Brendon1980 Neutral Newbie September 18, 2012 Share September 18, 2012 I am currently driving a 2year old 09' batch Ody. However I am facing some problems. What happen is that intermittently my car will restart her current especially during stops (happens also when I am driving halfway too). The engine is still running did not die off so no need to restart, its just like the current shut itself off and on again. Anyone encounter this issue? On some occassions, when I start the car the whole car has no power and cannot start, after awhile the power comes back and can start the engine. The alternator should be working fine as no issues with the charging as I have left the car standby for 2days and no problem starting the engine. Also the batt is only 8months old. Thanks for the advise. ↡ Advertisement Link to post Share on other sites More sharing options...
Detach8 5th Gear September 18, 2012 Share September 18, 2012 I don't understand what you are writing. Can you write in shorter sentences? Link to post Share on other sites More sharing options...
Brendon1980 Neutral Newbie September 18, 2012 Author Share September 18, 2012 well meaning the current will shut itself and on again even with the engine running every once in awhile. car still drivable during this period.. Link to post Share on other sites More sharing options...
Detach8 5th Gear September 18, 2012 Share September 18, 2012 How do you tell that the current (you mean electrical power?) will shut itself off and on? Link to post Share on other sites More sharing options...
Brendon1980 Neutral Newbie September 18, 2012 Author Share September 18, 2012 How do you tell that the current (you mean electrical power?) will shut itself off and on? my audio shuts down, the engine light comes out for a split second, the headlights flickered, my car recorder shuts down, my charger stops charging and there is a slight jerk... Link to post Share on other sites More sharing options...
Detach8 5th Gear September 18, 2012 Share September 18, 2012 (edited) Do you have upgraded audio (ICE)? Two possibilities: 1. Something electrical shorting out 2. Your engine almost stalled 3. Your alternator belt slipping? Try: 1. Checking your fuses, see if any major fuse is shorting out 2. Get an OBD read-out of stored engine error codes, might be ignition system problem or fuel delivery system problem Edited September 18, 2012 by Detach8 Link to post Share on other sites More sharing options...
Watwheels Supersonic September 18, 2012 Share September 18, 2012 If I'm not wrong it's the wiring assembly where you insert the key to turn on the ACC and ignition. There's a short circuit somewhere or a loose connection. Did you recently install something like a DVR or onboard cam tapping the power source from there? Coz for some ppl they install in such a way when they on the ignition the cam will also be switched on. Link to post Share on other sites More sharing options...
Brendon1980 Neutral Newbie September 18, 2012 Author Share September 18, 2012 Do you have upgraded audio (ICE)? Two possibilities: 1. Something electrical shorting out 2. Your engine almost stalled 3. Your alternator belt slipping? Try: 1. Checking your fuses, see if any major fuse is shorting out 2. Get an OBD read-out of stored engine error codes, might be ignition system problem or fuel delivery system problem my ICE was installed probably a year ago but this problem came out recently.. probably need to check the connection, but I was wondering why will trip the whole car circuit if lets say the connection of the ICE was an issue? Shouldn't the fuse take care of it? Ok, I will go check out the proposed solutions. Thanks.. Link to post Share on other sites More sharing options...
Brendon1980 Neutral Newbie September 18, 2012 Author Share September 18, 2012 If I'm not wrong it's the wiring assembly where you insert the key to turn on the ACC and ignition. There's a short circuit somewhere or a loose connection. Did you recently install something like a DVR or onboard cam tapping the power source from there? Coz for some ppl they install in such a way when they on the ignition the cam will also be switched on. Yup, I had installed a DVR but this connection is always live meaning not off. I am using the blackvue with magic box for auto power cut off. But I have installed over 6months already, could this issue comes back and haunt me after 6 months? Probably I need to check all the connections again. Thanks. Not sure if this issue will damage any circuit or ECU thou... Link to post Share on other sites More sharing options...
Detach8 5th Gear September 18, 2012 Share September 18, 2012 Watwheels may be correct. Your DVR may be tapped from ignition. Link to post Share on other sites More sharing options...
Rustyz 5th Gear September 18, 2012 Share September 18, 2012 bring back KAH motor check la. still under warranty Link to post Share on other sites More sharing options...
Audi655 Clutched September 18, 2012 Share September 18, 2012 maybe battery socket loosen Link to post Share on other sites More sharing options...
Xers007 Supercharged September 18, 2012 Share September 18, 2012 bring back KAH motor check la. still under warranty u want his warranty to get void ah.... do so many wiring stuff still bring back KAH to check... most likely some short circuit somewhere ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone watches MMA?
Anyone watches MMA?
Green fingers anyone?
Anyone try Cathay Pacific before?
New Zealand - anyone?
Feedback
Feedback
Roti Prata lover? Anyone?
