Rubberstamp Neutral Newbie November 27, 2011 Share November 27, 2011 (edited) i know nothing about speaker cables. can anyone recommend me a reasonably good speaker cable? i need to connect my front standing speakers to my amp (home entertainment system - not car). maybe budget less than $20 per meter? and where to buy? thanks Edited November 27, 2011 by Rubberstamp ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 27, 2011 Share November 27, 2011 I suggest you open up your amp to see the cable that is used to connect to the red and black speaker connector post. Do the same for your speakers. If both use good quality cables, then you should also invest in a good cable. If what you see are just cheapo cables inside your amp and speakers......then those freebies speaker cables that comes with budget mini-compo system will be sufficient. Speakers cables are over rated. What you need to ensure is that the connector post are able to have a secure clamping on the bare wires to transmit the analog electric voltage from amp to speakers. Link to post Share on other sites More sharing options...
Quaky Neutral Newbie November 27, 2011 Share November 27, 2011 u would not go too far wrong with belden cables....go to SIM LIM Tower...LHS.... Link to post Share on other sites More sharing options...
Rubberstamp Neutral Newbie November 27, 2011 Author Share November 27, 2011 u would not go too far wrong with belden cables....go to SIM LIM Tower...LHS.... thanks... how much are these belden cables? i heard of it.. dun want to be carrot at sim lim towers Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear November 27, 2011 Share November 27, 2011 Hey bro rubberstamp, Does your floorstanders allow bi-wire? Bi-wiring is best way to bring out the sonic qualities of your speakers. Beldens r really stiff cables.... But they r quite transparent so they don't "cloud" your system. Plus they r inexpensive so it's quite good value for $$. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 27, 2011 Share November 27, 2011 I would say those 'see thru', OFC cables sold at Harvey or DIY shop is good enough for me. My ears are not tuned to listen to High Crass music. Link to post Share on other sites More sharing options...
Josho 1st Gear November 27, 2011 Share November 27, 2011 (edited) As Rex mentioned: Belden. Belden is commonly used for industrial AV system, hence people trust that with heart. It is inexpensive as well. LHS @ Sim Lim Tower - my company often bought drums of cables from them.. ranging from Cat 6 to AV system. For 2 core - Speaker cable Jacketed, zip, unjacketed plenum 12 AWG 8477, 9718, 1860A For 4 core (allow you to do Bi-Amp) - Bi-amp speaker cable Wiring dual-amplifier driven speakers 1810A Info: http://www.belden.com/pdfs/Techpprs/bavcadtp.pdf Edited November 27, 2011 by Josho Link to post Share on other sites More sharing options...
5936 1st Gear November 28, 2011 Share November 28, 2011 Consider both listening environment and AV equipment before getting the cables. For an ordinary set up, normal OFC cables or even the red/black cables is good enough. Save your money for something else ↡ Advertisement Link to post Share on other sites More sharing options...
Speaker Tan Chuan-Jin, MP Cheng Li Hui resign
Anyone watches MMA?
Anyone watches MMA?
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Green fingers anyone?
