Porche 5th Gear October 10, 2015 Share October 10, 2015 Mine also once a while vibrate, still can tong. Aircon compressor also kaput, hunting for next car ↡ Advertisement Link to post Share on other sites More sharing options...
jactan Neutral Newbie November 7, 2015 Share November 7, 2015 Replaced my swift 1.3 Manual Engine Mount yesterday, bought from stockist + labour $480. No more thump or tuck sound from front and rear wheels when do sudden accelerate. 1 Link to post Share on other sites More sharing options...
Throttle2 Supersonic November 7, 2015 Share November 7, 2015 Sounds like i got a good deal when replacing my hydraulic engine mounts Cost of parts $650 after discount. Link to post Share on other sites More sharing options...
Toyo 1st Gear December 9, 2015 Share December 9, 2015 Hi, Any recommendation for a workshop that charges reasonably for engine mount replacement for Daihatsu Sirion? I was quoted about $500-600 inclusive parts and labour. Link to post Share on other sites More sharing options...
Acewin 4th Gear December 9, 2015 Share December 9, 2015 Hi Everyone, Just to check with fellow bro/sis, I drive a sylphy 1.5 was told by workshop it has 4pcs of engine mounting and one of it has some sort of sensor attached and this is the most expensive piece out of the 4. Was told if replace all 4 cost $850.00 If replace the other 3 pcs (without the sensor piece) cost $450.0 Anyone can help me understand what W/s telling me is truth? Your feedback is appreciated. Thanks Link to post Share on other sites More sharing options...
Hotshot85 4th Gear December 9, 2015 Share December 9, 2015 Hi Everyone, Just to check with fellow bro/sis, I drive a sylphy 1.5 was told by workshop it has 4pcs of engine mounting and one of it has some sort of sensor attached and this is the most expensive piece out of the 4. Was told if replace all 4 cost $850.00 If replace the other 3 pcs (without the sensor piece) cost $450.0 Anyone can help me understand what W/s telling me is truth? Your feedback is appreciated. Thanks I smell B.S. What's the "sensor" for, did the W/S tell you? And check your manual too, I'm pretty sure if there's such a sensor it'll be mentioned somewhere in there. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 9, 2015 Share December 9, 2015 Try Eng Hup Auto - at Sungei Kadut there - I bought Axio engine mount from the boss there - then he bring you to his workshop at the same place to do the change. The lowest price after I've checked a few shops. Got a canteen there u can makan while waiting for your car. But no shopping centres nearby lah if you need aircon haha. Link to post Share on other sites More sharing options...
Toyo 1st Gear December 9, 2015 Share December 9, 2015 Thank u for the recommendation. Will check out the price there. Link to post Share on other sites More sharing options...
Mpeng Neutral Newbie May 9, 2016 Share May 9, 2016 Any recommendation for replacing engine mountings for Toyota wish. Thank you Link to post Share on other sites More sharing options...
AbbyYuan Clutched August 21, 2018 Share August 21, 2018 Influence of mounting system on NVH characteristics of vehicle The two main functions of suspension components:(Thanks for the help and support of Chongqing Feilong Jiangli Auto Parts technical department) (1) the displacement of the supporting powertrain and the East power train. (2) the vibration of the isolation power assembly is transferred to the vehicle body to improve the NVH of the vehicle. The higher stiffness of suspension is favorable for supporting powertrain, which is unfavorable to NVH of vehicle. The lower stiffness of the suspension is beneficial to the NWH of the vehicle and is not conducive to the support of the power train. Through the reasonable matching design of the mounting system, a better comprehensive result can be obtained, so that the NVH performance of the mounting system can be maximized while satisfying the support power assembly. Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear December 20, 2018 Share December 20, 2018 $130 to change Toyota mounts? wow that is expensive booosss. I change my conti car mounnts for $60 nia. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
