Shor 1st Gear May 15, 2011 Share May 15, 2011 Any bro/sis know any shop that do cheap alignment. Motogard charge $42.80 for a simple alignment. Any imput will be appreciate. ↡ Advertisement Link to post Share on other sites More sharing options...
Aaron_soh80 1st Gear May 15, 2011 Share May 15, 2011 Any bro/sis know any shop that do cheap alignment. Motogard charge $42.80 for a simple alignment. Any imput will be appreciate. The most cheap i heard is $50.. urs consider cheap already..i wonder still got below $42.80? funny price.. Link to post Share on other sites More sharing options...
Ken4555 1st Gear May 15, 2011 Share May 15, 2011 i did mine at JB for RM$25... at permays jaya the tyre plc called Beezz or smthing... but no explanation of anything i had to stand by the side and look at the toe adjustments to make sure correct... and then when he took out to test drive the road so rocky and sandy... dont know how accurate the adjustments... but car felt straight ok lor... and so cheap... like S$11-12 haha Link to post Share on other sites More sharing options...
Ken4555 1st Gear May 15, 2011 Share May 15, 2011 Any bro/sis know any shop that do cheap alignment. Motogard charge $42.80 for a simple alignment. Any imput will be appreciate. standard price outside is about $50... think some places maybe cheaper abit if you buy tyres from them... anyways just to let you know most of the time there is no way to make the car 100% straight.... Link to post Share on other sites More sharing options...
Shor 1st Gear May 15, 2011 Author Share May 15, 2011 Thanks bro, so assuming tyre balance will be fine enough already. I did my alignment before I change my tyre, so happen that decide to change tyre last minute. standard price outside is about $50... think some places maybe cheaper abit if you buy tyres from them... anyways just to let you know most of the time there is no way to make the car 100% straight.... Link to post Share on other sites More sharing options...
Ken4555 1st Gear May 15, 2011 Share May 15, 2011 Thanks bro, so assuming tyre balance will be fine enough already. I did my alignment before I change my tyre, so happen that decide to change tyre last minute. i balance my tyres everytime i rotate them at 10k intervals... alignment will not go off just by changing tyres... i did my alignment went off when i bought new suspensions... then also when i service/adjust height/camber of my suspension... also when i changed 4 new tyres... other then that no reason to adjust alignment unless accident... touch wood.. Link to post Share on other sites More sharing options...
Shor 1st Gear May 15, 2011 Author Share May 15, 2011 Changed my 4 tires and felt that it slightly left, so was wondering whether this due to the alignment or balancing as I just did my alignment checked before replacing this 4 new tires. i balance my tyres everytime i rotate them at 10k intervals... alignment will not go off just by changing tyres... i did my alignment went off when i bought new suspensions... then also when i service/adjust height/camber of my suspension... also when i changed 4 new tyres... other then that no reason to adjust alignment unless accident... touch wood.. Link to post Share on other sites More sharing options...
13177 Hypersonic May 15, 2011 Share May 15, 2011 Car alignment in sg will never cheap. The cheapest i heard is ard $50, some even cost $70! Only wheel rotation is consider price reasonable in sg. If u want cheap car alignment, the only place to go is JB. Link to post Share on other sites More sharing options...
Ken4555 1st Gear May 15, 2011 Share May 15, 2011 Changed my 4 tires and felt that it slightly left, so was wondering whether this due to the alignment or balancing as I just did my alignment checked before replacing this 4 new tires. pulling left is normal... provided it goes gently left after straight for a while... if immediately left when you let go then pls visit Kenny Alignment at AMK autopoint... he will explain to you all there is to know... should $60 or $50 depending on your car... Link to post Share on other sites More sharing options...
Mona-vie 1st Gear May 15, 2011 Share May 15, 2011 Why don't you go autobacs instead? Its not worth saving that bit of money. Most important is getting alignment done correctly and properly. Autobacs has the equipment to do the job. Link to post Share on other sites More sharing options...
Shor 1st Gear May 15, 2011 Author Share May 15, 2011 Yes bro, gently left!! Thanks! pulling left is normal... provided it goes gently left after straight for a while... if immediately left when you let go then pls visit Kenny Alignment at AMK autopoint... he will explain to you all there is to know... should $60 or $50 depending on your car... Link to post Share on other sites More sharing options...
Shor 1st Gear May 15, 2011 Author Share May 15, 2011 Not means to save this little money but I did alignment just 3 days before I change tire. Thanks for the advice though! Why don't you go autobacs instead? Its not worth saving that bit of money. Most important is getting alignment done correctly and properly. Autobacs has the equipment to do the job. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 15, 2011 Share May 15, 2011 go jb n do.. around rm 30 i think Link to post Share on other sites More sharing options...
D3badge 6th Gear May 15, 2011 Share May 15, 2011 The most cheap i heard is $50.. urs consider cheap already..i wonder still got below $42.80? funny price.. $40+GST Link to post Share on other sites More sharing options...
Shor 1st Gear May 15, 2011 Author Share May 15, 2011 Yes bro, as simple as that , not funny at all right? $40+GST Link to post Share on other sites More sharing options...
KkMICHELIN Neutral Newbie May 15, 2011 Share May 15, 2011 Go JB --- only RM25 and good service! Link to post Share on other sites More sharing options...
Shor 1st Gear May 15, 2011 Author Share May 15, 2011 Thanks br, many ppl recommend go JB, can PM me any shop you know? Go JB --- only RM25 and good service! Link to post Share on other sites More sharing options...
KaKiLang 4th Gear May 15, 2011 Share May 15, 2011 Gradual left is ok, cos our roads are not totally flat, for water drainage. To test your alignment, your car have to travel straight when you let go your steering wheels, hit on the brakes gradually if your car slow on a straight line your alignment still good. Towards Tampoi one shop along BAPOK LANE where theres a row of motorbike shops, at the end after ESSO, a shell station, diagonally opposite TAN CHONG or FIRE STATION (alot of Agua in the nite). Shop located inside tat small shell station, look for AH ZHUN, alignment really zhun zhun. 30RM ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Jun 2026
Total asset vs car price affordability
Petrol Discounts in Singapore
Xiaomi EV is Coming
Xiaomi EV is Coming
New car discount/price/promo
