Jj5599 1st Gear November 15, 2010 Share November 15, 2010 I was thinking of DIY clay bar on my car for the first time. Is it easy enough to DIY or better to send to detailer? I mean would it be likely to cause more problems if I DIY? ↡ Advertisement Link to post Share on other sites More sharing options...
Wizzercool 1st Gear November 15, 2010 Share November 15, 2010 The process is easy, but you need to have patience and time (plenty of time). One mistake that I always make when I did the DIY claying was dropping the clay onto the ground rendering it useless for any use on the car body. Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 15, 2010 Share November 15, 2010 (edited) I was thinking of DIY clay bar on my car for the first time. Is it easy enough to DIY or better to send to detailer? I mean would it be likely to cause more problems if I DIY? And also ensure your shampoo has enough lubricant..Get the correct claybar and is safe..Claybar have different type..from abrasive to mild abrasive.. here is a video.. Edited November 15, 2010 by Maddriver Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 15, 2010 Share November 15, 2010 The process is easy, but you need to have patience and time (plenty of time). One mistake that I always make when I did the DIY claying was dropping the clay onto the ground rendering it useless for any use on the car body. Actually i do drop it once a while..I soak into shanpoo..wash it and use it again.. Link to post Share on other sites More sharing options...
Jj5599 1st Gear November 15, 2010 Author Share November 15, 2010 (edited) which brand is mild-abrasive? i think beginner i should use that? What shampoo should I use? I thought i should use the spray type quick detailer? Edited November 15, 2010 by Jj5599 Link to post Share on other sites More sharing options...
Nzy Twincharged November 15, 2010 Share November 15, 2010 Actually i do drop it once a while..I soak into shanpoo..wash it and use it again.. If u can should just throw away. Cuz the shampoo sometimes cannot wash out the dirt and in the end ur car got alot of swirls. Link to post Share on other sites More sharing options...
Kezg1 5th Gear November 15, 2010 Share November 15, 2010 I was thinking of DIY clay bar on my car for the first time. Is it easy enough to DIY or better to send to detailer? I mean would it be likely to cause more problems if I DIY? Should not be any problem.....do it once a month.... I normally dip into little soapy water. Only for the not so fussy type... Link to post Share on other sites More sharing options...
Tweety889 Neutral Newbie November 15, 2010 Share November 15, 2010 For a moment I thought you meant to DIY, make a claybar yourself ... silly me :) Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 15, 2010 Share November 15, 2010 which brand is mild-abrasive? i think beginner i should use that? What shampoo should I use? I thought i should use the spray type quick detailer? Most off the shelf should be mild abrasive...I have clay lube coming in soon..To be premix with water and it has lots of lub in it.. You can use a quick detail for claying but I think is too expensive to use it just for claying.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 15, 2010 Share November 15, 2010 If u can should just throw away. Cuz the shampoo sometimes cannot wash out the dirt and in the end ur car got alot of swirls. Ya, my van got a lot of swirl now..enough for a plate of bee hoon.. doesn't mean everytime the floor has lot of sands right..depend on situation la.. Link to post Share on other sites More sharing options...
Krismas Neutral Newbie November 15, 2010 Share November 15, 2010 ONR makes a reasonably good (and cheap) clay lube. Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 15, 2010 Share November 15, 2010 ONR makes a reasonably good (and cheap) clay lube. Kris..will pass u some DNR ( duragloss no rinse ) soon..pm mi your address.. Link to post Share on other sites More sharing options...
Limck007 Neutral Newbie November 17, 2010 Share November 17, 2010 Kris..will pass u some DNR ( duragloss no rinse ) soon..pm mi your address.. benny .. i need to get from you my QD, 501 and 111 in dec when i get back from spore. now in overseas... on 3 mth assignment... damm sianzzzzzzzzzzz Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 18, 2010 Share November 18, 2010 benny .. i need to get from you my QD, 501 and 111 in dec when i get back from spore. now in overseas... on 3 mth assignment... damm sianzzzzzzzzzzz Sure bro...enjoy yr trip.. Link to post Share on other sites More sharing options...
Krismas Neutral Newbie November 18, 2010 Share November 18, 2010 Kris..will pass u some DNR ( duragloss no rinse ) soon..pm mi your address.. That is pretty AWESOME!!! Cheers mate. PMing..... Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear November 22, 2010 Share November 22, 2010 the main hinderance for DIY Claybar is actually the process... wash.. claybar.. wash.... also dont want to waste the effort... normally will do the sealant & waxing.... so it was really very tiring... expect to spend hours @ the washing bay... but after claybar, the surface will be very smooth...very shiok to touch.. Link to post Share on other sites More sharing options...
Booboon 1st Gear November 27, 2010 Share November 27, 2010 ONR makes a reasonably good (and cheap) clay lube. wats the dilution ratio? Link to post Share on other sites More sharing options...
Optivax 1st Gear November 27, 2010 Share November 27, 2010 wats the dilution ratio? approx 2 oz for 16oz water.. ↡ Advertisement Link to post Share on other sites More sharing options...
Singapore indeed is a safe country
Dunlop SP Sport FM800
Fire extinguisher (safe to be kept inside car's boot?)
In-Car Power Inverter - Safe or Not?
Is Singapore Safe From Earthquakes ?
Different version of 3M Clay Bar
Israel: safe to drive?
Tyre patching safe?
Tyre patching safe?
