Hensony Clutched October 20, 2009 Share October 20, 2009 Hi, I'm thinking of getting a cheap and hopefully good bluetooth headset. As I will use it only while driving, the headset will be kept in the car most of the time, which is why I'm not willing to spend so much for it. Appreciate if you can advise which one to get. I went around shopping last evening. Too many to choose from. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Bystander50 5th Gear October 20, 2009 Share October 20, 2009 (edited) Hi, I'm thinking of getting a cheap and hopefully good bluetooth headset. As I will use it only while driving, the headset will be kept in the car most of the time, which is why I'm not willing to spend so much for it. Appreciate if you can advise which one to get. I went around shopping last evening. Too many to choose from. Thanks I'm using a KDK one, $39.90. Downside is standby 10 hrs, 3-4 hrs continuous usage. Charge by USB only. It can pair 2 devices (handphone and pc), but not 2 hps. Edited October 20, 2009 by Bystander50 Link to post Share on other sites More sharing options...
Unltd 5th Gear October 20, 2009 Share October 20, 2009 Hi, I'm thinking of getting a cheap and hopefully good bluetooth headset. As I will use it only while driving, the headset will be kept in the car most of the time, which is why I'm not willing to spend so much for it. Appreciate if you can advise which one to get. I went around shopping last evening. Too many to choose from. Thanks Go challenger to buy, alot of cheap headset. If used in car with windows closed then almost everything is the same. Link to post Share on other sites More sharing options...
Hensony Clutched October 20, 2009 Author Share October 20, 2009 I'm using a KDK one, $39.90. Downside is standby 10 hrs, 3-4 hrs continuous usage. Charge by USB only. It can pair 2 devices (handphone and pc), but not 2 hps. KDK? The fan maker? Didn't know they also make bluetooth headset. ↡ Advertisement Link to post Share on other sites More sharing options...
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Any good private driving instructor to recommend?
Pls recommend good urologist
Recommend me a hotel in Hangzhou
