Tire pressure monitoring system (TPMS)
Achtung
28 minutes ago, Dreamer_toons said:
I'm into my 2nd sets of TPMS within the last 1 year due to air leaking from 1 of the tires. Similar to my previous set, the air leaked was gradual. Last Saturday, I just top that tire to 30 PSI and the car was not moved on Sunday. The PSI dropped to 15 on the Monday morning. No nail was found and I even replaced the valve. The tire and valve are completely ruled out coz the 2nd set was used on my previous ride and I carried over to my new ride couples of weeks ago.
I read this thread and someone rang the bell about over tightened the sensor and might lead to air leakage. Anyway, the 2 sets cost about $20+.
Any recommendation for better ones? I saw the Xiaomi brand but it is shipping from overseas, any local seller?
xiaomi shops in malls got sell also
It works the same just that maybe quality better and may last longer, but then all this may depends on luck also. I'm happy with my $20 plus one, just change anytime if faulty. $20plus one got more variety, eg windscreen mount etc.
6 minutes ago, Dreamer_toons said:
Thanks.
Anyone using this Xiaomi TPMS? Any difference from the $20++ ones?
Only added Bluetooth connection to phone apps. All the rest are sama sama. Even looks the same!
The good thing about Steelmate is that sensor can be replaced.
29 minutes ago, Dreamer_toons said:
Just saw that the Xiaomi ones is internal sensor.
They have both versions. Should be buying an external sensor set this week.
I saw the Xiaomi featuring on Lazada and Shopee having the internal sensor.
Can share where you see the internal sensor ones?
in case if you are intending to use the external TPMS,
at the wheel cap, do take note of the little O ring.
once damaged or misplaced, the leaking/reading will be inaccurate and very disturbing.
Carousell
u mean on the TPMS cap itself? not all will have the O ring.
Can advise which models (other than internal sensors) do not have the O rings?
The O rings are damaged due to over tightening in both sets in my case.
I had over tightened for my 1st set leading to air leaks. I thought it was malfunctioning and checked back with the seller. Then I learnt the O ring was damaged due to over tightening. Purchased the 2nd set and this time round, I was very mindful while screwing in the caps after top up. Last week, air starts to leak from 1 of the tires again. This 2nd set is only about 3 months old. So looking for replacement now.
i gave up eventually..
a quick solution is cutting rubberband and insert into the cap...
You can consider buying back the exact same model, and just use one sensor from the new set by reprogramming the receiver (usually by deflating and then inflating that particular tyre for internal type, not sure procedure for the screwed in type.) Then you have 3 more spare sensors!
  • Haha! 1
I thought of the same too.... but the usual rubber band seems kind of thick. Or maybe I can simply stuff it in.
20 minutes ago, mersaylee said:
What O ring are you guys referring to? Any picture? Not the washer that needs a spanner to lock or unlock right?
It’s not the washer.
If you invert the sensor cap, there is a O shape rubber that sits inside the groove. When you screw the cap onto the valve, I think this O ring will make contact with the edge of the valve and prevent air from escaping. When this ring is missing (mine was struck inside the valve previously) or damaged, air will escape gradually and the display will sound an alarm of low air pressure in that tire.
  • Praise 3
What about using a used bicycle inner tube to cut out?
