Waffenss Neutral Newbie July 28, 2010 Share July 28, 2010 just curious..whats the "pssst" sound that buses make when they are moving or stopping? been taking buses so long still dunnoe ↡ Advertisement Link to post Share on other sites More sharing options...
Subzro Neutral Newbie July 28, 2010 Share July 28, 2010 (edited) Pneumatics? If I'm not wrong, the doors, brakes are air-operated. But I'm not sure of the sound generated while on the move. EDIT: I think the sound while moving is the bypass valve opening due to sufficient air being compressed into the tanks to supply air into the necessary components. The parking brake will emit the sound when engaged too. Edited July 28, 2010 by Subzro Link to post Share on other sites More sharing options...
Cotrox Neutral Newbie July 28, 2010 Share July 28, 2010 BOV! Link to post Share on other sites More sharing options...
Prodrive7354 Neutral Newbie July 28, 2010 Share July 28, 2010 I think is the air operated brake system. Letting go the excess pressure. Link to post Share on other sites More sharing options...
Ysc3 Twincharged July 28, 2010 Share July 28, 2010 yup. its the brake system. same as those big lorries/trucks and also containers trailers also. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 29, 2010 Share July 29, 2010 Read that air brakes are pretty efficient for buses and heavy vehicles. Link to post Share on other sites More sharing options...
Best_ctzn Clutched July 29, 2010 Share July 29, 2010 just curious..whats the "pssst" sound that buses make when they are moving or stopping? been taking buses so long still dunnoe Is it heard on those newer buses? Those buses are designed with adjustable suspension. When on the move, the bus is raised higher. When stop, it will lower itself for passenger to alight, so called stepless. Very hi-tech. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear July 29, 2010 Share July 29, 2010 Turbo diesel...of course has the piss sound lah. Bus are powerful engine leh. Link to post Share on other sites More sharing options...
Mike1234 1st Gear July 29, 2010 Share July 29, 2010 There are quite many old buses around... But newer buses like the scanias, Mercs, etc.... Generally are much quieter ..... [laugh] Link to post Share on other sites More sharing options...
Virus 2nd Gear July 29, 2010 Share July 29, 2010 Should be the brake sound. If driver press/depress the brake during stopping, some gas will be release from brake cylinder. When during move off, it will pump air into brake cylinder which has a high pitch sound too. When air-cylinder full , the excess air will be release again and the pump will stop. Link to post Share on other sites More sharing options...
Saycheese78 Clutched July 29, 2010 Share July 29, 2010 Confirm brake sound. same sound on Fiat 3 tonner. Link to post Share on other sites More sharing options...
Robo 2nd Gear July 29, 2010 Share July 29, 2010 they are the airbrakes Link to post Share on other sites More sharing options...
Evo07 Neutral Newbie July 29, 2010 Share July 29, 2010 its the release of high pressure air from the compressor tank used for pnematic doors and their brakes. saf 3 & 5 tonner also same. Link to post Share on other sites More sharing options...
Yagami85 Neutral Newbie July 29, 2010 Share July 29, 2010 last time when i was a kid, my mother will tell me that wan is bus fang pi... so must fasted siam Link to post Share on other sites More sharing options...
Mockngbrd Supersonic July 29, 2010 Share July 29, 2010 Turbo la... ppssst ppssst.... i think got boost meter also Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear July 29, 2010 Share July 29, 2010 Its the air-operated braking system. Should be the same like those SAF 3-tonnes i've driven before in NS. Have to warm-up and let the air charge up first. Orelse if just start engine and go, you wont have any brake. The system needs to charge up continueously, everytime it chargers to a certain level, you will hear a pss sound. Hence u will hear the pan pui sound quite frequently. Link to post Share on other sites More sharing options...
Keira 4th Gear July 29, 2010 Share July 29, 2010 Air brake sound. The air release sound will came off after the driver release the brake pedal or pull up the handbrake. Link to post Share on other sites More sharing options...
Bankai87 Neutral Newbie July 29, 2010 Share July 29, 2010 (edited) Its the air-operated braking system. Should be the same like those SAF 3-tonnes i've driven before in NS. Have to warm-up and let the air charge up first. Orelse if just start engine and go, you wont have any brake. The system needs to charge up continueously, everytime it chargers to a certain level, you will hear a pss sound. Hence u will hear the pan pui sound quite frequently. not true. the air pressure is generatated to release the brake, i think some air brakes work like this no air, brakes is ON. u need the air pressure to release the brakes hence if somebody cut the air hose, the brakes will be permanently ON, and not like in the movies cut the air hose equal no braking is a safety feature. so if u just start e engine and try to move off u cant.... cuz air no air pressure to release the brake, u will be stuck Edited July 29, 2010 by Bankai87 ↡ Advertisement Link to post Share on other sites More sharing options...
LTA buys electric buses from China
Sound Proofing the car
Whole car sound proof
Public Buses of Yesterday
Porsche is now made in Malaysia!
Math Question
Math Question
Singapore Brand Rims VS China Brand Rims
