Sstar Neutral Newbie January 24, 2011 Share January 24, 2011 Last night, my 4 year old Latio suddenly vibrated terribly afetr move off from traffic light, scared and called Insurance company immediately to tow to to Tan Chong Motor, today I was informed 3 out of 4 ignition coils were damaged, the last one also degrade, might not last long. For safety and balance, they requested to replace 4 coils together. total cost was 800+, Just wondering, what is the chance that 3 coils spoil at the same time? is it necessary to replace all the 4 coils? ↡ Advertisement Link to post Share on other sites More sharing options...
Carer 2nd Gear January 24, 2011 Share January 24, 2011 First u need to know what is the function of an ignition coil. it is to step up 12V to around 10,000 - 15,000V (if i remembered correctly) to create a spark across your spark plug. so if the plug cannot spark properly, coil MAY (not definite) up lorry. it could be the cylinder not firing properly tat causes the engine vibration (something like going to die off?). one way to check is change new plugs first. maybe plug is dirty and cannot fire properly due to water seepage. sometimes it is better to have a second opinion. go other workshop check yourself. even doctors can give wrong diagnosis. just a word of caution. Link to post Share on other sites More sharing options...
Moredhel 2nd Gear January 24, 2011 Share January 24, 2011 Go get aftermarket coils better. Or get get from scrapyard. 800+ my arse. Link to post Share on other sites More sharing options...
Carer 2nd Gear January 24, 2011 Share January 24, 2011 (edited) aftermarket coils usually provide higher voltage resulting in a better spark, and better combustion leading to improved efficiency. but manufacturers already spent so much on R&D to improve car efficiency. so the stock coils already provide the best cost to effect ratio, no need to gei zua go buy expensive coils. why people still change coils? tats because the stock ones are more expensive than aftermarket after mark up! unless stock ones up lorry, just keep it stock Edited January 24, 2011 by Carer Link to post Share on other sites More sharing options...
Moredhel 2nd Gear January 24, 2011 Share January 24, 2011 aftermarket coils usually provide higher voltage resulting in a better spark, and better combustion leading to improved efficiency. but manufacturers already spent so much on R&D to improve car efficiency. so the stock coils already provide the best cost to effect ratio, no need to gei zua go buy expensive coils. why people still change coils? tats because the stock ones are more expensive than aftermarket after mark up! unless stock ones up lorry, just keep it stock Wrong, manufacturers spent so much to ensure their car's reliability for 20-30 years engine wear and tear coz they scared kenna sue. In Sinkapore you won't drive your B&B for more than 10 years. So zhng abit for better driveability. ADs charge too high becoz got alot of sotongs think original is best for B&Bs and ADs/Insurance uses scare tactics to ensure on-going carrot chopping business. 4 year old 4 ignition coils possibly die off?? Simi reliability? Chances are that TS add too many additives which eat out the rubber seal of the piston or cylinders. Link to post Share on other sites More sharing options...
Sstar Neutral Newbie January 24, 2011 Author Share January 24, 2011 First u need to know what is the function of an ignition coil. it is to step up 12V to around 10,000 - 15,000V (if i remembered correctly) to create a spark across your spark plug. so if the plug cannot spark properly, coil MAY (not definite) up lorry. it could be the cylinder not firing properly tat causes the engine vibration (something like going to die off?). one way to check is change new plugs first. maybe plug is dirty and cannot fire properly due to water seepage. sometimes it is better to have a second opinion. go other workshop check yourself. even doctors can give wrong diagnosis. just a word of caution. They told me the coil was short circuit. that means the coil can not gernerate high voltage, the car can not start any more. But my car still can start most of the time leh....... 2 times failed to start with engine light on. Link to post Share on other sites More sharing options...
Sstar Neutral Newbie January 24, 2011 Author Share January 24, 2011 Wrong, manufacturers spent so much to ensure their car's reliability for 20-30 years engine wear and tear coz they scared kenna sue. In Sinkapore you won't drive your B&B for more than 10 years. So zhng abit for better driveability. ADs charge too high becoz got alot of sotongs think original is best for B&Bs and ADs/Insurance uses scare tactics to ensure on-going carrot chopping business. 4 year old 4 ignition coils possibly die off?? Simi reliability? Chances are that TS add too many additives which eat out the rubber seal of the piston or cylinders. never add additives since day 1.......... stockist quote $110 per coil, other workshop quote $130+ per coil plus labour, and cost of tow service Link to post Share on other sites More sharing options...
