Spiderman302 2nd Gear March 9, 2013 Share March 9, 2013 My car 95,000 KM. Mechanic said no need to change the brake pad. Is it possible ? ↡ Advertisement Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic March 9, 2013 Share March 9, 2013 You hv a rare mechanic. Link to post Share on other sites More sharing options...
Dumb 4th Gear March 9, 2013 Share March 9, 2013 You hv a rare mechanic. Like that my agent should be extint! My last servicing at 200k still no need to change. Even brake pad changed once only, at 110k. Link to post Share on other sites More sharing options...
Inlinefour Twincharged March 9, 2013 Share March 9, 2013 My front pad and disc ard 30k km got to change new set... As for rear pad and disc can last till 70k km then change... Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear March 9, 2013 Author Share March 9, 2013 Like that my agent should be extint! My last servicing at 200k still no need to change. Even brake pad changed once only, at 110k. Wah lau, you use leg brake or what ? :D Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic March 9, 2013 Share March 9, 2013 Normally between 50 to 80k Depend on ur driving style whether u everyday love to brake when front of u is empty Link to post Share on other sites More sharing options...
Wormvirus 1st Gear March 9, 2013 Share March 9, 2013 oem by 35k can hear metal grind disc on my car, but the brake still feel confident albeit longer travel Link to post Share on other sites More sharing options...
Beonhah 1st Gear March 9, 2013 Share March 9, 2013 My car 95,000 KM. Mechanic said no need to change the brake pad. Is it possible ? yes Link to post Share on other sites More sharing options...
Torquemonster 1st Gear March 9, 2013 Share March 9, 2013 My car 93000km, still have around 7mm of fiction material left, so its possible. But still it is better to change as your old brake pads have gone through a number heat cycles, new pads will definitely improve braking! Link to post Share on other sites More sharing options...
5936 1st Gear March 9, 2013 Share March 9, 2013 Yes, its possible. If you are those tht dont waste fuel on the brakes. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 10, 2013 Share March 10, 2013 Wah lau, you use leg brake or what ? :D His car put parachute behind. Hahaha. My front pads changed at abt 80k km. Rear pads at abt 135k km. I also use parachute plus got sail also. Hahaha. Link to post Share on other sites More sharing options...
Vega Turbocharged March 10, 2013 Share March 10, 2013 Are all brake pads, be it performance or not come with a warning sound whenever you brake to tell you its about time to change brake pad? Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 10, 2013 Share March 10, 2013 Are all brake pads, be it performance or not come with a warning sound whenever you brake to tell you its about time to change brake pad? I dun think all hv. Only some hv a layer of rough material to give a grinding sound when pads almost gone. Some cars hv a warning light on dash wil come on also. Link to post Share on other sites More sharing options...
Berncsp76 6th Gear March 10, 2013 Share March 10, 2013 (edited) Are all brake pads, be it performance or not come with a warning sound whenever you brake to tell you its about time to change brake pad? my kimchee pad will have a screeching sound emitted from the screws rubbing the rotors and its time to change. Am on my third brake pad and 2nd rotor. Mileage 182k. Edited March 10, 2013 by Berncsp76 Link to post Share on other sites More sharing options...
Dumb 4th Gear March 10, 2013 Share March 10, 2013 My front pad and disc ard 30k km got to change new set... As for rear pad and disc can last till 70k km then change... Last time used to go up and down genting frequently and never remember had to change brake pads at 30k. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 10, 2013 Share March 10, 2013 my kimchee pad will have a screeching sound emitted from the screws rubbing the rotors and its time to change. Am on my third brake pad and 2nd rotor. Mileage 182k. If yr screws or rivets touch e discs....its already too late. Yr disc damaged liow. Thats why ty design pads wh grinding sound to frighten drivers to quickly go change pads. Maybe thats why u needed change yr rotors b4. I inspect my pads...inside n outside pads...when i know ty getting thin. Once i see its abt 3mm i change asap. Link to post Share on other sites More sharing options...
Junfeng1984 1st Gear March 10, 2013 Share March 10, 2013 My sa said brake pad still thick after 140,000km. Link to post Share on other sites More sharing options...
Briansoh 1st Gear March 10, 2013 Share March 10, 2013 Just wait for the warning lights to come on. Once the sensor in the pad hits the disc, it meas you have to change. If you wait for the screeching sound, it means its too late to save your discs as the screws have scored it already. ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
MALAYSIA TIPS - Long Distance Driving Trips
Change Disc Rotors
Change Disc Rotors
X for twitter change request
