Aircon pipe insulation DIY
Stanchiam
Actually I read somewhere Air con wrapping will trapped the condense water, and this may corrode the piping.. How serious or true is that? I don't know.
Water is condensated when the heat from the engine reaches the cold pipe.
The insulation insulates the heat from reaching the pipe and this helps
prevent condensation in the first place. :D
it does not work at all. so dun spend those $$ and waste time. those who have wrapped and tell you its colder now, its just psychological effect at work
oh well, be in psychological or real, as long as my wife asked me the question "do u go and service the aircon? how come it get colder faster now?"
For me that is enough. Maybe its psychological but doesnt matter as long i feel it get colder faster and maintain the coldness for a while after i turn it off.
No harm wrapping it, its like a condom protecting it from engine heat...lol
$2 and 15mins I can affort to waste.... [:p]
Edited by Stanchiam
why do u need to wrap w alum foil? any extra effect? i thot rmaflex wrap enuf?
contemplating of doin it too. whr to get armaflex? alum foil should be those normal foil fr supermarket used to wrap turkey / poultry for bakin rite? thx.
Edited by Fuelsaver
aircon material shop should have and just note that it cost about $2 only for 2m, dont get carrot head chop
alum foil is optional
Yes, but for foil i chose heavy duty type, 25sqft is normal while 37sqft is heavy duty, slightly thicker.
Well, the foil is used to protect the wrap from getting wet and also, it will reflect some heat away.
Thats science, remember to let the shiny surface face outside and the dull surface inside.
Just imagine putting a potato and bake it directly on charcoal versus wrapping it with alum foil, u will see the differences in the potato
Edited by Stanchiam
for me, I wrap all, just make sure the tube is aircon tube
if u want to do such DIY, make sure you wrap the correct pipe... 1 pipe is supply, another one is return. start your car, turn on the aircon to max, 5 mins later. touch each pipe. you should wrap only the pipe that is cool.
Yes it does nothing to coldness, as that is control by knobs or button setting for temperature or thermostat. What the insulating tube does is reduces heat loss during coolant transmission. Basically you want more of heat exchange to occur at the coil where the wind blows into the cabin, rather than loose some heat at the engine bay.
This should translate to the lesser energy used to achieve the same cooling load.
bro, not reduce heat loss lah, should be reduce "cool loss"[laugh][laugh] , the pipe transmitting the gas to the coil is cool, if exposed to the engine bay temp, it will absorb more heat and the compressor have to work harder to achieve the temp set by the termostate...... by wrapping the pipe,lesser heat will be absorb...
excellent explanation, no wonder feel the coldness last longer after i turn off
so....
[laugh]
This is serious and true. It just a matter of time. This will even happen to home aircon insulation (Indoor).
FYI, the cool pipe is going back to compressor. the hot one is going to coil (cabin). hot one is after compress and cool into liquid, heat released. cool one is vaporised and very cool, sub zero already.
really?? but the way u describe sound like how a heater work lrh... hot one go to the coil (cabin), then heat up the coil, blower blow thru the hot coil, hot air comes out? [laugh][laugh]
dig up an old thread. anyone can advice where to get this aricon insulation? thinking for DIY my piping also leh.. especially now the weather so hot. Wrapping will help anot?
OK Just to put in my 2cents worth here.
I did consider doing e ac pipe wrap cos it makes sense to me.
B4 I diy....I consult Ah Huat of Markcool...the ac specialist. [scholar]
His advice is dont do it.
Seems the pipe wil hv condensation n the water wil accumulate under the wrap on the pipe n might cause some corrosion problems so I scrap the idea.
Maybe thats why all cars dun come from e factory wh the cold pipe already wrapped in insulation foam. [confused]
yep. car mfg would have done it in the factory if it works at all
Thats why I checked wh someone who sud know n he said dun do so I listen to him lor. -_-
i thought the pipings are alunmium type? will also get corroded? if its steel probably i will say it will corrode over time due to condensation.
Supersonic
My getz a/c pipe has factory insulation in certain area.
Exposed pipe is usually aluminium, they don't corrode that easily unlike sheet metal.
Flexible pipe is some form of rubber.
My vw van has more factory "insulation", but it's probably also to prevent rubbing against other pipes/parts and making holes.
Should we wrap and try to keep the "cool" gaseous coolant colder and longer before it hits the compressor ?
It's quite debatable.
Fact is, compressor can't compress liquid, it can only compress gas.
Perhaps the effort should be made on keeping the front a/c radiator clean and cooling more efficiently, rather than focus on the wraps.
All metals wil corrode/oxerdise over time. Even stainless steel. Only difference is how long.
