Soya Supersonic November 20, 2010 Share November 20, 2010 i flush every morning. ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator November 20, 2010 Share November 20, 2010 i flush every morning. old man like you still can go every morning ah..thought weekly??? or weakly Link to post Share on other sites More sharing options...
Soya Supersonic November 20, 2010 Share November 20, 2010 old man like you still can go every morning ah..thought weekly??? or weakly eh, anytime ppl see u, sure hv to flush one.... [laugh] Link to post Share on other sites More sharing options...
Kamenrider Neutral Newbie November 20, 2010 Share November 20, 2010 Premium Auto also recommends my Audi for flushing... Link to post Share on other sites More sharing options...
Crazecow Neutral Newbie November 20, 2010 Share November 20, 2010 As the video has mentioned, flushing is a risky procedure. The deposits that came off may clog narrow oil glleries. If that happens you are in big trouble. Regular oil change is the best flushing. If you need to remove desposits. Just use a cheap oil and run it for 500/1000KM and change it. Engine flush can also breaks down the engine oil, causing the oil unable to adhere properly to metal surfaces. If that happens, you get massive wear due to metal contact. If you have done ebgine flush before, you realise the oil coming out is very thin like water? Thats what the flush did to the oil. W/o flush, oil is thicker. Link to post Share on other sites More sharing options...
Klchua 1st Gear November 20, 2010 Share November 20, 2010 used to do engine flush but not now, don't feel the difference. also, there is this thing call oil filter that already help to trap most of the dirt etc... Link to post Share on other sites More sharing options...
Zxcvb Turbocharged November 20, 2010 Share November 20, 2010 Toyota Borneo Motors also have an option for engine flushing apart from their usual servicing package. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 20, 2010 Share November 20, 2010 As the video has mentioned, flushing is a risky procedure. The deposits that came off may clog narrow oil glleries. If that happens you are in big trouble. Regular oil change is the best flushing. If you need to remove desposits. Just use a cheap oil and run it for 500/1000KM and change it. Engine flush can also breaks down the engine oil, causing the oil unable to adhere properly to metal surfaces. If that happens, you get massive wear due to metal contact. If you have done ebgine flush before, you realise the oil coming out is very thin like water? Thats what the flush did to the oil. W/o flush, oil is thicker. u r right... if engine is too dirty, you cant flush. If your engine is clean, no point to flush... either way,. flushing is not necessary... Link to post Share on other sites More sharing options...
ER-3682 Supersonic November 20, 2010 Share November 20, 2010 If the car is using 100% Syn oil since new,no need to flush,because there will be no or very little deposit. Link to post Share on other sites More sharing options...
Chilla18 Neutral Newbie November 20, 2010 Share November 20, 2010 Another way of engine flush is drain out oil oil put in new oil run for 10-15min drain out and put in new oil againg this is another way of flushing the engine. Link to post Share on other sites More sharing options...
Panhard 1st Gear November 20, 2010 Author Share November 20, 2010 (edited) Toyota Borneo Motors also have an option for engine flushing apart from their usual servicing package. but if you carefully read the manuals of most car maker--no indication of flush required. all this is at the local agents discretion...bottom line is its money making. truly i feel it can do more harm than good. esp to all the seals & gaskets ! Edited November 20, 2010 by Panhard Link to post Share on other sites More sharing options...
Panhard 1st Gear November 20, 2010 Author Share November 20, 2010 Another way of engine flush is drain out oil oil put in new oil run for 10-15min drain out and put in new oil againg this is another way of flushing the engine. for me i feel this way more safer. thats why dont stretch your oil change period too long for sludge to form.... Link to post Share on other sites More sharing options...
Panhard 1st Gear November 20, 2010 Author Share November 20, 2010 If the car is using 100% Syn oil since new,no need to flush,because there will be no or very little deposit. thats the good thing about using syn. oil in the engine.... Link to post Share on other sites More sharing options...
Forte3737 5th Gear November 20, 2010 Share November 20, 2010 thats the good thing about using syn. oil in the engine.... use reputable brands syn oil. not those too cheap type Link to post Share on other sites More sharing options...
Branteo Clutched November 20, 2010 Share November 20, 2010 Just changed mine yesterday. I'm using Mugen Rev R for my engine oil - left me with a S$165 damage (for 4 litres). Link to post Share on other sites More sharing options...
Initial_fire82 Neutral Newbie November 20, 2010 Share November 20, 2010 In singapore... car drive how long only. the most 10 years.. flush or no flush no diff lah...just traditional service can already. engine flush, addictive, broquet imo is no use or little use. Link to post Share on other sites More sharing options...
Forte3737 5th Gear November 20, 2010 Share November 20, 2010 Just changed mine yesterday. I'm using Mugen Rev R for my engine oil - left me with a S$165 damage (for 4 litres). unless you are driving a high performance car, the oil is an overkill Link to post Share on other sites More sharing options...
Chemluber Neutral Newbie November 21, 2010 Share November 21, 2010 If you wanna give your engine a good clean why not Auto-Rx? Works great.. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Any recommended tyre shop
Any recommended workshop with reasonable labour charges?
