAT32
Forummer
Hi Computer Experts,
I need your help! Bought a HDD which is in NTFS format. Though NTFS is a better format, my device that I bought cannot suuport NTFS rather FAT32.
Does anyone here know how to convert my NTFS HDD to FAT32?
If its empty its relatively easy right? just reformat using Fat32 file system instead..
It's empty and I tried by right clicking the drive and formatting. There is no option for me to choose FAT32. There is only NTFS. Quite frustrating...
use partition magic. Create a new partition. Format it fat32. Then copy all files including system boot file into new fat32 partition. After tat remove the ntfs partition and promote fat32 to c drive. restart pc with your xp cd to repair tat c drive. Should be able to work.
computer expert ya??? haha, once it's at ntfs u cant juz format it to FAT32... the other way from FAT32 to ntfs u can juz format...
partition it and leave a small partition which going to be unused which is still in ntfs, dan the bigger part can be formatted in FAT32...
otherwise, go find a program to do it for u...
Took this off, lazy to type.
If your hard drive is formatted in NTFS and you need to reformat the drive to use either FAT or FAT32 all you need to do is insert your Windows XP CD into your CD-ROM, reboot your system and follow the instructions below:
After restarting your PC the Windows Setup will begin
At the Welcome to Setup screen press F10
Pressing F10 opens the Recovery Console. This is a DOS based screen so you need to first specify the operating system location, i.e. C: Drive and then log in as using your Administrator Password.
After logging in type map and then press Enter
Highlight the drive you want to reformat. Drive letters may differ in recovery console to those in windows xp
Type format x: /fs:fat32 Substitute the
Windows Fat32 have limitation. Can't remember the max size. But it is very small like 30gb or something. Google "Fat32Format" and you will find many programs that allow fat32 format of up to TBs.
Hypersonic
If you're under XP. Right Click on 'My Computer' - >'Manage' -> 'Storage'->'Disk Management(Local)'.
You should arrived in a menu to allow you to delete logical drive and partition. And then repartition it to your desired format. Only thing here is select your drive carefully, don't select your OS drive accidently..
FAT32 can only read/write 4.2gb per file.
So even if the filesize is more than 4.2gb from a NTFS hdd, it will not continue to process the file beyond that.
I recommend you stay with NTFS.
and yes the max volume up to 32gb only... unless u are still with win98 or 95, i strongly recommend to stay with ntfs
chill.. never said im one, remembered thats what i did for my hdd that came in fat32
Fat32 can't read/write any file larger than 4Gb.
Edited by Darth_mel
1st partition your HD by running diskmgmt.msc
take note of the drive letter assigned
then go to command prompt, type format X: /fs:fat32 where X is the drive letter
type format/? if you need help
hope this help
Hypersonic
You should be replying to the TS instead.
Anyway, please read TS situation before recommending to stay in NTFS..
oh ok... tat's bcos ur hdd is new and need to formatted once b4 u can use it... so u can still format it to FAT32... but if format ur new hdd to NTFS dan u cant juz format it back to FAT32 juz like tat only...
nowadays hdd some come unformatted but some came wif NTFS formatted already...
Frankly, I am not very clear about the relationship between the three.
However, I got something useful information about NTFS and FAT32.
Perhaps you will be interested it. [:)]
