In car vehicle recorder
Tom_kkh
Ah...interesting point of view. Quite true.
The objective of installing the camera at the front is to defend yourself against the 50-50 case like side collision due to abrupt lane change or reckless driving. Rear end case usually is straight forward, don't need to defend yourself much.
The DC/cigarette light connector is designed for up to 15A.
So are the wires connected to it rated for slightly more than 15A.
Overloading will lead to heating of wires and subsequently plastic insulation may burn.
I've personally overloaded a pair of thin wires due to a short circuit.
Luckily it was outside and visible, with burnt smell.
Do be careful.
Dont worry, I will be using at least 18 AWG wires. Safety is my paramount concern. I may not have any single cert in electrical/electronics engineering but I still do have basic electrical knowledge. :D
http://www.rbeelectronics.com/wtable.htm
Second that. Also against reversing vehicle. [;)]
that's right. Guard against kuku drivers engaging reverse gear when the light turns green. Also vehicles on neutral gears not applying brakes and rolling backwards, etc.
All pm replied!
Last 5 promo units left.
Due to the overwhelming support for Itronics, the next shipment will be ready by 19th jun.
Cheers!
Any bro thinking of getting the new itronic but already got finevu 300.
I'm looking for a used finevu 300 in working condition & everything in the box.
PM me for the price u looking for.
Prefer a set from shochong.
Thanks. :D
Thanks. :D
Thanks for the support [;)]
Hi all,
Is there any accessory i can buy from autobacs that can be plugged into the cigarette socket to maintain the voltage whenever we crank our engine?
its for my Marbella GPS.
Seems like those Car Rearview Mirror with DVR not very popular in here.
Like these two:
http://www.ebay.com.sg/itm/Car-DVR-acciden...=item3cbe035b4e
http://www.ebay.com.sg/itm/3-5-LCD-Screen-...=item564aa45ffa
Is like 2 in 1 (rearview mirror + recorder) and nothing need to be stick to the windscreen.
Probably the recording might be poor but I saw the playback for HDVR-150 like not bad leh.
Like these two:
They dont have smart feature of auto surveillance, viewing angle & resolution are also not good enough[:(]
Hi all,
I dont think so. Have to DIY.
1) use a small saled lead acid battery
2) use some capacitors
How come most of us only care about recording on the move? Most install the camera facing front n that normally only show your fault when you rear-end someone.
Someone hitting us from the side or rear will not be captured, so really defeats the purpose.
I would also want the camera with motion sensor so it can record anyone or any car coming near in case of hit and run or vandalism.
Another perspective: hopefully when more drivers have these cams installed, it helps to keep our roads safer as other reckless drivers are aware that their actions maybe caught by other drivers. It may also help one another as the accident maybe capture on video by other drivers and you can use it as evident.
Pretty good comparison here between quality of BlackVue VS ITB100HD:
http://www.radardetectorforum.org/counterm...e-blackvue.html
Shochong, are there any RAW videos around of highest quality from each? Raw as in, not uploaded and processed via youtube? Are they better quality when watched direct from the card?
Yes, the video clips are better quality when viewed directly rather that via YouTube. At least it is for my Finevu 300
Guest
