So_nice 6th Gear March 23, 2011 Author Share March 23, 2011 i had a similiar encounter but not sure if it applies to your situation I bought a new air filter from forum and brought it to the workshop to change after changing, i realize that whenever my car went into D and stationary, it vibrate like a lorry Open my bonnet and found my air filter box shaking like mad! Thought going to explode liao Went straight back to workshop to diagnose and decided to buy another air filter from 1 of the shops there After changing then surprising the vibration stops! You guys can try changing the air filter. FYI the 1 i bought from forum has a denso wording on it and looks new. to my surprise, my vibrating problem is solved too! i bought a k&n drop-in and proceeded to change out the OEM filter. drove it around and the vibrating problem is gone. the car is now quiet and slient when idle. lolx ↡ Advertisement Link to post Share on other sites More sharing options...
Monkeykidz Neutral Newbie March 23, 2011 Share March 23, 2011 ma tu liao .... i going to change air filter soon~ [:p] Link to post Share on other sites More sharing options...
So_nice 6th Gear March 23, 2011 Author Share March 23, 2011 but seriously, i cannot understand why the air filter can cause this problem..really weird! Link to post Share on other sites More sharing options...
Budgetdriver 1st Gear June 23, 2011 Share June 23, 2011 but seriously, i cannot understand why the air filter can cause this problem..really weird! Everything has a resonance frequency and the airbox resonance freq happens to be the same as engine idling frequency. That's why vibration is worst only when idling. but once we put neutral or off Air cond the engine speeds up past that frequency and then the vibration is significantly removed. By adding a slightly heavier knn filter the mass is increased which results in a slower resonance frequency than idling, and I believe that's why u dont see the vibration anymore. Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 14, 2011 Share August 14, 2011 Sir, can I ask you which workshop you change your absorbers? My 04 vios, 100k mileage, absorbers spoil liao. Autosaver quoted $265+GST to replace 2 rear absorbers. why not get the shock from stockists? then pay for the labour only. much more cheaper Link to post Share on other sites More sharing options...
WFME Neutral Newbie August 25, 2011 Share August 25, 2011 Everything has a resonance frequency and the airbox resonance freq happens to be the same as engine idling frequency. That's why vibration is worst only when idling. but once we put neutral or off Air cond the engine speeds up past that frequency and then the vibration is significantly removed. By adding a slightly heavier knn filter the mass is increased which results in a slower resonance frequency than idling, and I believe that's why u dont see the vibration anymore. Actually, my guess without looking at the car is that the at idle, your car runs on close-loop and the due to blockage, not enough air is going into the car and thus the vibration due to incorrect fuel to air mixture. Link to post Share on other sites More sharing options...
WFME Neutral Newbie August 25, 2011 Share August 25, 2011 why not get the shock from stockists? then pay for the labour only. much more cheaper May or may not be the case pending on the WS and the price of spares they are getting. Don't forget, in most cases the WS will have a tradesmen discount and you still have spend money and time for petrol, to drive down and parking. Like I said, may or may not save so calculate properly and don't assume. Also, it is common practice for some workshop to package the spares with labor. It simply means that if they charge $200 for spares and $100 for labor, don't assume that they will charge $100 even if you bring your own spares. It's always good to check how much they charge for labor if you bring your own spares to avoid disagreements. Work with a WS you feel comfortable with and trust, after all, it's better to head to someone you feel is honest and meet your needs for the 10 years of your car's life rather than hunt around for best deal all the time and worry about being ripped off each time you push your ride in. Link to post Share on other sites More sharing options...
Klownyan Neutral Newbie September 6, 2011 Share September 6, 2011 bros` here..when a passenger sit on my vios 06,rear or front there will be a squeking sound frm the suspension...whats the problem due..? Link to post Share on other sites More sharing options...
Icecube187 2nd Gear September 7, 2011 Share September 7, 2011 is your handbrake engaged when you hear the squeaking sound? If yes, then no worries. Link to post Share on other sites More sharing options...
R_aquarii 1st Gear September 7, 2011 Share September 7, 2011 mine also. time to change shock liao... Link to post Share on other sites More sharing options...
Ivan_06 5th Gear September 7, 2011 Share September 7, 2011 May or may not be the case pending on the WS and the price of spares they are getting. Don't forget, in most cases the WS will have a tradesmen discount and you still have spend money and time for petrol, to drive down and parking. Like I said, may or may not save so calculate properly and don't assume. Also, it is common practice for some workshop to package the spares with labor. It simply means that if they charge $200 for spares and $100 for labor, don't assume that they will charge $100 even if you bring your own spares. It's always good to check how much they charge for labor if you bring your own spares to avoid disagreements. Work with a WS you feel comfortable with and trust, after all, it's better to head to someone you feel is honest and meet your needs for the 10 years of your car's life rather than hunt around for best deal all the time and worry about being ripped off each time you push your ride in. For me, i go to Riverview Auto!! May not be the cheapest but i get the assurance of mind.. My vios has been serviced by them since 20k... Link to post Share on other sites More sharing options...
Klownyan Neutral Newbie September 7, 2011 Share September 7, 2011 the sound come only when the vehicle is stationary n when passenger sit or get up frm my car...quite loud squeking sound..is it my suspension? mine is 06 fl Link to post Share on other sites More sharing options...
Keithchue 5th Gear September 21, 2011 Share September 21, 2011 bros, i'm driving 05 vios, recently i can feel a kick on the seat when the aircon comp kicks in...seems like a person seating behind me kicking the seat....any suggestions? Link to post Share on other sites More sharing options...
Tinydog Clutched September 21, 2011 Share September 21, 2011 For me, i go to Riverview Auto!! May not be the cheapest but i get the assurance of mind.. My vios has been serviced by them since 20k... I replaced my old VIOS shock absorbers with them before. all 4 of them. Total damage $380. But not those OEM ones. Most importantly is they recommended it and say its similar to original ones. Link to post Share on other sites More sharing options...
Tinydog Clutched September 21, 2011 Share September 21, 2011 bros, i'm driving 05 vios, recently i can feel a kick on the seat when the aircon comp kicks in...seems like a person seating behind me kicking the seat....any suggestions? You hear the "click" sound? I dunno why only vios has this when the air con is turned on. Link to post Share on other sites More sharing options...
Tinydog Clutched September 21, 2011 Share September 21, 2011 the sound come only when the vehicle is stationary n when passenger sit or get up frm my car...quite loud squeking sound..is it my suspension? mine is 06 fl Its your chair la. Otherwise your passengers might be overweight and your car is protesting! Link to post Share on other sites More sharing options...
Harcals 1st Gear October 18, 2011 Share October 18, 2011 very informative...im getting 06 vios too at 80k milage...i would like to straight away go to WS and do the necessary...problem is i don't know what to fix/change first... any kind soul to help...thanks. Link to post Share on other sites More sharing options...
Mahjong74 Supercharged October 18, 2011 Share October 18, 2011 very informative...im getting 06 vios too at 80k milage...i would like to straight away go to WS and do the necessary...problem is i don't know what to fix/change first... any kind soul to help...thanks. For me, I will go to trustworthy WS to do a major 80k servicing. My mechanic even have the diagnostic computer for toyota. I had used him for the last 10 yrs. PM me if you need my WS contact. You can call him to check the price before you go down. Or autosaver also quite good ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
