Aaronlkl Supersonic May 28, 2012 Share May 28, 2012 For those using brembo or other bbk, would u pick dot4 or dot5.1? Which is better in term of performance and moist adsorbion?i ↡ Advertisement Link to post Share on other sites More sharing options...
Shibadog Turbocharged May 28, 2012 Share May 28, 2012 For those using brembo or other bbk, would u pick dot4 or dot5.1? Which is better in term of performance and moist adsorbion?i bro i think choice of brake fluid is more based on usage rather than type of bbk. I believe dot 5.1 is higher spec than dot 4, and also a lot more expensive. However i am using dot 4 with my brakes (front Prodrive, rear Sti) and no fade even after 5-6 hot laps on sepang. For longer endurance tracking, i wld go for dot 5.1 Rgds~ Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 28, 2012 Share May 28, 2012 (edited) Use the one with the highest boiling point if you need to do frequent high speed braking. All brake fluid will absorb surrounding moisture except silicon brake fluid. Edited May 28, 2012 by Yeobh Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 29, 2012 Share May 29, 2012 (edited) will changing only brake fluid improve the braking ???? assuming its just normal servicing big NO unless you are going downhill and likes to brake alot or go tracking. New brake fluid reduces brake fade better than old fluids, because of the reduced boiling point due to moisture. Edited May 29, 2012 by Hamburger Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 29, 2012 Share May 29, 2012 It's is a good practice for both car owners and mechanics to check the brake fluid moisture % whenever the the car is in for servicing. Brake fluid with high % of moisture will boil at much lower boiling temp and will overtime cause brake piston seizure resulting in costly brake overhaul. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 1, 2012 Share June 1, 2012 Link to post Share on other sites More sharing options...
Yuan 6th Gear June 1, 2012 Share June 1, 2012 It's is a good practice for both car owners and mechanics to check the brake fluid moisture % whenever the the car is in for servicing. Brake fluid with high % of moisture will boil at much lower boiling temp and will overtime cause brake piston seizure resulting in costly brake overhaul. I usually change out my brake fluid once a year or two due to our frequent start stop traffic conditions in Singapore and humid weather. Brakes feel better after that. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 1, 2012 Share June 1, 2012 Yes two years is almost the right time for our humid and hot weather. Once the water content reaches certain % you will feel the brake looses its solid hydraulic brake force - its tend to be spongy. This can be overcome by removing all the used brake fluid and replace with the correct brake fluid. The air bubbles bleeding process MUST be carried out either via pressure or vacuum brake bleeder ( hand vacuum pump is ok but very slow). Avoid using leg pumping power as the multi pumping actions will introduce more dirt into the master cylinder and will gradually travel down towards the slave cylinders/pistons. The dirt will over time cause system failure. Link to post Share on other sites More sharing options...
DD97 Neutral Newbie June 3, 2012 Share June 3, 2012 C@rlube Dot 4 Brake Fluid C@rlube Dot 4 Brake fluid is a synthetic brake and clutch fluid, mostly specified for Disc Brake systems, giving high performance and protection exceeding FMVSS 116 Dot 3 and SAEJ 1703 specifications. It will mix safely with other brake fluids (E.R.B.P.) conforming to these specifications. Specifications: Minimum Boiling Point 230 Link to post Share on other sites More sharing options...
Trex101 3rd Gear June 3, 2012 Share June 3, 2012 ATE Type 200 and SuperBlue Super Dot 4. Boiling point minimum (ERBP): 280'c Wet boiling point minimum: 198'c Viscosity at -104 degrees F: max 1,400 mm 2/5 Designed to last up to 3 years under normal highway driving conditions Cost $18/L, cheap and effective. Link to post Share on other sites More sharing options...
DD97 Neutral Newbie June 11, 2012 Share June 11, 2012 C@rlube Dot 4 Brake Fluid @ less than $8.00 C@rlube Dot 4 Brake fluid is a synthetic brake and clutch fluid, mostly specified for Disc Brake systems, giving high performance and protection exceeding FMVSS 116 Dot 3 and SAEJ 1703 specifications. It will mix safely with other brake fluids (E.R.B.P.) conforming to these specifications. Specifications: Minimum Boiling Point 230 Link to post Share on other sites More sharing options...
Cliveekeo Clutched June 12, 2012 Share June 12, 2012 As i know dot4 works well. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
