QQDreamer 4th Gear March 5, 2012 Share March 5, 2012 (edited) As above, any bros here into ICE can advise? Active subwoofer better or Box up type Subwoofer better? There are pros and cons of both type . Would like to learn from the ICE bros here. Pls kindly advise. Edited March 5, 2012 by MkMan ↡ Advertisement Link to post Share on other sites More sharing options...
Vertigoer Neutral Newbie March 5, 2012 Share March 5, 2012 As above, any bros here into ICE can advise? Active subwoofer better or Box up type Subwoofer better? There are pros and cons of both type . Would like to learn from the ICE bros here. Pls kindly advise. Are you referring to those under seat subwoofer vs subwoofer in the boot? Because both are active. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear March 5, 2012 Share March 5, 2012 (edited) Box type you can have a bigger woofer like 30cm diameter type or larger. Also you can match it with a higher power amplifier for better low end BOOM BOOM BOOM. Active type usually are having smaller woofer, <20cm diameter. And the amplifier power is usually not high. So the base usually sound like Thud Thud Thud type. Of course small cars can install two active type under the front seats to get satisfactory bass and vibration. If got budget can even install four active woofer that is well hidden, without sacrificing boot space. It's always space vs sound quality compromised. Edited March 5, 2012 by SimonTan Link to post Share on other sites More sharing options...
SimonTan 2nd Gear March 5, 2012 Share March 5, 2012 Active means = packaged into one unit, with inbuilt amplifier circuits. Link to post Share on other sites More sharing options...
Kurty Supercharged March 5, 2012 Share March 5, 2012 Box type you can have a bigger woofer like 30cm diameter type or larger. Also you can match it with a higher power amplifier for better low end BOOM BOOM BOOM. Active type usually are having smaller woofer, <20cm diameter. And the amplifier power is usually not high. So the base usually sound like Thud Thud Thud type. Of course small cars can install two active type under the front seats to get satisfactory bass and vibration. If got budget can even install four active woofer that is well hidden, without sacrificing boot space. It's always space vs sound quality compromised. wah, 2 under the front seats.. i only using one.. go for reputable makes like pioneer. slightly expensive but worth every thump. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear March 5, 2012 Share March 5, 2012 The problem with large woofer bass is that you need a strong amplifier. I installed a 500RMS Punch amplifier to drive my woofer box. The sound is great with a fully charged and new battery. But after 1.5 years, my battery is weak. And is not able to deliver enough ampere to power the amplifier anymore. The headlights will flickers with the bass sound. Thinking of install a separate battery to support powerful bass. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged March 5, 2012 Share March 5, 2012 (edited) go for focal active if space constraint - but cost 600+. the bass sounds as strong & tight as amp-driven type, even w doors opened u can still hear boom boom from outside. Edited March 5, 2012 by Fuelsaver Link to post Share on other sites More sharing options...
SimonTan 2nd Gear March 5, 2012 Share March 5, 2012 Most are OEM, all looks the same, some even different brand but exactly same unit. So steelmate or whatever cheap brand is good enough. Another important point is the music source must also be good. Many of my MP3 music has a weird phenomen, the bass frequency will fluctuate with the vocals. Can clearly hear the bass inconsistency with the vocals on/off. The MP3 encoding is messing up the bass level in many of my iPod music. wah, 2 under the front seats.. i only using one.. go for reputable makes like pioneer. slightly expensive but worth every thump. Link to post Share on other sites More sharing options...
Vertigoer Neutral Newbie March 5, 2012 Share March 5, 2012 go for focal active if space constraint - but cost 600+. the bass sounds as strong & tight as amp-driven type, even w doors opened u can still hear boom boom from outside. It's not about boom boom noise. It's about the low frequency reverb that trembles the whole car :) Think good side speakers 6.5' with sound proofing and Amp can do much better than Active sub. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear March 5, 2012 Author Share March 5, 2012 Are you referring to those under seat subwoofer vs subwoofer in the boot? Because both are active. Yes thats what i mean. Any advise? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear March 5, 2012 Author Share March 5, 2012 wah, 2 under the front seats.. i only using one.. go for reputable makes like pioneer. slightly expensive but worth every thump. bro you using pioneer active sub? How is the review? sound quality how is it? What is the damage like? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear March 5, 2012 Author Share March 5, 2012 go for focal active if space constraint - but cost 600+. the bass sounds as strong & tight as amp-driven type, even w doors opened u can still hear boom boom from outside. Are you referring to box up type or active sub woofer ? Link to post Share on other sites More sharing options...
5936 1st Gear March 5, 2012 Share March 5, 2012 I am using the kenwood active under seat sub-woofer. a very compact, 6" diameter speaker, but without the tud plastic sound. In my previous sedan, I just install a pair of 6*9" boston acustics woofers, at back of rear seat, and the bass sound is deep enough for me. Link to post Share on other sites More sharing options...
Dunno Neutral Newbie March 5, 2012 Share March 5, 2012 How low do you want the music to go? Underseat subs can't play low notes. Force it and you get boomy bass. Boxed 12" sub driven by an amp will be able to play low. I don't thump with my sub, it just messes up the whole music enjoyment. The attack of the thump is done by my 6.5" midbass, followed by the decay of the thump by my sub. The handshake of both is important. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged March 5, 2012 Share March 5, 2012 (edited) Are you referring to box up type or active sub woofer ? active underseat / underglove sub by focal, see feedback below http://www.civicfd-sg.com/viewtopic.php?t=...859149263195053 http://www.focal.com/en/car-audio-sound/su...ers/ibus-20.php what i've heard was the ibus 20 fitted on a bmw 5-series mounted under glove compartment; very solid build, heavy & very tight bass. but at 600+, some may consider amp box? Edited March 5, 2012 by Fuelsaver Link to post Share on other sites More sharing options...
SimonTan 2nd Gear March 5, 2012 Share March 5, 2012 The SB20BUS from Focal, looks so generic like a steelmate or OEM built. Just get two units, from simlim, and hook it up to the woofer output of your HU. Good enough sound level to shake the whole car. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged March 6, 2012 Share March 6, 2012 (edited) The SB20BUS from Focal, looks so generic like a steelmate or OEM built. Just get two units, from simlim, and hook it up to the woofer output of your HU. Good enough sound level to shake the whole car. so who copy who... get the iBUS man... Edited March 6, 2012 by Fuelsaver Link to post Share on other sites More sharing options...
QQDreamer 4th Gear March 6, 2012 Author Share March 6, 2012 er.. so which is good? havent get my answer from experience bros here yet [:p] ↡ Advertisement Link to post Share on other sites More sharing options...
Is a subwoofer necessary?
What type of car air freshener ?
Laundry Drying system - Pull-down/Push-up type
Save up to $100 on the Brand New Sony XS-AW8 Compact Powered Subwoofer
Which 10" boxed subwoofer to get?
Recommend under seat active sub
