Deckbuild 6th Gear March 6, 2012 Share March 6, 2012 My battery is only around 1 yr 1 mth. early morning start is instant, but when I start it after stopping for 5 mins or when engine is warm. Is it the battery or ? ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear March 6, 2012 Share March 6, 2012 My battery is only around 1 yr 1 mth. early morning start is instant, but when I start it after stopping for 5 mins or when engine is warm. Is it the battery or ? The ignition system, like the ignition coil most likely faulty. Incorrect viscousity engine oil rarely the cause. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 6, 2012 Author Share March 6, 2012 The ignition system, like the ignition coil most likely faulty. Incorrect viscousity engine oil rarely the cause. Ignition coil faulty during hot engine only? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear March 6, 2012 Share March 6, 2012 Ignition coil faulty during hot engine only? Most common faulty ignition coil symptom Link to post Share on other sites More sharing options...
Trex101 3rd Gear March 6, 2012 Share March 6, 2012 My battery is only around 1 yr 1 mth. early morning start is instant, but when I start it after stopping for 5 mins or when engine is warm. Is it the battery or ? Most likely it's battery problem, if you are free just drop by our warehouse, we have a CCA battery tester that can diagnose if it's really the battery problem or something else. If not, just drop by any battery shop or tire shop, they will have the machine to test your battery condition. Link to post Share on other sites More sharing options...
Lowrider 2nd Gear March 7, 2012 Share March 7, 2012 (edited) My battery is only around 1 yr 1 mth. early morning start is instant, but when I start it after stopping for 5 mins or when engine is warm. Is it the battery or ? It must be fuel-related problem. It's been known vapor can form in fuel line when it gets very hot and this vapor blocks the fuel from igniting. You can solve it by wrapping the fuel line with heatshield where it's exposed to heat the most. Edited March 7, 2012 by Lowrider Link to post Share on other sites More sharing options...
Ikennyg Clutched March 7, 2012 Share March 7, 2012 Is your ride BMW 3 serial? My friend bimmer had this problem on and off too. Replace the 2 years old battery, ignition coil and starter motor but still can't solve the problem. The workshop also can't identify the problem. Eventually he sold the car. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 7, 2012 Author Share March 7, 2012 Is your ride BMW 3 serial? My friend bimmer had this problem on and off too. Replace the 2 years old battery, ignition coil and starter motor but still can't solve the problem. The workshop also can't identify the problem. Eventually he sold the car. 8.5 yr old Matrix. Still bearable for me, will go check the battery. Link to post Share on other sites More sharing options...
oomph Neutral Newbie March 7, 2012 Share March 7, 2012 just guessing - one of those sensors may be off: 02 sensor, exhaust gas recirculation valve, idle air control valve etc. from what I've read (about electronic control systems) they seem to do badly when things warm up. of course don't discount everything suggested above. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Spam calls starting from 31290xxx
