Icyfreakass 1st Gear April 23, 2010 Share April 23, 2010 During raining i seem to see spots on the windscreen during wiping. Not sure what are those spots. But when it dries up the spot is gone. Is it my windscreen or wiper problem? ↡ Advertisement Link to post Share on other sites More sharing options...
Panhard 1st Gear April 23, 2010 Share April 23, 2010 During raining i seem to see spots on the windscreen during wiping. Not sure what are those spots. But when it dries up the spot is gone. Is it my windscreen or wiper problem? I also experience this on my 2 month old car ! Link to post Share on other sites More sharing options...
Babyt 4th Gear April 23, 2010 Share April 23, 2010 i think is etched watermarks....they said use diluted vinegar solution can remove ... Link to post Share on other sites More sharing options...
Svtfocus Neutral Newbie April 23, 2010 Share April 23, 2010 I've used Jif on my side mirrors which had the stains, works well... don't know about windscreens though... Link to post Share on other sites More sharing options...
Melvinyuen 2nd Gear April 23, 2010 Share April 23, 2010 i think is etched watermarks....they said use diluted vinegar solution can remove ... will this solution affect the paintwork if it accidentally came in contact? I always have marks on my windscreen. weekly washing of the car also did not manage to get the lines off. Link to post Share on other sites More sharing options...
Khhome06 Neutral Newbie May 3, 2010 Share May 3, 2010 will this solution affect the paintwork if it accidentally came in contact? I always have marks on my windscreen. weekly washing of the car also did not manage to get the lines off. i use vinegar solution so far no problem Link to post Share on other sites More sharing options...
Jtb 6th Gear May 4, 2010 Share May 4, 2010 just fill water tank with distilled water, no soap. Link to post Share on other sites More sharing options...
Chiangauto Clutched May 12, 2010 Share May 12, 2010 Ways of removing Water Marks from glasses. 1. Claying 2. Vinegar wipe 3. Soft 99 Glass Compound 4. Autoglym Glass Polish 5. Meguiar's Dual Action Cleaner Polish (M83) Another vinegar trick to remove water spots. 1. Keep on wetting the glass with vinegar to keep it wet for 1/2 hour. 2. While it is wet, soak a 0000 steel wool with more vinegar and rub the problem area. Rinse with water and inspect. 0000 steel wool is extremely fine and available from Ace Hardware. Harmless if used as explained above. Definitely will not scratch. I know it sounds drastic. But it solved my water mark problem many years ago. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear June 7, 2010 Author Share June 7, 2010 Mmm. must soak in vinegar? I use vinegar to wipe. Its still there. Im not sure what marks also. Its like can see streaks of water in the glass after wiping. They fade away after awhile. Is this water marks? Link to post Share on other sites More sharing options...
Donut Supercharged December 2, 2010 Share December 2, 2010 i also got this waterspots on windscreen. makes my windscreen blur during raining.... Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear May 17, 2011 Author Share May 17, 2011 Any grooming shop that can remove this? Can any bro recommend, thanks~ Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 17, 2011 Share May 17, 2011 Try Rain-X,it can remove it easily. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear May 17, 2011 Author Share May 17, 2011 Hmm. Am looking for a shop to help me polish off the marks. Cos i tried to buff it off myself with nu glass and it dosent work. Maybe need those machine type polisher. And i remember an uncle from a grooming shop told me that it is products like rain-x that causes such water stains. Not sure how true. Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 17, 2011 Share May 17, 2011 Then go V-Cool of Jin Bukit Merah,yes the one that fit window films,they have this service. Link to post Share on other sites More sharing options...
Edwardthy 1st Gear May 17, 2011 Share May 17, 2011 aiya dun be paranoid la. these watermarks wont kill you. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear May 17, 2011 Author Share May 17, 2011 the whole windscreen is filled with it. Paranoid about what? I know it wont kill me but its becoming annoying. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear May 17, 2011 Author Share May 17, 2011 thanks, will check it out. Link to post Share on other sites More sharing options...
Maroon5 5th Gear May 17, 2011 Share May 17, 2011 i suspect it could be window tinting? mine started hvg same problems aft this current tint but so far too lazy to go back ask them check. ↡ Advertisement Link to post Share on other sites More sharing options...
Heavy and rain proof curtains/blinder recommendations?
Boy won hearts for sheltering bus passengers from rain
how to remove micro/fine scratches on windscreen
How to remove stubborn stain on windscreen?
