THINKWARE / INAVI Users, Come In
Maxus-MIFA9
anyone knows if the F750 comes with something like the power magic built-in? Thanks.
all thinkware devices have inbuilt voltage cut off. So yes already included you dont have to pay extra
cheers
A bit picky on memory card. Don't use Samsung. Sandisk is fine. Normal class ten uhs1 enuff
Thanks for the heads up. Download the manual which says 16GB, 32GB, 64GB. Do you know if cards with higher capacity (eg 128Gb) is ok?
u got 128 i can try for u
but no point
64 is already damn big
Can I check for the Dual Save, manual says to press Rec and Voice Recording button. Do I do it once and it will auto save the future incident recording to the internal memory? Or every time I have to press it?
When the internal memory is full, does it also delete the oldest data for new data like in the micro sd?
Actually I tried pressing rec and voice rec button, it says copying dual save files from internal memory to sd card. So I think the manual state wrongly. The dual save should be auto I think.
Has anyone installed a additional battery like a Cellink B for the F750?  Care to share the experience and recommendation of where to get it installed please?  Thanks.
Am not tech savvy so do excuse me if I am mistaken.
If you link the cam to an external battery, the camera will be on "continuous recording" mode when your car is parked. This being the case, if your memory card has limited memory space, older files might be overridden as such.
I might be wrong.
But, bottom line is, Thinkware can be linked to an external battery (though ZMC doesn't carry the latter).
Edited by Chickenfarm
  • Praise 2
I might be wrong.
Hmm... you are probably right. I guessed it may not go into parking mode if there is no way for the cam to determine whether the engine has been switched off.  And without going into parking mode, I'm not sure if it will also activate the motion detector.  Probably these are the reasons why ZMC don't sell or want to hook it up to an external battery?  If that's the case, they should have told me before my purchase when I enquired about the external battery.
Edited by CultureShock
Got the Sandisk Ultra 64GB today expecting it to work but kena memory card error. Thinking if I should get another sandisk card to try...
