Dfx16 6th Gear March 6, 2013 Share March 6, 2013 Got my very 1st ice kit yesterday Problem is there's an intermittent tek tek tek sound which is quite annoying It happened about 4 times in a single song play both cd and radio Went back audio shop today, courtesy of the shop they change another new pair of speakers but it still happen Can pls help advise where could possible went wrong This is what I had installed yesterday Pioneer front components Pioneer rear 2 ways Pioneer woofer Pioneer amp Pioneer hu Thanks for any input ↡ Advertisement Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear March 6, 2013 Share March 6, 2013 last time is my vol i set too high, cause my woofer to pop... u try lower vol and see... Link to post Share on other sites More sharing options...
Dfx16 6th Gear March 6, 2013 Author Share March 6, 2013 (edited) This is not for my case Mine distorted the other way If i turn the volume low the "tek" sound is quite obvious If volume go louder the "tek" sound still can be hear but not that obvious Edited March 6, 2013 by Dfx16 Link to post Share on other sites More sharing options...
Jtb 6th Gear March 6, 2013 Share March 6, 2013 Got my very 1st ice kit yesterday Problem is there's an intermittent tek tek tek sound which is quite annoying It happened about 4 times in a single song play both cd and radio Went back audio shop today, courtesy of the shop they change another new pair of speakers but it still happen Can pls help advise where could possible went wrong This is what I had installed yesterday Pioneer front components Pioneer rear 2 ways Pioneer woofer Pioneer amp Pioneer hu Thanks for any input Any fray wires touched the car body? Link to post Share on other sites More sharing options...
HoLiaoLiang Neutral Newbie March 6, 2013 Share March 6, 2013 This is not for my case Mine distorted the other way If i turn the volume low the "tek" sound is quite obvious If volume go louder the "tek" sound still can be hear but not that obvious Probably power flow towards the speaker too high voltage or low? You can go sgsounsystem.com and ask Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 6, 2013 Share March 6, 2013 Maybe one of yr spark cable is leaking, the high kv sparks may have cause inference in yr sound system Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear March 6, 2013 Share March 6, 2013 Check your grounding points. Link to post Share on other sites More sharing options...
Dfx16 6th Gear March 10, 2013 Author Share March 10, 2013 (edited) Update till date I had changed another new speakers, new head unit and reroute the cables Reconfigure the channel a and b Problem still persist Can anyone intro any good audio trouble shooter to me? Quite irritating the "spark" sound The tek tek tek sound appear when switch on off the air con, playing music, toggle the function in the hu for eg. Louder or softer etc Edited March 10, 2013 by Dfx16 ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Home repair advice needed
