Which tyre?
Mllcg
Btw re002 for 15" cost $140+
Someone say u drive a wrx ?
So it stock 16 or upgrade 17?
With a budget of $150
For 16 , I think only choice is ku36.
17 no performance tyres for u.
If u downgrade to 15"
U buy the wrong car.
S$ 150 for RE ? Not possible !
17 inch.
my current RE001 bought for 120/pce.
if i up to $200/tyre, what can i get?
performance tyres.
but cannot be low profile or i will get murdered my my family.
Edited by Mllcg
When you said Performance tires, you have to be careful, because most high track focus performance tires compromised in the wet. As for a tires to be good in the rain, it has to have more grooves for water channeling, & more groove is less rubber, hence affect max performance in the dry. Hence the Ultra performance tires have very little grooves, good in darym, bad in wet. Just compare the rain & slick tires in F1.
Not to mention high wear rate.
I quote my own example. When I was looking for tires for my old ride. AT first I looked at the Ultra performance grade, like Dunlop S1 star, RE11 and R888. But after careful study, & research on the net, like looking up Tirerack.com, I eventually pick up the Goodyear Asymmetric F1 summer tires, as they have good track performance (1 grade down from the Ultra Performance grad), but much slower wear rate, & better in the rain.
If you wanted serious lap times for track, & a good tires for daily, its better to have 2 sets of tires (or wheels), otherwise, I personally don't recommended Ultra performance grade as the only options.
Performance tyres catalogue
1.Extreme performance (re11,rs3,rsr,ku36,z1,888,ad08 etc)
2. Max performance ( sport maxx tt, re001,)
3.ultra high performance ( t1r,ps3,csc3)
4. High performance
1&2 tyres, gd dry grip ,wear rate below 200, they dun care abt wet.
3 onward, they mix wet n dry handling n comfort . N hv nice wear rate.
17 inch.
performance tyres.
Last check 3 weeks ago re002 @ $142 (15")
How can 17" @re001 $120 only.
17" is 225?
Rs3 @ $240
Rsr @ $250
Ku36 n z1 star should be ard 200 range.
But I can't find any of them for 17" 225/45. 3 weeks ago.
Rs3 n rsr cfm got stock.
High profile will be more exp right?
Yoko S drive!
Not very good for performance vehicle. Sdrive is slightly above your average family type tyre imo.
Re55s is not street legal...
Yea but I'm suggesting they're sort of similiar. Wear wouldnt be good so probably not recommended as a daily. Same goes to AD08.
4. High performance
I would put re001 at (3) though. I dont find them very grippy.
F1 is a good compromise too. I would definitely recommend ps2 (or super sport now), re050a and f1. They're probably the best compromise in terms of dry/wet grip and durability.
Why would u say potenza S001 is a comfort tyre?
I agree with cdior. S001 is in the same range as RE002. Can refer to BS website and also confirmed by tyre shop.
I just bought KU36 215/45R17. $175 each. 225 no stock.
Value for money IMO.
how about those that are good in both wet and dry?
what models?
i wont pay more than 1k/set. thats the max i will pay
17 inch high profile tyres
Edited by Mllcg
4. High performance
can someone help me to understand how to read wear rate? is it that the higher the number, the longer it can last? if so, what is the max reading?
Of course, the higher the wear rate the better; 100 being the lowest standard for all tyres.
However, wear rate varies from manufacturer to manufacturer. A 400 wear rate for a certain brand can be equivalent to a 300 wear rate for another brand.
Thanks for explaining. That means this rating is quite useless. Btw,can i find this rating on the tire wall?
It depends on the preference of the reviewer.
One practical issue with most reviews is that the tyres are tested when new, and not over a long period of usage. For myself, I don't like tyres with soft sidewall as I like tyres with sharp steering response (and hence I choose tyre with stiff sidewalls).
One man's meat is another man's poison. PS3 and CSC3 are highly rated in many automotives magazine reviews
If you change tyres at 40k/2 years, it should not matter unless your are using RE070 (need to change at 30k). I've used max perf tyres for the last 10-11 years, and they can last me till 40k without problems.
Well, it's not really useless. The rating can be used as a comparison between tyres from the same manufacturer.
Yes, the UTQG rating can be found on every tyre sidewall.
The threadwear rating comes first, followed by traction and temperature rating (eg. 400 A A)
Ok. Tks. Do you happen to know what is the rating on RE-11?
