Iczboi Neutral Newbie May 8, 2013 Share May 8, 2013 Hi bros out there, I tried searching for the above, but don't seems to get an answer. Hope I can get help from you guys.Is it an snake oil product again? I have a piggyback Dastek UniChip. If I put this on, do I need to re-tune?Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Tiger1 6th Gear May 8, 2013 Share May 8, 2013 Wat car u driving? Link to post Share on other sites More sharing options...
LoverofCar 6th Gear May 8, 2013 Share May 8, 2013 Hi bros out there, I tried searching for the above, but don't seems to get an answer. Hope I can get help from you guys. Is it an snake oil product again? I have a piggyback Dastek UniChip. If I put this on, do I need to re-tune? Thanks in advance. What does it do?....add more spinning air to in take? Link to post Share on other sites More sharing options...
Iczboi Neutral Newbie May 8, 2013 Author Share May 8, 2013 I'm driving Avante. Link to post Share on other sites More sharing options...
Iczboi Neutral Newbie May 8, 2013 Author Share May 8, 2013 SUPER SPIRAL TURBO VENTILATOR blades are made of advanced precision bearing technology (running up to 30,000 RPM). Light weight aluminum alloy design is not only anti-rust, but also has the ability to match your high-revving engine. The blades have special angles to promote extra air flow to the inlet manifold and assist in providing better engine combustion. Experience strong torque during low to medium RPM ranges but also extreme horsepower at higher engine revolutions. The upgraded fuel combustion can reduce carbon accumulation to your engine. Furthermore, it is environment friendly and greatly increases performance efficiency Improved fuel economy Instant increase in engine power Reduction in carbon accumulation to your engine Minimized air pollution Enhanced throttle response and acceleration Easy to install, DIY Link to post Share on other sites More sharing options...
LoverofCar 6th Gear May 8, 2013 Share May 8, 2013 So is another type of so call air charger lah.. do a search here on air charger.....you get your answer... Link to post Share on other sites More sharing options...
LoverofCar 6th Gear May 8, 2013 Share May 8, 2013 Hi bros out there, I tried searching for the above, but don't seems to get an answer. Hope I can get help from you guys. Is it an snake oil product again? I have a piggyback Dastek UniChip. If I put this on, do I need to re-tune? Thanks in advance. Didn't you got the answer in the other thread on with charger?...and u open a thread on this kinda thing again... Link to post Share on other sites More sharing options...
Ooosh 1st Gear May 9, 2013 Share May 9, 2013 Its proven not to be effective It will only mess up the air fuel ratio... The only power increase you get is through compressed air which this does not provide Please stop wasting your money on such stuff!!!! Link to post Share on other sites More sharing options...
Iczboi Neutral Newbie May 9, 2013 Author Share May 9, 2013 Oh, so this is another type of air charger? Thanks for enlightening :) Link to post Share on other sites More sharing options...
Rayoflight 5th Gear May 9, 2013 Share May 9, 2013 bro.. i put already now my car can fly as fast as a F15! how fast you want your avante to be? its all in your mind..save your pockets for more fuel $ la Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear May 9, 2013 Share May 9, 2013 Sounds like Surbo...hahahahaha... A good open pod filter plus a good heat shield...your engine would have more volume than it ever needs... Unless you are driving a Bugatti Veryon....or having a turbine engine....all these "toys" have pretty negligible gains. Wanna save fuel...spend the money on petrol and you sure will go further. Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 9, 2013 Share May 9, 2013 Read that those spirals act as blade to drawn air faster, but as the car goes faster these will be an obstruction to the air flow. No point in this, it is no way its gonna work the same as a turbo. Link to post Share on other sites More sharing options...
Solar Turbocharged May 9, 2013 Share May 9, 2013 Sounds like Surbo...hahahahaha... A good open pod filter plus a good heat shield...your engine would have more volume than it ever needs... Unless you are driving a Bugatti Veryon....or having a turbine engine....all these "toys" have pretty negligible gains. Wanna save fuel...spend the money on petrol and you sure will go further. and surprisingly, that 'company' is still around Link to post Share on other sites More sharing options...
Watwheels Supersonic May 9, 2013 Share May 9, 2013 Install it on your nostril and see whether it gives you extra power when you run. Link to post Share on other sites More sharing options...
Rayoflight 5th Gear May 9, 2013 Share May 9, 2013 Install it on your nostril and see whether it gives you extra power when you run. Hahahaha i should put one in my mouth and run for my IPPT! Link to post Share on other sites More sharing options...
Ungtiong 2nd Gear May 9, 2013 Share May 9, 2013 there is some truth but not much use, same like large exhaust upgrade only...its just make a sound that you associate with fast so you think you are going faster. Link to post Share on other sites More sharing options...
Iczboi Neutral Newbie May 9, 2013 Author Share May 9, 2013 I confirm no use liao... instead of being a air flow optimizer, it should be called as air flow restrictor. I checked with my mechanic friend, that is what he told me. Link to post Share on other sites More sharing options...
Iczboi Neutral Newbie May 9, 2013 Author Share May 9, 2013 Haha, cos alot of people don't bother to check up before purchasing. Only minority of car owners bother to do research. ↡ Advertisement Link to post Share on other sites More sharing options...
Sinota/Simota VS Hurricane -- Drop-In Air Filter..
Simota Carbon Charger airfilter
Simota Air Intake Anyone???
Simota air cabon charger
Where to buy Simota air filter ?
Simota Aeroform
Simota Aeroform
