Blackyv Turbocharged August 24, 2012 Share August 24, 2012 Well, I have a Toshiba system 3 and since yesterday, the masterbedroom unit blow only air, not cold at all... the rest of room still normal, blow cold air... so I don't think the problem lies with the compressor... anyone have such problem before? What could be the possible fault? Spoil sensor on the split unit?..... damn hot without air-conditioning... ↡ Advertisement Link to post Share on other sites More sharing options...
Tjkbeluga 5th Gear August 24, 2012 Share August 24, 2012 When was the last time you service? Probably need to top-up refrigerant.... Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 24, 2012 Share August 24, 2012 Well, I have a Toshiba system 3 and since yesterday, the masterbedroom unit blow only air, not cold at all... the rest of room still normal, blow cold air... so I don't think the problem lies with the compressor... anyone have such problem before? What could be the possible fault? Spoil sensor on the split unit?..... damn hot without air-conditioning... I face a problem at home about 4 mths back too. when you put your hand at the condenser unit, the air that comes out is not cold at all? even when you set at 18 degree celsius? did you notice any noise e.g. rumbling or rushing noise from the condenser unit? any water dripping from condenser unit? Link to post Share on other sites More sharing options...
Blackyv Turbocharged August 24, 2012 Author Share August 24, 2012 When was the last time you service? Probably need to top-up refrigerant.... Don't think so, the other 2 rooms cold...I service regularly... Link to post Share on other sites More sharing options...
Blackyv Turbocharged August 24, 2012 Author Share August 24, 2012 I face a problem at home about 4 mths back too. when you put your hand at the condenser unit, the air that comes out is not cold at all? even when you set at 18 degree celsius? did you notice any noise e.g. rumbling or rushing noise from the condenser unit? any water dripping from condenser unit? Yup, even set to 18deg, it still blow air, like any fan... not cold at all even after running for 2hrs... no water leak, no noise... .. for ur case, what went wrong? Choked pipe?.... Link to post Share on other sites More sharing options...
Windwaver Turbocharged August 24, 2012 Share August 24, 2012 Well, I have a Toshiba system 3 and since yesterday, the masterbedroom unit blow only air, not cold at all... the rest of room still normal, blow cold air... so I don't think the problem lies with the compressor... anyone have such problem before? What could be the possible fault? Spoil sensor on the split unit?..... damn hot without air-conditioning... Thermostat faulty, need to replace. Link to post Share on other sites More sharing options...
Blackyv Turbocharged August 24, 2012 Author Share August 24, 2012 Thermostat faulty, need to replace. That's what I suspect also... any ideal how much it cost?... Link to post Share on other sites More sharing options...
Windwaver Turbocharged August 24, 2012 Share August 24, 2012 That's what I suspect also... any ideal how much it cost?... Forgot liao but with servicing about $120 I think. So the repair should be less than $100. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear August 24, 2012 Share August 24, 2012 I have no air con. I do not even have bloody fan! Anyway, aircon switch on too long not very good leh. Cause too dry. Maybe open windows a bit. Just a question, what you guys think is a comfortable room temperature at night? Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 24, 2012 Share August 24, 2012 Yup, even set to 18deg, it still blow air, like any fan... not cold at all even after running for 2hrs... no water leak, no noise... .. for ur case, what went wrong? Choked pipe?.... My case the blower was noisy and airflow was uneven. that's caused by the drum blower being clogged with dirt. It was unevenly coated with dirt so the drum rotation was laboured. I also used a metal brush to remove the dirt. the air was also not cold because the waste water pipe was clogged with slime. This clog prevents the intake air from properly passing through the condenser A Tower because the water generated naturally on the aluminium fins of the condenser coil could not drain away in time. Surface contact and efficient thermal transfer between the intake air and the coil was compromised. Had to borrow a Borsch water vacuum to suck at the end of the drain pipe in the loo. So far I noticed that the condenser coil is getting clogged but not that clogged to perform a chemical wash- overhaul. Link to post Share on other sites More sharing options...
Kangadrool Supersonic August 24, 2012 Share August 24, 2012 I have no air con. I do not even have bloody fan! Anyway, aircon switch on too long not very good leh. Cause too dry. Maybe open windows a bit. Just a question, what you guys think is a comfortable room temperature at night? Your place needs heater. LOL... Link to post Share on other sites More sharing options...
Nojoke123 1st Gear August 24, 2012 Share August 24, 2012 need to do chemical wash for the particular unit. Link to post Share on other sites More sharing options...
Blackyv Turbocharged August 24, 2012 Author Share August 24, 2012 need to do chemical wash for the particular unit. How is chemical wash done? Spray chemical and vacuum?.. some say must dismatle the unit to do chemical wash.. true? . Link to post Share on other sites More sharing options...
GoodCar 4th Gear August 24, 2012 Share August 24, 2012 Simple dIY maintenance. Buy those foam type aircon fin cleaner from diy shop. Run air con in fan mode at high speed Spray foam evenly over the fin. Spray thin mist of water to slowly wash down the foam. Ensure you can see foam and water coming out from the drain pipe. Only do this if your drain pipe is draining ok. Link to post Share on other sites More sharing options...
Blackyv Turbocharged August 24, 2012 Author Share August 24, 2012 I have no air con. I do not even have bloody fan! Anyway, aircon switch on too long not very good leh. Cause too dry. Maybe open windows a bit. Just a question, what you guys think is a comfortable room temperature at night? I like to set to 26 for aircon with a fan blowing at me, not rotating.. just nice, not too cold, not too hot...... Link to post Share on other sites More sharing options...
Blackyv Turbocharged August 24, 2012 Author Share August 24, 2012 My case the blower was noisy and airflow was uneven. that's caused by the drum blower being clogged with dirt. It was unevenly coated with dirt so the drum rotation was laboured. I also used a metal brush to remove the dirt. the air was also not cold because the waste water pipe was clogged with slime. This clog prevents the intake air from properly passing through the condenser A Tower because the water generated naturally on the aluminium fins of the condenser coil could not drain away in time. Surface contact and efficient thermal transfer between the intake air and the coil was compromised. Had to borrow a Borsch water vacuum to suck at the end of the drain pipe in the loo. So far I noticed that the condenser coil is getting clogged but not that clogged to perform a chemical wash- overhaul. Ur case will have water leakage right?.. Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 24, 2012 Share August 24, 2012 Ur case will have water leakage right?.. ya got leaking somewhat. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear August 24, 2012 Share August 24, 2012 Your place needs heater. LOL... Not in the summer, & we have hot days as well. Last week, is record for the year I think. 33-35 degree I think. I have also played football at aound 30 deg twice. Almost going to died, as its not only hot, but also dry. You feel very hot, but no sweat, & mouth & hands very dry. The type of heat need to get used too. Summer also bring new inhabitants, like mosquito! Thankfully, they are active for like 3-4 days only. Now they are gone. My friend also complain, he went to a restaurant, & it was very hot, as they have no aircon. I believe the indoor hall in my town do not have aircon as well. But its not justification (unless you rich) to install aircon for something you need maybe 2-3 weeks of a year. The one thing I appreciate is warm water on the tap. Its nice to wash your face in the morning with warm water (until you forgot to off the tap, & warm water drain out over the night, & a big hole in your pocket ) ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Simple home DIY repairs
Home Aircon
Home Aircon
Car air-con
Car air-con
