Pltang Clutched August 7, 2011 Share August 7, 2011 Not sure if i read it wrong, but i was given a $3 complimentary per entry carpark ticket, but was charged $6 at exit. Cashcard was deducted $3. so am i charge wrongly or assume they printed wrongly on the ticket? Carpark charges: $3.50 for 1st hr, $1.50 for next subsequent 1/2hr from 7am to 9pm ↡ Advertisement Link to post Share on other sites More sharing options...
Jefkking Clutched August 7, 2011 Share August 7, 2011 (edited) Most likely, you had fully inserted your Cashcard into the IU prior to exit and that's why amount was deducted from your Cashcard value thru IU. You should have remove your Cashcard prior to exit / inserting the Complimentary ticket into the EPS systems. Edited August 7, 2011 by Jefkking Link to post Share on other sites More sharing options...
Friendstar Supercharged August 7, 2011 Share August 7, 2011 Not sure if i read it wrong, but i was given a $3 complimentary per entry carpark ticket, but was charged $6 at exit. Cashcard was deducted $3. so am i charge wrongly or assume they printed wrongly on the ticket? Carpark charges: $3.50 for 1st hr, $1.50 for next subsequent 1/2hr from 7am to 9pm errr 6 minus 3 = 3 right? Link to post Share on other sites More sharing options...
Pltang Clutched August 7, 2011 Author Share August 7, 2011 so $3 per entry doesn't mean per entry but means minus $3 from total? Link to post Share on other sites More sharing options...
Pltang Clutched August 7, 2011 Author Share August 7, 2011 Most likely, you had fully inserted your Cashcard into the IU prior to exit and that's why amount was deducted from your Cashcard value thru IU. You should have remove your Cashcard prior to exit / inserting the Complimentary ticket into the EPS systems. my cashcard was removed and i was charged a total of $6 excluding that $3 per entry tix..... Link to post Share on other sites More sharing options...
Nzy Twincharged August 8, 2011 Share August 8, 2011 Last time got one card like this from thomson medical centre also. I think it means you have to pay $3 to park there. No matter how long you park. So your cashcard got deducted $3 is correct. Link to post Share on other sites More sharing options...
Darthrevan Supercharged August 8, 2011 Share August 8, 2011 example u go Mandarin Gallery..the per entry charge is $6..but the concierge gave u a $3 complimentary ticket..so the charges is still $3 Link to post Share on other sites More sharing options...
Dafansu Turbocharged August 8, 2011 Share August 8, 2011 so $3 per entry doesn't mean per entry but means minus $3 from total? If no limit they won't put in the $3. Whats your parking time Link to post Share on other sites More sharing options...
Ultramega 1st Gear August 9, 2011 Share August 9, 2011 Not sure if i read it wrong, but i was given a $3 complimentary per entry carpark ticket, but was charged $6 at exit. Cashcard was deducted $3. so am i charge wrongly or assume they printed wrongly on the ticket? Carpark charges: $3.50 for 1st hr, $1.50 for next subsequent 1/2hr from 7am to 9pm This is an English problem and not a maths problem... "$3 complimentary per entry" means they give u a discount of $3. If you want 100% free, u need to find a ticket that says "Complimentary Parking". Link to post Share on other sites More sharing options...
Pltang Clutched August 9, 2011 Author Share August 9, 2011 If no limit they won't put in the $3. Whats your parking time 45min Link to post Share on other sites More sharing options...
Dafansu Turbocharged August 9, 2011 Share August 9, 2011 45min 45min should be $3.50 right, which car park is it Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 9, 2011 Share August 9, 2011 Not sure if i read it wrong, but i was given a $3 complimentary per entry carpark ticket, but was charged $6 at exit. Cashcard was deducted $3. so am i charge wrongly or assume they printed wrongly on the ticket? Carpark charges: $3.50 for 1st hr, $1.50 for next subsequent 1/2hr from 7am to 9pm Did u follow the instructions on the ticket? Usually it says to remove yr cashcard b4 u near the gantry. Then u slot in the ticket n Wallah, the barrier wil open. Link to post Share on other sites More sharing options...
Timex1441 1st Gear August 9, 2011 Share August 9, 2011 juz a guess, maybe the $6 is a combination of rate parking and per-entry parking?....e.g. if per entry parking is $3, but u parked for 1 hr b4 the per-entry timing starts, then u incur charges for tat 1 hr of parking AND the per-entry parking charge. ↡ Advertisement Link to post Share on other sites More sharing options...
Barrier arms raised at carpark gantries in 500 HDB estates following ‘technical difficulties’
MBS Carpark
MBS Carpark
Season Parking Around CBD - Inquiries / Buy / Sell
Carpark Gantry Cheats
EPS car park gantry - no entry record
Fire breaks out at Singapore's Golden Mile Tower
