Ladykillerz 4th Gear January 29, 2010 Share January 29, 2010 Finally found a shop that has stock for RS-02 and finally swapped my Assymetric. Anyone here using Assymetric? I am just doing a survey to see if there is any issue with this tyre. My Assymetric clocked 21000 km and the inner tyre surface block became uneven, hence need to change. I have a friend with same Assymetric having a cracked side wall visible only from the inside and with same mileage as mine. Eyeing on that for my next change actually. However, I was also told by my mechanic that some customers had complained that there will be crack on side wall. Do you happen to change at the same shop? Serangoon? :p ↡ Advertisement Link to post Share on other sites More sharing options...
Grix17 Clutched February 4, 2010 Share February 4, 2010 What is the wear rating number for the F1 Assym? Thanks According to Tirerack, it is 240. Link to post Share on other sites More sharing options...
Ar1472007 Neutral Newbie February 7, 2010 Share February 7, 2010 Hi all, Just came across the GY F1 Assy tyre crack issue and I am very upset indeed becoz I have just changed to a brand new set. As I travel long distance up north frequently and at high speed, I am very concern and has been having sleepless nite. I am running on 225/45/R17, made in german and dated 43/09. Kindly update me if any bro/sis who has experience the crack on their tyre. Many thanks! Link to post Share on other sites More sharing options...
Sky61 1st Gear February 7, 2010 Share February 7, 2010 hi,i have been on 2sets on F1 assy for my front and one set for my rears, so far no issues wif sidewall cracking and i do corner quite a bit. only grip wif it is the way my first set front wears out (25000km) and some high speed balancing issues(light vibrations at above 100km/h) from time to time that i suffer wif F1 assy and not the previous F1 GSD3. nothing a onwheel balancing couldnt solve... i would say its a value for money set of tyres compared to PS2 n RE11. Link to post Share on other sites More sharing options...
Tonicwater Neutral Newbie February 7, 2010 Share February 7, 2010 Now on my second set of MIG F1 Assy. First set done approx 45-47k. Noise level ok. A bit noisy just before change. Now second set still new. So far so good. Looking forward to using this set for another 40k. Link to post Share on other sites More sharing options...
Ar1472007 Neutral Newbie February 10, 2010 Share February 10, 2010 Hey all guys, Check this out......http://www.vagsg.com/forums/showthread.php?t=30222. Suggest get the tyres check for peace of mind and and most importantly safety. Drive safe and have a great day!! ↡ Advertisement Link to post Share on other sites More sharing options...
Tyres - Goodyear / Bridgestone.
[Post-Event] MCF Hang Out with Goodyear. 28 Sept
Michelin Primacy 4 vs Continental Premium Contact 6 vs Goodyear F1A5
Goodyear Eagle F1 Asymmetric 5
