Quantum 5th Gear April 29, 2011 Share April 29, 2011 Hi All, My relative now is at Pulau Tekong BMTC, but he is difficult to pass the chin-up test can anyone how to achive the goal tks alot ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 29, 2011 Share April 29, 2011 Hi All, My relative now is at Pulau Tekong BMTC, but he is difficult to pass the chin-up test can anyone how to achive the goal tks alot I believe, first he must not be overweight like me (did two chin-up only) Link to post Share on other sites More sharing options...
Quantum 5th Gear April 29, 2011 Author Share April 29, 2011 I believe, first he must not be overweight like me (did two chin-up only) shdn't be overweight, 1.8m/70kg, struggling only two Link to post Share on other sites More sharing options...
Antonee 6th Gear April 29, 2011 Share April 29, 2011 i worst ...me 58 kg , can only do 1 chin up Link to post Share on other sites More sharing options...
Nicz Clutched April 29, 2011 Share April 29, 2011 Do sports that utilises the same muscles as chin-ups. eg. sport climbing. Extremely effective. Been there done that. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear April 29, 2011 Share April 29, 2011 do push ups. trains your arm muscles Link to post Share on other sites More sharing options...
Tianmo Hypersonic April 29, 2011 Share April 29, 2011 Hi All, My relative now is at Pulau Tekong BMTC, but he is difficult to pass the chin-up test can anyone how to achive the goal tks alot do sit ups, push ups and back pusk ups using the sofa or chairs..............ask him to use under grip, it is easier to pull himself up and uses more of the arm, the over grip uses both the arm and shoulder. pull up also use the mid section of the body, so do some sit ups. And do a few pull ups at the bar when ever he got the chance, even if it is 2 or 3 each time, get the body to get use to the pulling up effect, and once in a while go to the max. Once he is comfortable, go for the max each time he hit the bar. I did 15 when I was enlisted, now over 40 still can do abt 8. good luck to your relative. Link to post Share on other sites More sharing options...
Tianmo Hypersonic April 29, 2011 Share April 29, 2011 shdn't be overweight, 1.8m/70kg, struggling only two 1.8m/70kg i think is under weight leh..........I think his arm and shoulder is not strong enough. he need to also learn the vertical wave up, but not swinging, that way can save some energy. Link to post Share on other sites More sharing options...
Chrispie 5th Gear April 29, 2011 Share April 29, 2011 Hi All, My relative now is at Pulau Tekong BMTC, but he is difficult to pass the chin-up test can anyone how to achive the goal tks alot do lat pull downs... (machines) chin ups utilises biceps and the lats... so doing push ups actually doesnt help. Link to post Share on other sites More sharing options...
Whathefish 5th Gear April 29, 2011 Share April 29, 2011 start doing in sets of flex arm hang... 1) hang with chin over the bar as long as u can..then rest 30sec and do again 2) hang with your arms 90 degree (means head just slightly below the bar) as long as u can..then rest 30sec and do again keep doing sure can improve... Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 29, 2011 Share April 29, 2011 shdn't be overweight, 1.8m/70kg, struggling only two Any previous medical issue or injury? Link to post Share on other sites More sharing options...
Quantum 5th Gear April 29, 2011 Author Share April 29, 2011 Any previous medical issue or injury? no lah Link to post Share on other sites More sharing options...
Ptc77 Neutral Newbie April 29, 2011 Share April 29, 2011 Hang on to the bar. Let his arm get use to his body weight. Very siong initially , once a week or two, he should be alrite. Of course, must lost weight to make job easier.. Link to post Share on other sites More sharing options...
Josho 1st Gear April 29, 2011 Share April 29, 2011 Hang on to the bar. Let his arm get use to his body weight. Very siong initially , once a week or two, he should be alrite. Of course, must lost weight to make job easier.. agree w u. that one is important before starting to do other exercise on arm Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear April 29, 2011 Share April 29, 2011 As long as he can do two pull-ups, then can consider this technique. Use the under grip. Go to the bar, do one pull-up the hang there for 30 secs (heads above the bar). Then slowly release until until arms are 45deg to the bar (eye should be level with the bar). Again hold for 30 secs. The finally release totally n just hang from the bar with arms straightened. Again hang for another 30 secs. Then dismount n rest for 1min. Then do another 2 more reps. Hang time can increase as resistance level improves. Do this every night for two weeks n should be able to do more pull ups after that. Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 29, 2011 Share April 29, 2011 do sit ups, push ups and back pusk ups using the sofa or chairs..............ask him to use under grip, it is easier to pull himself up and uses more of the arm, the over grip uses both the arm and shoulder. pull up also use the mid section of the body, so do some sit ups. And do a few pull ups at the bar when ever he got the chance, even if it is 2 or 3 each time, get the body to get use to the pulling up effect, and once in a while go to the max. Once he is comfortable, go for the max each time he hit the bar. I did 15 when I was enlisted, now over 40 still can do abt 8. good luck to your relative. NB! How lian! Enlisted I still beat you, now past 40 I also still beat you. [laugh] Link to post Share on other sites More sharing options...
Ender Hypersonic April 29, 2011 Share April 29, 2011 Just do more chin up. I improved just by doing that. Got myself a door mount chip up bar. For a period when I was training, I did it alternate days, but a few set a day.. Slowly increase from 4 to 11, proper one. Now a bit lazy and don't do it often, drop to 8 or 9. I think the bicep curl also helps.. Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 29, 2011 Share April 29, 2011 no lah It's not going to be a overnight thing, progressive. he needs to keep training, resting training. roughly round 3-4 weeks, he should be able to pull himself up, proper, 3-4 pulls. ↡ Advertisement Link to post Share on other sites More sharing options...
Scenic Train Rides in China (Especially to Lhasa)
South East Asia's 1st Bullet Train Ready Next Year June
India train derails, at least 119 killed
SDCF Trial - Death of Kok Yuen Chin
Taiwan Train derailment - 50 dead
KTMB Train From Woodlands CIQ To JB Sentral
Yokohama Train crash with Truck
