Torque6 Neutral Newbie February 22, 2011 Share February 22, 2011 (edited) with the hike on tyres, don't feel like changing them as my tyre depth still around 5mm. Any recommendations? I thinking of going SHH at woodlands or any tyre shop near riverview WS. My passenger rear side seems to goes flat in 3 weeks, so have to pump every week. My tyre sizes are 225/45/17 and 245/40/17. Edited February 22, 2011 by Torque6 ↡ Advertisement Link to post Share on other sites More sharing options...
GemLeo 1st Gear February 22, 2011 Share February 22, 2011 bro, you bought it at stamford? why don't you try going back to them? Link to post Share on other sites More sharing options...
Silver_blade Turbocharged February 22, 2011 Share February 22, 2011 You can go to any reputable tyre shop to have it patched. But more importantly....is the damage repairable? Better to let the tyre shop have a look. Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 22, 2011 Share February 22, 2011 with the hike on tyres, don't feel like changing them as my tyre depth still around 5mm. Any recommendations? I thinking of going SHH at woodlands or any tyre shop near riverview WS. My passenger rear side seems to goes flat in 3 weeks, so have to pump every week. My tyre sizes are 225/45/17 and 245/40/17. most tyre shop do tyre reapair with outside method (generally called i temperary way repair by car owner) best is ask your shop to carry out the inside method of repaired which assure you of the tyre is safe to put back on the road used ( only inside method repair has the access to examine the tyre internal condition)(in some cases tyre is demaged or injured internally after punctured) So do make your choice of repair method wisely Link to post Share on other sites More sharing options...
Torque6 Neutral Newbie February 22, 2011 Author Share February 22, 2011 yup, bought at stamford tires at AMK ind PK2. will go back to them. By the way, do i need to bring my receipt? Or they would be able to check on their end? Link to post Share on other sites More sharing options...
Nf0rc3r 1st Gear February 26, 2011 Share February 26, 2011 where u stay? I juz patched mine opposite ten mile junction for $15 internal patch. Link to post Share on other sites More sharing options...
Beng2 5th Gear February 26, 2011 Share February 26, 2011 I did my internal patch at one of the shops in Sungei Kadut. $10 nia, including balancing. TS must ask properly because not all shops offer internal patch (although it does not look too technical to do, but more work to be done - take out tyre from rim, sandpaper the internal, apply sealant and let it dry, patch it, fix back tyre, balancing). Link to post Share on other sites More sharing options...
Picanto 3rd Gear February 26, 2011 Share February 26, 2011 I did my internal patch at one of the shops in Sungei Kadut. $10 nia, including balancing. TS must ask properly because not all shops offer internal patch (although it does not look too technical to do, but more work to be done - take out tyre from rim, sandpaper the internal, apply sealant and let it dry, patch it, fix back tyre, balancing). i think there are some shops that take short cut when doing patching work. suggest you go to reputable ones such as stamford tyres Link to post Share on other sites More sharing options...
D3badge 6th Gear February 26, 2011 Share February 26, 2011 yup, bought at stamford tires at AMK ind PK2. will go back to them. By the way, do i need to bring my receipt? Or they would be able to check on their end? dun need receipt as stamford will have ur car plate key in their system Link to post Share on other sites More sharing options...
D3badge 6th Gear February 26, 2011 Share February 26, 2011 i think there are some shops that take short cut when doing patching work. suggest you go to reputable ones such as stamford tyres I patch mine at stamford before, they use tyre plug too Link to post Share on other sites More sharing options...
Beng2 5th Gear February 27, 2011 Share February 27, 2011 I patch mine at stamford before, they use tyre plug too Did you ask for the internal patch, or did you just "my tyre puncture liao", Mechanic said, "OK". Link to post Share on other sites More sharing options...
Torque6 Neutral Newbie February 27, 2011 Author Share February 27, 2011 (edited) I managed to patched them at LS yesterday. Mechanic quite pro. They found 2 3 inch screws in my tyres..... So had to do 3 patches. Total price was around $40. Is it expensive? I thought patching is standard everywhere, $10 per sesson. Edited February 27, 2011 by Torque6 Link to post Share on other sites More sharing options...
Karebu 1st Gear February 27, 2011 Share February 27, 2011 sidetrack a bit. what does the 'flat tyre' option on air pumps do? i pressed it for fun and air keeps gushing out when it was not even connected to a nozzle. Link to post Share on other sites More sharing options...
Karu 6th Gear March 9, 2011 Share March 9, 2011 Does it mean that those external repair using 'fillers pushed in & pulled out' method is not reliable? Mine was done that way. Wonder if I should get it repaired internally or change the tyre... Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 11, 2011 Share March 11, 2011 Does it mean that those external repair using 'fillers pushed in & pulled out' method is not reliable? Mine was done that way. Wonder if I should get it repaired internally or change the tyre... MHO those filler push and pull out is NOT relaible Reason : They cant inspect your tyre internally for any hiddened or internal injury. Sometime(sometime not surely) this push and pull method could enlarged the nail hole(make it bigger) thus the hole is torn and the whole tyre is not so safe to use. So in order to make sure the punctured tyre is safe to put back re-used is Internal patche. Link to post Share on other sites More sharing options...
Breadandwater April 2, 2011 Share April 2, 2011 plug and patch is the best method but most don't do it that way. Patch is better than plug but plug prevents water from making the metal rusty. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 2, 2011 Share April 2, 2011 with the hike on tyres, don't feel like changing them as my tyre depth still around 5mm. Any recommendations? I thinking of going SHH at woodlands or any tyre shop near riverview WS. My passenger rear side seems to goes flat in 3 weeks, so have to pump every week. My tyre sizes are 225/45/17 and 245/40/17. If you are kidding with us. This is ticklish. Any hike is insignificant to someone using those type of tire. If no puncture found on tyre, it could be a defective inflation valve If you got that tyre from places like Stamford, they used to repair puncture for free, if the its the tire they carry. ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Where to get Workshop Manual
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Where to buy canvas cloth to cover entire car?
