E-Jazz Neutral Newbie October 6, 2010 Share October 6, 2010 (edited) Hi bros/sis, Just wondering what you would recommend for tyre pressure given that the sticker on my door (as shown in image) indicating front tyre 220 and rear tyre 210 (if i am reading it correctly) for 09 jazz. I am aiming for optimum comfort in ride. Thanks Edited October 6, 2010 by E-Jazz ↡ Advertisement Link to post Share on other sites More sharing options...
Lowrider 2nd Gear October 6, 2010 Share October 6, 2010 Hi bros/sis, Just wondering what you would recommend for tyre pressure given that the sticker on my door (as shown in image) indicating front tyre 220 and rear tyre 210 (if i am reading it correctly) for 09 jazz. Thanks u can pump it up to 40 psi... a little bumpier but better FC Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie October 6, 2010 Author Share October 6, 2010 u can pump it up to 40 psi... a little bumpier but better FC For all 4 tyres? How about for comfort? I am the type to go for more comfort haha. Thanks. Link to post Share on other sites More sharing options...
Tohto Hypersonic October 6, 2010 Share October 6, 2010 Normally I pump ~10% more than sticker. 220 - pump 240 Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie October 6, 2010 Author Share October 6, 2010 Normally I pump ~10% more than sticker. 220 - pump 240 I see, do you pump all four wheels same? Link to post Share on other sites More sharing options...
Tohto Hypersonic October 6, 2010 Share October 6, 2010 I see, do you pump all four wheels same? Yes. Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie October 6, 2010 Author Share October 6, 2010 Yes. Alright, thanks. Link to post Share on other sites More sharing options...
Strix Neutral Newbie October 6, 2010 Share October 6, 2010 u can pump it up to 40 psi... a little bumpier but better FC correct me if i'm wrong...but it will wear the tyre out unevenly if you pump too high a pressure right?? Link to post Share on other sites More sharing options...
Mini-itx Clutched October 6, 2010 Share October 6, 2010 For all 4 tyres? How about for comfort? I am the type to go for more comfort haha. Thanks. Just pump a little more 20kpa more won't affect your ride comfort. Link to post Share on other sites More sharing options...
Lowrider 2nd Gear October 6, 2010 Share October 6, 2010 correct me if i'm wrong...but it will wear the tyre out unevenly if you pump too high a pressure right?? if u pump it extremely too high.. 40psi isn't that high. If your wheel alignment is out, that will cause uneven tire wear Link to post Share on other sites More sharing options...
Jchuacl Clutched October 6, 2010 Share October 6, 2010 If u r using tyres without flimsy sidewall, just pump the pressure as indicated . If u r using tyres with flimsy sidewall , then u will need pump a little more but not till 40psi. Hi bros/sis, Just wondering what you would recommend for tyre pressure given that the sticker on my door (as shown in image) indicating front tyre 220 and rear tyre 210 (if i am reading it correctly) for 09 jazz. I am aiming for optimum comfort in ride. Thanks Link to post Share on other sites More sharing options...
Jchuacl Clutched October 6, 2010 Share October 6, 2010 Hi bros/sis, Just wondering what you would recommend for tyre pressure given that the sticker on my door (as shown in image) indicating front tyre 220 and rear tyre 210 (if i am reading it correctly) for 09 jazz. I am aiming for optimum comfort in ride. Thanks Link to post Share on other sites More sharing options...
Thedream 3rd Gear October 6, 2010 Share October 6, 2010 if u pump it extremely too high.. 40psi isn't that high. If your wheel alignment is out, that will cause uneven tire wear brother, people's ride recommended 220/210 you ask him to pump 40 psi is 276 kPa leh... Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 6, 2010 Share October 6, 2010 (edited) Hi bros/sis, I am aiming for optimum comfort in ride. Thanks 220, 210 Edited October 6, 2010 by Jamesc Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 6, 2010 Share October 6, 2010 Hi bros/sis, Just wondering what you would recommend for tyre pressure given that the sticker on my door (as shown in image) indicating front tyre 220 and rear tyre 210 (if i am reading it correctly) for 09 jazz. I am aiming for optimum comfort in ride. Thanks The manufacturer already advised you with the sticker? Deflate below that minimium pressure and the car may not brake/steer normally Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 6, 2010 Share October 6, 2010 u can pump it up to 40 psi... a little bumpier but better FC I am wondering if you do not understand his question, or you assume his question? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 6, 2010 Share October 6, 2010 Normally I pump ~10% more than sticker. 220 - pump 240 I wonder if you do not understand his question, or you assume his question? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 6, 2010 Share October 6, 2010 Alright, thanks. All wrong. he did not understand the question or assume the question. Now you assume his answer to be in order? ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
