Simonsoh 2nd Gear October 11, 2013 Share October 11, 2013 (edited) Hi all, just checking if possible to have a 2nd micro sd card attached via a reader/ cable to my note 2 instead of inserting into the actual sd card slot? got such device? example like a laptop, you plug in 2 thumbdrives like that... Cuz sometimes i want to view the car cam footages on my hp... Edited October 11, 2013 by Simonsoh ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator October 11, 2013 Share October 11, 2013 i know iPad has a dongle for sd card to connect to it, not sure about android. Link to post Share on other sites More sharing options...
Fishbowl 2nd Gear October 11, 2013 Share October 11, 2013 (edited) Hi all, just checking if possible to have a 2nd micro sd card attached via a reader/ cable to my note 2 instead of inserting into the actual sd card slot? got such device? example like a laptop, you plug in 2 thumbdrives like that... Cuz sometimes i want to view the car cam footages on my hp... Get a Samsung compatible OTG cable and a card reader. With OTG cable can also link up with thumbdrive. Btw, before you remove the OTG cable from your Note, remember to go Settings --> Storage-->unMount the USBdrive first else you may short the SD card. Edited October 11, 2013 by Fishbowl Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear October 11, 2013 Author Share October 11, 2013 Get a Samsung compatible OTG cable and a card reader. With OTG cable can also link up with thumbdrive. Btw, before you remove the OTG cable from your Note, remember to go Settings --> Storage-->unMount the USBdrive first else you may short the SD card. hi thanks! means i get this. then get another card reader. and viola!? http://list.qoo10.sg/item/MICRO-B-USB-HOST-OTG-ADAPTER-CABLE/405098136?selectedOptions=; Link to post Share on other sites More sharing options...
Watwheels Supersonic October 11, 2013 Share October 11, 2013 Why not just install a rear view mirror that comes with video monitor. I'm sure your cam has a video output. Connect the two with a video cable and you can view everything anytime. Switching the micro sd cards between devices, not troublesome meh? Link to post Share on other sites More sharing options...
Nicholas 5th Gear October 11, 2013 Share October 11, 2013 http://www.aliexpress.com/wholesale?shipCountry=us&shipCompanies=&SearchText=otg+cable&exception=&isRtl=yes&CatId=0&g=y&initiative_id=SB_20131010191028&isPremium=y&needQuery=n Link to post Share on other sites More sharing options...
Knoobie Supercharged October 11, 2013 Share October 11, 2013 Make sure your phone supports USB OTG first.. If doesn't sarpork, but what cable also no use.. Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear October 11, 2013 Author Share October 11, 2013 Why not just install a rear view mirror that comes with video monitor. I'm sure your cam has a video output. Connect the two with a video cable and you can view everything anytime. Switching the micro sd cards between devices, not troublesome meh? i planning whenever i want to retrieve anything from my car cam's sd card, I just take it out the card and view from and save to hp via a reader+cable. thats it. I thought this is simple enuf? I dun get what u suggesting... wats a rear view mirror c/w video monitor? my car cam has a video output. but dun i need to dismount the car cam to connect to anything else? Link to post Share on other sites More sharing options...
Fishbowl 2nd Gear October 11, 2013 Share October 11, 2013 hi thanks! means i get this. then get another card reader. and viola!? http://list.qoo10.sg/item/MICRO-B-USB-HOST-OTG-ADAPTER-CABLE/405098136?selectedOptions=; Yup, with the OTG cable and card reader, you can download/upload music, pictures n videos from/to devices n cards or thumbdrive. cheers Link to post Share on other sites More sharing options...
Icu 6th Gear October 11, 2013 Share October 11, 2013 Maybe a bit off-topic. Just take note of using Sandisk micro-SD cards on Note 2; there's a spate of incidents reported of Sandisk micro-SD getting damaged on Galaxy S3 & Note 2 phones. Not sure if it applies to external connections though. http://forums.hardwarezone.com.sg/samsung-user-group-136/widespread-sd-card-issue-samsung-galaxy-s3-note-2-a-4130144-4.html http://forums.sandisk.com/t5/Mobile-memory-professional-cards/32GB-Sandisk-Micro-SD-suddenly-stopped-being-recognized-by/td-p/291095 http://forums.androidcentral.com/samsung-galaxy-note-2/249920-sd-card-problem-note-2-a.html Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear October 11, 2013 Author Share October 11, 2013 Yup, with the OTG cable and card reader, you can download/upload music, pictures n videos from/to devices n cards or thumbdrive. cheers last question. so means "my files" will show my 3 folders? 1) internal storages 2) sd card (in slot) 3) sd card (connected via cable) Link to post Share on other sites More sharing options...
Fishbowl 2nd Gear October 11, 2013 Share October 11, 2013 last question. so means "my files" will show my 3 folders? 1) internal storages 2) sd card (in slot) 3) sd card (connected via cable) Based on my Note1, the storage description as follows 1. Device memory (2gb) 2. USB storage (device 32/64 gb storage space) 3. SD card (device micro SD card slot) 4. SD card (OTG) cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Android Phones
Android Phones
RAM/MicroSD issues
RAM/MicroSD issues
Oppo Mobile Phone Discussion Thread
Prepaid card
Prepaid card
Mirrorlink vs Apple CarPlay vs Android Auto.
Android’s emergency call shortcut is flooding dispatchers with false calls
My 4th Telco TPG Sim Card
Malaysia Touch 'N Go Card post-COVID-19