ER-3682 Supersonic January 24, 2011 Share January 24, 2011 never add additives since day 1.......... stockist quote $110 per coil, other workshop quote $130+ per coil plus labour, and cost of tow service Tan Chong's overhead high,so price sure more expensive[all the agents is the same.] than outside workshop. Link to post Share on other sites More sharing options...
ER-3682 Supersonic January 24, 2011 Share January 24, 2011 never add additives since day 1.......... stockist quote $110 per coil, other workshop quote $130+ per coil plus labour, and cost of tow service Outside mostly use O.E.M.[no warranty] so it is also cheaper. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 24, 2011 Share January 24, 2011 It does not make sense. If the coils are affected that means the whole electrical system ranging from batt to alternator also got problem. Electrical components could be easily damaged if they suffer power starvation or surges. Better have a second opinion. Link to post Share on other sites More sharing options...
D3badge 6th Gear January 24, 2011 Share January 24, 2011 It does not make sense. If the coils are affected that means the whole electrical system ranging from batt to alternator also got problem. Electrical components could be easily damaged if they suffer power starvation or surges. Better have a second opinion. you dun need electric system to fail together I had 2 out of 6 coil down before. and yes just the coil damage, change all sparks and coil, engine as good as before Link to post Share on other sites More sharing options...
Sstar Neutral Newbie January 24, 2011 Author Share January 24, 2011 if I decide not to repair at Tan Chong, do they have the rights to charge me for the diagnostics? they spent quite a lot time and resource on this issue. Link to post Share on other sites More sharing options...
D3badge 6th Gear January 24, 2011 Share January 24, 2011 if I decide not to repair at Tan Chong, do they have the rights to charge me for the diagnostics? they spent quite a lot time and resource on this issue. I think they do after all labour is involve. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 24, 2011 Share January 24, 2011 (edited) you dun need electric system to fail together I had 2 out of 6 coil down before. and yes just the coil damage, change all sparks and coil, engine as good as before I dunno how u concluded that I say the system fail. But if u insist I also no choice. Why not read again? The problem I mentioned could be the charging system or the batt is weak, not able to output enough power for all the coils to work at their optimum thus leaving them to starve thus damaging the coils. Edited January 24, 2011 by Watwheels Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 24, 2011 Share January 24, 2011 The shop should use a spark inline spark tester to prove to you that the coil is KO. Link to post Share on other sites More sharing options...
Carer 2nd Gear January 24, 2011 Share January 24, 2011 Wrong, manufacturers spent so much to ensure their car's reliability for 20-30 years engine wear and tear coz they scared kenna sue. In Sinkapore you won't drive your B&B for more than 10 years. So zhng abit for better driveability. ADs charge too high becoz got alot of sotongs think original is best for B&Bs and ADs/Insurance uses scare tactics to ensure on-going carrot chopping business. 4 year old 4 ignition coils possibly die off?? Simi reliability? Chances are that TS add too many additives which eat out the rubber seal of the piston or cylinders. It is this type of mentality tat keeps aftermarket workshops going and also the economy. keep it up. for me, i will just keep it stock. Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 24, 2011 Share January 24, 2011 coil failure is relatively common. why? cause everyone try to cut cost and use cheaper parts. and thus higher chance of breaking down. also the relatively higher under bonnet temps these days due to emission standards. so the coil is subjected to more 'torture' so fail lor. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear January 24, 2011 Share January 24, 2011 stock coil got so easy kaput meh??? sure it's due to the coil or something else? hmmmmm... ↡ Advertisement Link to post Share on other sites More sharing options...
Damaged ignition coil. consequences?
Nissan Latio Ignition Coils Replacement
New VW still using key ignition
FireStorm Ignition Coil Booster
A/C repair in JB
A/C repair in JB
Suspect Aircon coil leak
Axio / Fielder evaporator (cooling coil) leak
Replacement of fl N16 sunny ignition coils
