F1fan Neutral Newbie April 15, 2011 Share April 15, 2011 Would like to find out the best way/most effective way to tune honda i-vtec powerplant, to be specific k24a. Is it via direct ecu tuning, piggyback, vtec controllers, etc? what kind of performance improvement can be expected? ↡ Advertisement Link to post Share on other sites More sharing options...
Minikong 1st Gear April 15, 2011 Share April 15, 2011 hmm just install 2 turbo, or a twin scroll turbo, the performance will be much better Link to post Share on other sites More sharing options...
Melvyn Neutral Newbie April 15, 2011 Share April 15, 2011 (edited) Largely depends on how much control you prefer as well as your budget. Flashpro would be a good start from overwriting values in the ECU all the way to Motec M400 which alters the signals to control the 4 cylinders. There's of course M880 but we dun need that since its for control up to 12 cylinders. Head on over to http://www.k20a.org/ and there's plenty of resources we have for you to tap on. Search for a guy nicknamed Nikos and check out his K24A build. You'll have a rough gauge of the stuff he's got packing and the horses he's putting down Edited April 15, 2011 by Melvyn Link to post Share on other sites More sharing options...
Aeromania 1st Gear April 15, 2011 Share April 15, 2011 u may want to post ur thread at shc forum. All the Honda brothers hang around there one. Link to post Share on other sites More sharing options...
Num3ga Neutral Newbie April 16, 2011 Share April 16, 2011 i Vtec has several stages of Vtec engagement compared to the Legendary Big brother B Series. If you are on a budget the apexi neo or Vafc 2 is more then enough to fine tune i-vtec. The piggy back is able to alter the A/F ratio for fuel that is set from the factory settings which is usually very rich to optimum savings for power and better F/C to Power and the vtec engagement points. The non scamming tuner/workshop will also need to dyno to find the right engagements points. For example when tuning a b/d series vtec. The piggy back must be programmed to engage vtec at a later time like 9k rpm and manual WOT on the dyno to find the settings/map where the non vtec lube drops in power . That will the mark to set the vtec to engage to get the max h.p for tuning the vafc for vtec. If this is done correctly when vtec kicks in in a b series you'll see that the rpm jumps from between 5k or when Vtec is engaged to 9k in nano secs!!!! Perfect!!!. I've driven a correctly tuned B series that i can still wheel spin from 4th to 5th gear. I know i left my balls at the pavement somewhere since 2nd to 3rd gear already.... Thus tuning the i-vtec has different stages to go thru.Good luck in your quest for extracting the k series power.If u have a budget get cams,springs and valves. Link to post Share on other sites More sharing options...
Renegade777 5th Gear April 16, 2011 Share April 16, 2011 i Vtec has several stages of Vtec engagement compared to the Legendary Big brother B Series. If you are on a budget the apexi neo or Vafc 2 is more then enough to fine tune i-vtec. The piggy back is able to alter the A/F ratio for fuel that is set from the factory settings which is usually very rich to optimum savings for power and better F/C to Power and the vtec engagement points. The non scamming tuner/workshop will also need to dyno to find the right engagements points. For example when tuning a b/d series vtec. The piggy back must be programmed to engage vtec at a later time like 9k rpm and manual WOT on the dyno to find the settings/map where the non vtec lube drops in power . That will the mark to set the vtec to engage to get the max h.p for tuning the vafc for vtec. If this is done correctly when vtec kicks in in a b series you'll see that the rpm jumps from between 5k or when Vtec is engaged to 9k in nano secs!!!! Perfect!!!. I've driven a correctly tuned B series that i can still wheel spin from 4th to 5th gear. I know i left my balls at the pavement somewhere since 2nd to 3rd gear already.... Thus tuning the i-vtec has different stages to go thru.Good luck in your quest for extracting the k series power.If u have a budget get cams,springs and valves. Wa ! Sure ? 4th to 5th gear can wheel spin. What kinda powder is that ? Link to post Share on other sites More sharing options...
Aaron_soh80 1st Gear April 16, 2011 Share April 16, 2011 Wa ! Sure ? 4th to 5th gear can wheel spin. What kinda powder is that ? The power of dream.. Link to post Share on other sites More sharing options...
Mrkiasume Neutral Newbie April 16, 2011 Share April 16, 2011 The power of dream.. lol. whose dream is that? megamind uh? 4th to 5th can have wheelspin. means is either you got a VERY close gear ratio box. or you have insane amounts of torque. which is probably not very realistic. the only cars in the world which i know MIGHT be able to do it are the F1 cars. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear April 16, 2011 Share April 16, 2011 Hondata, which is a tunable Honda ECU in effect. Link to post Share on other sites More sharing options...
Djdp Clutched April 17, 2011 Share April 17, 2011 Would like to find out the best way/most effective way to tune honda i-vtec powerplant, to be specific k24a. Is it via direct ecu tuning, piggyback, vtec controllers, etc? what kind of performance improvement can be expected? the usual hondata lor. but dun expect big difference there as in big jump in numbers. if jus do tunning only, i think best is to expect better drivability. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear April 17, 2011 Share April 17, 2011 Sorry to hijack. Can my Honda jazz engine be tuned for more power? Link to post Share on other sites More sharing options...
Lanevomax 1st Gear April 17, 2011 Share April 17, 2011 more power = higher fuel consumption. hope you guys know what you are doing..... no such thing like low FC , high power..... Link to post Share on other sites More sharing options...
Davidklt Supercharged April 17, 2011 Share April 17, 2011 wanna install turbo might as well get those TCed cars in the first place. hmm just install 2 turbo, or a twin scroll turbo, the performance will be much better Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear April 17, 2011 Share April 17, 2011 can u control the car in the first place or not... no point mod the car until it was too powerful for u to control... then end up in accident.. beside power... also got to consider the control (brake, suspension) Link to post Share on other sites More sharing options...
Jfamily Neutral Newbie April 18, 2011 Share April 18, 2011 bro, honda slogan is power of dreams Link to post Share on other sites More sharing options...
F1fan Neutral Newbie April 19, 2011 Author Share April 19, 2011 i am on a budget, so will probably start with VAFC 2 or NEO. Where is a good place to buy this plus have expertise to tune for i-vtec engines? Link to post Share on other sites More sharing options...
Chelsea901 1st Gear April 19, 2011 Share April 19, 2011 bro, honda slogan is power of dreams lol, honda alot of dreams, but he only gt 1 dream. Link to post Share on other sites More sharing options...
Gmbh Neutral Newbie April 21, 2011 Share April 21, 2011 Try to check out honda tunning website they hava alot of info for you. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
2020 5th Generation Honda City
RS Chip Tuning
RS Chip Tuning
