Keithchue 5th Gear March 26, 2011 Share March 26, 2011 bros, yesterday went to regular mech for reg servicing for my 05 vios, usually using sparkplug IK16-xxxx, saw them using IK20-xxx, spark plugs, both are from denso...when asked them, they said as they do not have stock for IK16, they used IK20, assured me the same, in fact more power in sparking, is this true? what is the difference between the two of them? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Raymondism Twincharged March 27, 2011 Share March 27, 2011 my mechanic sometimes dun even wan to change spark plug for me.. say wanna save money for me.. somehow i feel like changing spark plug every time i service my car... any bros got this experience? Link to post Share on other sites More sharing options...
Eyke Supercharged March 27, 2011 Share March 27, 2011 read: http://www.globaldenso.com/en/products/aft...ange/index.html http://www.globaldenso.com/en/products/aft...lect/index.html Link to post Share on other sites More sharing options...
Keithchue 5th Gear March 27, 2011 Author Share March 27, 2011 sorry, my technical knowledge a bit lacking, can help to explain? Link to post Share on other sites More sharing options...
Memphis1972 1st Gear March 27, 2011 Share March 27, 2011 my mechanic sometimes dun even wan to change spark plug for me.. say wanna save money for me.. somehow i feel like changing spark plug every time i service my car... any bros got this experience? spark plug can last 30k, my car 50k ,only changed once in 33k when servicing Link to post Share on other sites More sharing options...
Raymondism Twincharged March 27, 2011 Share March 27, 2011 any good plugs to recommend? forgive me.. i am not into mod and such Link to post Share on other sites More sharing options...
Melvyn Neutral Newbie March 27, 2011 Share March 27, 2011 sorry, my technical knowledge a bit lacking, can help to explain? In very basic terms => High heat range, i.e., colder plugs are for highly tuned high HP engines Low heat range, i.e., hotter plugs are for lower HP engines So, if your avatar pic is an indication of your ride, use cold plugs. Which in your case, shd be wrong plug as you shd be looking at IK22 and above. If it's a Impreza 1.6TS, you used the correct plug. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear March 27, 2011 Share March 27, 2011 bros, yesterday went to regular mech for reg servicing for my 05 vios, usually using sparkplug IK16-xxxx, saw them using IK20-xxx, spark plugs, both are from denso...when asked them, they said as they do not have stock for IK16, they used IK20, assured me the same, in fact more power in sparking, is this true? what is the difference between the two of them? thanks They smoke you man.....Absolutely nothing to do with power. The difference in IK16 and IK20 is the heat range. IK16 would be considered heat range 5 for NGK specs, IK20 is heat range 6. Higher number means its a colder plug. If the plug is too cold, it can cause fouling on the plugs and actually degrade performance. Purpose of using correct heat range is to ensure plugs stay within the optimum operating temp. Howver, jump 1 number higher is usually OK, if they use IK22, the NO NO....... Link to post Share on other sites More sharing options...
Dafansu Turbocharged March 28, 2011 Share March 28, 2011 my mechanic sometimes dun even wan to change spark plug for me.. say wanna save money for me.. somehow i feel like changing spark plug every time i service my car... any bros got this experience? I change every 20k Link to post Share on other sites More sharing options...
Keithchue 5th Gear March 28, 2011 Author Share March 28, 2011 nope, i'm not driving a scooby, i'm driving a bread and butter vios. that is me remote control car. so, does this mean they have used the wrong plugs for my car? Link to post Share on other sites More sharing options...
Trex101 3rd Gear March 28, 2011 Share March 28, 2011 nope, i'm not driving a scooby, i'm driving a bread and butter vios. that is me remote control car. so, does this mean they have used the wrong plugs for my car? Nope, IK20 is fine for your Vios, just need to clear carbon once in a while. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear March 28, 2011 Share March 28, 2011 my mechanic sometimes dun even wan to change spark plug for me.. say wanna save money for me.. somehow i feel like changing spark plug every time i service my car... any bros got this experience? It depends. You just need to clean the plugs and check the gaps once in a while.Not necessary have to change all the time on. Link to post Share on other sites More sharing options...
Raymondism Twincharged March 28, 2011 Share March 28, 2011 It depends. You just need to clean the plugs and check the gaps once in a while.Not necessary have to change all the time on. o i c Link to post Share on other sites More sharing options...
Indiandrivesdotcom Neutral Newbie March 28, 2011 Share March 28, 2011 The spark plug must be changed after every two servicing of the car. This is the best way to protect your car from more maintenance cost. i had experienced of this. Link to post Share on other sites More sharing options...
5936 1st Gear March 28, 2011 Share March 28, 2011 Use denso iridium tough. they last 100,000km. Mine is original since day one, now 70k still firing smoothly. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 28, 2011 Share March 28, 2011 i cant find the spark plugs in my WRX Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 28, 2011 Share March 28, 2011 Boxer engine layout - at the bottom. You need w/s to change for you. Hardly DIYable. Link to post Share on other sites More sharing options...
Raymondism Twincharged March 29, 2011 Share March 29, 2011 Use denso iridium tough. they last 100,000km. Mine is original since day one, now 70k still firing smoothly. can this plug be used for most BB car? ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Math Question
Math Question
Plug-and-play vaccine
Spark Car Care
Spark Car Care
Question on Transfer of Car Ownership
Question for Car Servicing
