Furrynadz 5th Gear October 31, 2009 Share October 31, 2009 need some help fren's ice keeps blowing the fuse once the volume is turn up too much using 20amp fuse now, already blown 2... safe to upgrade to a higher amp fuse? what to go for? ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 31, 2009 Author Share October 31, 2009 additional info previously worked fine, recently upgraded speakers at front to higher powered ones... Link to post Share on other sites More sharing options...
Mits_jc 5th Gear October 31, 2009 Share October 31, 2009 you just answered yourself... additional info previously worked fine, recently upgraded speakers at front to higher powered ones... Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 31, 2009 Author Share October 31, 2009 what effect does that have? what to do ? use a higher fuse? what amp Link to post Share on other sites More sharing options...
Mits_jc 5th Gear October 31, 2009 Share October 31, 2009 higher current flow that produces higher heat that blows the fuse? higher amp fuse may help, but risk of catching fire is also possible. Link to post Share on other sites More sharing options...
Kb27 Supersonic October 31, 2009 Share October 31, 2009 Must see if the wire can take higher current before changing to bigger fuse. If not, wire will overheat and melt insulation, causing a fire hazard. Link to post Share on other sites More sharing options...
Opasa4 Neutral Newbie October 31, 2009 Share October 31, 2009 the original fuse is sized to protect the cable from catching fire. If a higher current rating fuse is used instead, yes it may not blow... but it may also allow the cable to overheat under consistent overloading and may also damage your amplifier. It is important that the sizing of cable and fuse matches the load requirement, in this case, the load is your amp/speaker. Hope this provides some insight. Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 1, 2009 Share November 1, 2009 It's best to determine max amp draw before putting in the replacement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 2, 2009 Author Share November 2, 2009 thanks asked him to go back to shop to check Link to post Share on other sites More sharing options...
Daniel76 Neutral Newbie January 9, 2010 Share January 9, 2010 yah,, fuse blow.. just replace it and will be up and good. btw ..my radio reception is very bad after my k.l trip just last month.. nothing wrong when i play my DVD/VCD/WMA/USB etc.. but when switch to radio mode got alot of interferance noise... Checked all my connection , nothing wrong .. so what is the proble? circuit board got burnt? where to retify this problem? Or any1 got lobang on single din DVD player ? Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 9, 2010 Share January 9, 2010 The interference may have come from leaking spark plug cables ( replace with new sets ) or +B battery terminal ( connect a suppressor ) ↡ Advertisement Link to post Share on other sites More sharing options...
Battery warranty , must we service with distributor?
My EV journey to the i4
Battery for Honda Vezel
