Red Coolant
Sins
Hi all,
I need to buy red engine coolant. Anyone knows which brand comes in red? Many thanks.
Hi all,
Wat is so special about red coolant huh......???
Apparently there is a difference in the property between red and green. It is for my bike which requires red.
You are saying for your bike, but this fluid is more car. Its premix (dont have to dilute with water) "anti freeze, anti rust long life coolant" and comes in 3.785L bottle. But I guess will work for any engine.
Hi all,
Ziko Coolant by Topfuel
You need to get Maxima Cool-Aide Coolant for your bike.
Mah MotorParts
19 Jln Besar Singapore 208792
Tel: 6293 3841
Mustafa
Mustafa Centre
145 Syed Alwi Road
Singapore 207704
i suggest that you do not go just by colour.
it is best to use exactly the same brand.
if unsure, best is to flush out completely and change.
there's a thread somewhere on this forum that goes into details... with lots of info from Bro Genie47. do a search, u'll be rewarded.
Told many years back, a certain car brand had used a dedicated coolant for their engine. Due to ignorance or ortherwise, Owners/workshops replenished with water for one reason or another later. The water dissolved the gasket and the respective engines had to be overhauled for the damages.
It is good to know what is going on before some serious damages caused by ignorance.
So far the two main types of coolants I've seen are red (anti-freeze) and green (anti-rust).
I don't think SG/MY has any possibility of freezing over, so I just stick to green lol
mine is blue leh, so its anti-what?
Looks like you did not bother to google for info. Try to get them right before putting up your views. This subject has been discuss in this forum more than 101 times. The anti-freeze ( don't be mislead by the name) glycol if correctly mixes with distilled water not only helps to reduce freezing temp to as low as -37deg C but also bring boiling point up to 135 deg C.
Edited by Yeobh
Hypersonic
Don't mislead people leh.
There's also a pink coolant for VW. So how? Is it anti-boil then? [rolleyes]
