Battery indicator, what can be wrong?
Windwaver
Supercharged
Do you all constantly measure your battery with volt meter?
If I don't have volt meter, how do I tell when to change my battery?
Can I change when I start to need to crank twice? Will it be too late?
You just be more alert when your battery reaches 2 years of usage. Then when you find difficult in starting for a few days in a row, then better change the battery.
Crank twice to start may not be a good indicator. It could be you turn your key too fast (& release) ......
Not a few days. As soon as the carnk is slow n strained, better change.
Now battery damm fast die. I kenna in the morning slow crank n then in the afternoon cannot crank at all. [smallcry]
Since dot 3 n 4 compatible
And light nb shows up after a week
I jus leave it first ha ha
Ya after u top-up n it still ok then prob just yr brake pads worn n the fluid drop.
If u need to keep topping-up then prob u got a leak in the system.
what do you mean difficult in starting? as it it coughs a few times before engine started?
Supercharged
Yes, something like that....
Or it takes more than 2-3 times to start. Usually, with a healthy battery, just one start and the engine will fire up!
You got bino eyes
I strongly believed it's my rear brake worn but wth I jus changed brand new 1.5 yrs ago
It's really too fast ha ha
You got bino eyes
Cud b the replacement pads slightly thinner than the original or some difference so the fluid drop a bit more.
Usually when I change pads, I wil flush a bit of the fluid from the calipers so the fluid near the calipers wil b fresh again. Thats the place that gets very hot n the fluid wil breakdown n absorb moisture.
If u dun wan to flush the whole system, at least flush the fluid near the calipers better than nothing.
Also new pads wil compress a bit when u use for abt a month so u sud top-up the reservoir after abt a month after changing yr pads as the level wil drop a bit.
Edited by Pisces69
I see, think you are right , should top up a bit fluid hor
My mech got bleed the fluid I saw
I think he didn't tell me about the top up
Will penalized him next trip
Ha ha so far so good
Tks
Tks
Ya just monitor for the next month n if it dun drop again, then all is well.
Sorry to bring dig out a old thread..Recently i also got the same issue..But the battery indicator light up only in heavy rain..And after 5 sec..The indicator light will goes off..
Supercharged
Were your car moving while the battery indicator light up, in heavy rain ?
