MacDuck 1st Gear March 9, 2012 Share March 9, 2012 Hi all. My car is coming to 5yrs old and the AC is getting noisy when it kicks in, I can also feel the vibration. AC is still blowing cold air and I change the filter every year. Was recommended to change/add aircon oil. AC system uses oil? Will the oil help? The workshop wants to charge $87 renewing aircon oil. ↡ Advertisement Link to post Share on other sites More sharing options...
IvanL Neutral Newbie March 9, 2012 Share March 9, 2012 have you tried using the air con uv dye treatment? my 5 year old latio sports had the same problem like yours. after my workshop inject the uv dye, it quieten down alot. $48 was the damage. Link to post Share on other sites More sharing options...
MacDuck 1st Gear March 9, 2012 Author Share March 9, 2012 have you tried using the air con uv dye treatment? my 5 year old latio sports had the same problem like yours. after my workshop inject the uv dye, it quieten down alot. $48 was the damage. I thought the UV dye is used to detect leaks instead? Link to post Share on other sites More sharing options...
Picanto 3rd Gear March 10, 2012 Share March 10, 2012 have you tried using the air con uv dye treatment? my 5 year old latio sports had the same problem like yours. after my workshop inject the uv dye, it quieten down alot. $48 was the damage. enough of your false info please Link to post Share on other sites More sharing options...
Picanto 3rd Gear March 10, 2012 Share March 10, 2012 I thought the UV dye is used to detect leaks instead? you are right, he is trying to mislead us Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 10, 2012 Share March 10, 2012 Hi all. My car is coming to 5yrs old and the AC is getting noisy when it kicks in, I can also feel the vibration. AC is still blowing cold air and I change the filter every year. Was recommended to change/add aircon oil. AC system uses oil? Will the oil help? The workshop wants to charge $87 renewing aircon oil. trusts me, it wont work. but whether it prolongs the life of the compressor, maybe........ Link to post Share on other sites More sharing options...
5936 1st Gear March 10, 2012 Share March 10, 2012 You can get mechanics to check magnetic clutch, and bearing. These 2 are the most common culprits. In sg wkspa, replacing the whole compressor is the norm. But in JB, they do replqce bearing and magnetic clutch, for less than a friction of the cost. And you can also replace the compressor oil. Link to post Share on other sites More sharing options...
Picanto 3rd Gear March 19, 2012 Share March 19, 2012 its better to replace the whole compressor. why? once you replace part A, then part b inside the compressor may spoil. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 19, 2012 Share March 19, 2012 with new comp selling at 400-500, maybe it is better to replace the whole thing Link to post Share on other sites More sharing options...
Briansoh 1st Gear March 19, 2012 Share March 19, 2012 Could it be your engine mounts? Each time the air con kicks in, the additional load would just cause the car to vibrate. Anyway my old car has the same problem with the compressor. Im just going to use it first since its still blowing cold air albeit being rather noisy when outside. If the compressor does die and stop spinning, my car would automatically detect it and disengage it from the drive belt so there wouldnt be any damage. Ive already gotten a good secondhand one to standby. Maybe you can go the same route and just save the money and wait. Link to post Share on other sites More sharing options...
5936 1st Gear March 20, 2012 Share March 20, 2012 Magnetic clutch and bearings are parts mounted on the external drive shaft of compressor. Usually with labour and parts at $100-$120. Link to post Share on other sites More sharing options...
Simpleonly 5th Gear March 31, 2012 Share March 31, 2012 Hi bro, Any jb WS to intro for this aircon part change? Thanks ! Link to post Share on other sites More sharing options...
SF13 Neutral Newbie April 14, 2014 Share April 14, 2014 My perodua kelisa ac compressor is spoilt. Then mechanic cut off the belting. Then the mechanic ask to change compressor which cost $500. Is the price reasonable? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged June 19, 2014 Share June 19, 2014 my yom 07 tucson quoted ac comp at 550 fyi Link to post Share on other sites More sharing options...
Hanan_ho 2nd Gear June 19, 2014 Share June 19, 2014 My perodua kelisa ac compressor is spoilt. Then mechanic cut off the belting. Then the mechanic ask to change compressor which cost $500. Is the price reasonable? Should be around that price range. Plus minus there with labours etc. If you find the price bit high, maybe can source for 2nd hand or reconditioned set. Link to post Share on other sites More sharing options...
Harrier57 Neutral Newbie February 5, 2017 Share February 5, 2017 Hi, just got my new Toyota Harrier 2 weeks ago before CNY. Found loud noise and vibration when compressor cuts-in. Sent in to workshop for inspection however they cannot identify the issues and says that it's the new piping design issue and need to cut the "High Pressure" inlet pipe and do some modification. Have verify with some other Harrier and confirmed that all have same design and without any noise or vibration issue. Can anyone advise and help. Thanks in advance for any advise! Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 5, 2017 Share February 5, 2017 Sound like talk rock to me. Would manufacturer allow their product to be release with such flaw? I seriously do not think so Link to post Share on other sites More sharing options...
Harrier57 Neutral Newbie February 5, 2017 Share February 5, 2017 Hi, just got my new Toyota Harrier 2 weeks ago before CNY. Found loud noise and vibration when compressor cuts-in. Sent in to workshop for inspection however they cannot identify the issues and says that it's the new piping design issue and need to cut the "High Pressure" inlet pipe and do some modification. Have verify with some other Harrier and confirmed that all have same design and without any noise or vibration issue. Can anyone advise and help. Thanks in advance for any advise! ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Aircon Cabin Filter
Aircon Cabin Filter
Aircon oil renewal necessary?
Car air-con
Car air-con
Dehumidifier recommendations
