Treadwear = km
Nom107
does ur tire last long as state on spec "Treadwear"
my ze912 Treadwear 360 used 30k ( now track left 3mm deep )
if i change to one tat the Treadwear is 200 mean can use may b up to 20k ???
or if higher 400 can use to 40-50k ???
Driving style has the biggest influence.
Hard breaking? Hard acceleration? Hard cornering?
Proper inflation? Anyway good to change after 5 years
as the rubber hardens.
The tires with silica has improved durability.
Important statement to note from Tirerack website - "Typically, comparing the Treadwear Grades of tire lines within a single brand is somewhat helpful, while attempting to compare the grades between different brands is not as helpful."
So I guess your guess is as good as mine on the thread wear of different brands.
No, the ones with the lowest treadwear numbers are more expensive.
s far s tires are concerned, which brand,or rather which tires gives the highest so far treadwear...............but must be ex i think
5 years ? by then the rubber already become as hard as wood liao. i change my tires every 1 to 1.5 years.
not really. Yokohama Advan Sport 180, Michellin PS2 220, Conti CSC3 280, BS RE050A 280, goodyear eagle F1 GS-D3 280.
data gather from tirerack from suvey result under Max Performance Summer. I am using each brand respective best max summer performance result that sell in Singapore.
If you see Ranking 1 is Conti Extreme Contact DW dunno got sell in SG or not is 340 thread wear!!!
base on the data Yoko and Goodyear happen to be the cheaper tyres selling in SG and Yoko is 180 thread count!!!!!!
U need to compare within the same brand, not across brands, as the rating is not the same across different manufacturer.
For some reason which I don't understand, European branded tyres which costs more, does not offer the same level of performance as compared to some of the Japanese brands which costs lesser.
Generally, European branded tyres tends to be more biased towards consistent grip throughout the lifetime rather than the ultimate grip. As far as I know, BS S03 was designed with that philosophy and hence many pple were disappointed with it as it deemed as less competent as compared to BS S02. Thereafter, newer tyres produced by BS has gone back to their original philosophy of having ultimate grip.
My experience with Yoko before really wear out fast!!! only lasted 15mths
another thing abt Jap tires very heavy!!!!!!!! can feel when u drive and shown on spec too from tirerack
Which one you used? AD07/8?
It is only BS that is heavier, the rest are better. And just feel at the sidewall construction and you'll know why some tyres are heavier than others.
dont 100% trust the numbers.(is not they are not honest)
use it as general reference only
lately just found out michelin pilot ps 3 treadwear 320 (220 for ps2)
what i understand is michelin has make this ps3 tyre more grip and also more lasting.
so this is R & D technology
Not really..mine turns 5yrs old in 4 months time and it is still ok..
