Cerano 1st Gear June 25, 2010 Share June 25, 2010 Hey bros I thinking of replacing my stock intercooler for a more efficient/larger one. Do you think it will make much of a diff? ↡ Advertisement Link to post Share on other sites More sharing options...
Burnings Neutral Newbie June 26, 2010 Share June 26, 2010 Without supporting mods, it is not necessary to change intercooler.... :) Link to post Share on other sites More sharing options...
Mini-itx Clutched June 26, 2010 Share June 26, 2010 (edited) Yes, upgrading intercooler will usually result in a slight performance improvement, even if your car is stock. However, if yours is a top mount intercooler I suggest you also install a fan to prevent heat soak when car is not moving. It will improve your pickup as well. If front mount, you may want to consider turning on your fan all the time to ensure there is airflow over the intercooler. Of course this will reduce the lifespan of your fan. But then, electric fans are pretty cheap so I don't really care. You may also want to consider a water to air intercooler instead of air to air. Its much more efficient but more complicated as well. I am using a water to air intercooler right now. Edited June 26, 2010 by Mini-itx Link to post Share on other sites More sharing options...
Zangetsu77 Clutched June 26, 2010 Share June 26, 2010 Yes, there should be a difference. Go for it!! Fundamentally, you know you want it!! Link to post Share on other sites More sharing options...
BITURBO Neutral Newbie June 26, 2010 Share June 26, 2010 Stock IC are usually not well designed or not big enough...can try aftermarket IC if you are running FI engine... Link to post Share on other sites More sharing options...
Happily1986 5th Gear June 26, 2010 Share June 26, 2010 Hey bros I thinking of replacing my stock intercooler for a more efficient/larger one. Do you think it will make much of a diff? Technically it will make a difference. It improves performance by increasing the density of air entering combustion chamber. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear June 26, 2010 Share June 26, 2010 (edited) With all things remain the same, a Bigger intercooler will induce more lag, although the power may increase. Thats why I am still on stock. Unless upgrade to bigger turbo, its better to keep stock, in my opinion. Out of curiosity, what car are you driving? Edited June 26, 2010 by Kiadaw Link to post Share on other sites More sharing options...
Qr25vet Clutched June 27, 2010 Share June 27, 2010 too big a intercooler will cause a lag or a slight drop in pressure...think of it as opening up the hole on a jet washer...so be sure to choose a size which is just nice :) Link to post Share on other sites More sharing options...
Mini-itx Clutched June 27, 2010 Share June 27, 2010 With all things remain the same, a Bigger intercooler will induce more lag, although the power may increase. Thats why I am still on stock. Unless upgrade to bigger turbo, its better to keep stock, in my opinion. Out of curiosity, what car are you driving? Actually, getting a bigger intercooler doesn't exactly increase lag. Depending on the intercooler uses, it may actually improve response. This is because many intercoolers are actually more of a restriction causing pressure drop. If a better intercooler could reduce this pressure drop, then you will actually get better performance. Link to post Share on other sites More sharing options...
Watwheels Supersonic June 27, 2010 Share June 27, 2010 Hey bros I thinking of replacing my stock intercooler for a more efficient/larger one. Do you think it will make much of a diff? Leave it as it's, stock. Some interesting facts on air to air intercooler and water based intercooler. Link How can an air-to-air intercooler be more efficient than a water based intercooler? There is an overwhelming quantity of ambient air available to cool an air-to-air core relative to the charge air thru the inside of the intercooler (The iced down water intercooler is the only exception to this argument.). At just 60 mph, with a 300 bhp engine at full tilt, the ambient air available to cool the intercooler is about ten times the amount of charge air needed to make the 300 hp. Whereas the water intercooler largely stores the heat in the water until off throttle allows a reverse exchange. Some heat is expelled from a front water cooler, but the temperature difference between the water and ambient air is not large enough to drive out much heat. Another way to view the situation is that ultimately the heat removed from the air charge must go into the atmosphere regardless of whether it's from an air intercooler or a water based intercooler. The problem with the water intercooler is that the heat has more barriers to cross to reach the atmosphere than the air intercooler. Like it or not, each barrier represents a resistance to the transfer of heat. The net result; more barriers, less heat transfer. What are the relative merits of an air or water-cooled intercooler and which would suit my purposes best? This depends on the circumstances. These circumstances are; street use, drag racing, or endurance racing (more than two minutes). Street use: The air-to-air intercooler will prove superior in efficiency when sized properly. Drag racing: The short spurt of power allows the iced water to cool the charge air to below ambient temperature. Endurance racing: The air-to-air intercooler is clearly superior due to the shorter route of getting the heat out of the air charge and into the atmosphere. Endurance racing would preclude the use of ice water, thus negating the singular advantage of the water intercooler. Further, the air-to-air intercooler is (virtually, see comments below) maintenance free Link to post Share on other sites More sharing options...
Mini-itx Clutched June 27, 2010 Share June 27, 2010 Leave it as it's, stock. Some interesting facts on air to air intercooler and water based intercooler. Link How can an air-to-air intercooler be more efficient than a water based intercooler? There is an overwhelming quantity of ambient air available to cool an air-to-air core relative to the charge air thru the inside of the intercooler (The iced down water intercooler is the only exception to this argument.). At just 60 mph, with a 300 bhp engine at full tilt, the ambient air available to cool the intercooler is about ten times the amount of charge air needed to make the 300 hp. Whereas the water intercooler largely stores the heat in the water until off throttle allows a reverse exchange. Some heat is expelled from a front water cooler, but the temperature difference between the water and ambient air is not large enough to drive out much heat. Another way to view the situation is that ultimately the heat removed from the air charge must go into the atmosphere regardless of whether it's from an air intercooler or a water based intercooler. The problem with the water intercooler is that the heat has more barriers to cross to reach the atmosphere than the air intercooler. Like it or not, each barrier represents a resistance to the transfer of heat. The net result; more barriers, less heat transfer. What are the relative merits of an air or water-cooled intercooler and which would suit my purposes best? This depends on the circumstances. These circumstances are; street use, drag racing, or endurance racing (more than two minutes). Street use: The air-to-air intercooler will prove superior in efficiency when sized properly. Drag racing: The short spurt of power allows the iced water to cool the charge air to below ambient temperature. Endurance racing: The air-to-air intercooler is clearly superior due to the shorter route of getting the heat out of the air charge and into the atmosphere. Endurance racing would preclude the use of ice water, thus negating the singular advantage of the water intercooler. Further, the air-to-air intercooler is (virtually, see comments below) maintenance free Hmmm.... interesting read. But one main advantage of WTA intercooler is much shorter paths for air to travel, hence much lower turbo lag. Of course, a top mount ATA intercooler can achieve the same results. However, given the same size, a WTA one will be more efficient as water has much higher thermal conductivity and density compared to air. Of course, the ultimate cooling is provided by those front mount ATA ones as they are much larger. However, downside is lag. Link to post Share on other sites More sharing options...
Cerano 1st Gear June 27, 2010 Author Share June 27, 2010 im driving a supercharged c-class with quite alot of mods so im wondering if it'll help Link to post Share on other sites More sharing options...
Ithunk 1st Gear June 27, 2010 Share June 27, 2010 swap it man.....live for the day! lol ↡ Advertisement Link to post Share on other sites More sharing options...
Worth to be a Grab Driver now?
Pump Petrol In JB - Worth it
Is your car worth what it cost? [Shocking]
Is it worth to be an AAS member?
How much is 100 billion?
1.5A Vios may 2008 worth to renew COE?
Is your worth just based on that like?
10 years worth of photos...
