Chucky2007 Turbocharged March 18, 2013 Share March 18, 2013 R u using original air filter? Seems strange every 8k km u need to clean tb? I doubt car was made to b like that. Last time on original paper filter also got this symptom, now on K&N also same. Most lancer and colts have similar symptoms, but its something that can live with. Just that the vibration total stops once TB is cleaned. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 18, 2013 Share March 18, 2013 Last time on original paper filter also got this symptom, now on K&N also same. Most lancer and colts have similar symptoms, but its something that can live with. Just that the vibration total stops once TB is cleaned. Usually sports filter can give this problem but original air filter sud not hv. Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 18, 2013 Share March 18, 2013 Colt plus I always thought the Colt Plus looks like handheld vacuum cleaner. Seems like the similarity is more than skin deep, need to change filter frequently to maintain performance. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 19, 2013 Share March 19, 2013 I always thought the Colt Plus looks like handheld vacuum cleaner. Seems like the similarity is more than skin deep, need to change filter frequently to maintain performance. Haha yah man.. like Philip handheld. Link to post Share on other sites More sharing options...
Yuan 6th Gear March 26, 2013 Share March 26, 2013 Last time on original paper filter also got this symptom, now on K&N also same. Most lancer and colts have similar symptoms, but its something that can live with. Just that the vibration total stops once TB is cleaned. My old CS3 when on stock or original air intake, need not need the cleaning and only did once after 70k or 80k km. Then when I was on k&n then, I clean the TB after 40k km. If you clean your k&n, make sure don't over-oil your filter. Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 26, 2013 Share March 26, 2013 Throttle body dirty has nothing to do with type of air filter. It's from the blow by from the PCV. Use an oil catch tank and the throttle body will be much cleaner. Link to post Share on other sites More sharing options...
Circuit Clutched March 26, 2013 Share March 26, 2013 I go DIY home fix buy those residue free electric board cleaner for o2 sensor, then happen to clean the pipes and flap using that and wipe clean if need too O2 sensor just spray a lot to flush the sensor Link to post Share on other sites More sharing options...
Ungtiong 2nd Gear March 27, 2013 Share March 27, 2013 (edited) how to move the flap for an electronic throttle...it is safe to move it manually? Edited March 27, 2013 by Ungtiong 1 Link to post Share on other sites More sharing options...
Ooosh 1st Gear March 27, 2013 Share March 27, 2013 Throttle body dirty has nothing to do with type of air filter. It's from the blow by from the PCV. Use an oil catch tank and the throttle body will be much cleaner. In my opinon, a oil catch tank is insufficient to catch 100% of the oil. A good way to resolve this is to cap the part on air intake where the engine oil pipe is leading into the air intake. Then use a oil catch tank with breather on the engine oil pipe leading out. 1 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 27, 2013 Share March 27, 2013 how to move the flap for an electronic throttle...it is safe to move it manually? don't remove the electronic throttle.. else need to calibrate Remove all rubber piping that connects to throttlebody, then turn the electronic on but not the engine, when the electronic is on, when step pedal, able to open throttle valve, then use cloth lined with throttle plate safe solution and wipe. Need another person to step pedal. Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 27, 2013 Share March 27, 2013 In my opinon, a oil catch tank is insufficient to catch 100% of the oil. A good way to resolve this is to cap the part on air intake where the engine oil pipe is leading into the air intake. Then use a oil catch tank with breather on the engine oil pipe leading out. like that not environmentally friendly lor. :) which is why the design was for the blow by is piped back to the intake.. Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 27, 2013 Share March 27, 2013 Maybe you can adv those who wish to DIY how to remove and clean the o2 sensor . Link to post Share on other sites More sharing options...
Mauiman Neutral Newbie March 27, 2013 Share March 27, 2013 don't remove the electronic throttle.. else need to calibrate Remove all rubber piping that connects to throttlebody, then turn the electronic on but not the engine, when the electronic is on, when step pedal, able to open throttle valve, then use cloth lined with throttle plate safe solution and wipe. Need another person to step pedal. I always take out the cables and clean. also use hand to move the flap. No issues but rpm will shoot up when starting car. after a week, the rpm is normal after relearning again. Link to post Share on other sites More sharing options...
Airwaver 4th Gear March 27, 2013 Share March 27, 2013 I go DIY home fix buy those residue free electric board cleaner for o2 sensor, then happen to clean the pipes and flap using that and wipe clean if need too O2 sensor just spray a lot to flush the sensor So far yet to hear ppl cleaning O2 sensor, MAF sensor si bo? Link to post Share on other sites More sharing options...
Airwaver 4th Gear March 27, 2013 Share March 27, 2013 I always take out the cables and clean. also use hand to move the flap. No issues but rpm will shoot up when starting car. after a week, the rpm is normal after relearning again. Not advisable if it's E-throttle. Link to post Share on other sites More sharing options...
Yuan 6th Gear March 27, 2013 Share March 27, 2013 Throttle body dirty has nothing to do with type of air filter. It's from the blow by from the PCV. Use an oil catch tank and the throttle body will be much cleaner. Oh. Okay. Thanks for sharing that I have now learnt something which is correct. Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 27, 2013 Share March 27, 2013 So far yet to hear ppl cleaning O2 sensor, MAF sensor si bo? yalor. lambda sensors i thought are usually found before and after the catalytic converter. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear August 9, 2013 Share August 9, 2013 Other than cleaning throttle, what other things to clean to improve fuel consumption ↡ Advertisement Link to post Share on other sites More sharing options...
3M Double Sided Tape and Car Body Coating
Car carpet cleaning
Car carpet cleaning
Is Wide Body Kit Illegal??
Scrap Value for my Integra
Police investigating after body retrieved in waters off Merlion Park
Body Odour
Body Odour
😥Woman, in her 80s, keeps body of son, 54, in HDB flat for over a week after he passed away😥
