'clock clock/tok tok' sound
Andrewchia
Drive shaft problems very simple:
a) When U-turn or turning got tok tok sound from front shaft, the outer CV joint, (wheel side) is worned out.
b) When going straight also got tok tok sound, the inner joint at (gearbox side) is worn out.
Go to drive shaft workshop, they will solve for you. less than $200 for re-con shaft. Check out Elite workshop at Sin Ming. Can't remember their address. Many years didn't go there.
roger tt..tks bro...tks
here is the contact for Elite
http://www.elitedriveshaft.com/contactUs.htm
They do install re-con drive shaft at their workshop. I prefer to go there as they are one of the few that supply re-con drive shaft to most workshop, so if you go outside workshop, they'll still be getting from them (or the other few). might as well go straight to the supplier to install, any problem just go back to them.
p.s. I do not work for Elite.
hi bros, i need help here. I'm driving a swift 1.5A. When i'm moving off(2k+RPM) a clock clock sound comes from near e front right wheel, but no sound if i acelerate less..slow pick up.. Ani1 kena tis prob b4 or noe wat's wrong..tks tks
Could be wheel bearing.
Thanks. This is the power of MCF
this is what MCF is for, to provide info and help car owners.
Proberly undercarriage lower arm Bush or drive shaft get check and seek opnion by at least 2 Mechnic then shoul get a better picture.
latest update: went wksp chk..chg susp mounting as both worn out..but still hv e sound. Finally discover it's e engine mounting worn out. But no stock..need 2 go bk next wk...
hi bros here,
wanna check with you guys here, i came back from malaysia driving 70km/hr toward the MY custom then I saw a hump "too black cannot see"then i didnt apply brake cos too late already so i chiong.. then later the car produce sound when i accelerate gear1-2 . could it be belt? engine? or suspension?
