Bluepica 4th Gear November 6, 2013 Share November 6, 2013 both of my ride side mirror like lacking of lube, sometimes can open/close, sometimes can't, need to use hand to push... is it serviceable? I went to a few workshop to asked, they told me cannot service, must change whole set ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator November 6, 2013 Share November 6, 2013 take out the electrical and make it stay unfold permanently 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear November 6, 2013 Author Share November 6, 2013 take out the electrical and make it stay unfold permanently I guess that will be the final resort. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 6, 2013 Share November 6, 2013 the mirror motor is the problem. probably going to spoil. Link to post Share on other sites More sharing options...
Rustyz 5th Gear November 6, 2013 Share November 6, 2013 nissan sunny last time I change 250 each. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 6, 2013 Share November 6, 2013 both of my ride side mirror like lacking of lube, sometimes can open/close, sometimes can't, need to use hand to push... is it serviceable? I went to a few workshop to asked, they told me cannot service, must change whole set I spray a bit of lube spray (not WD40 hor) at the top n bottom pivot points to lube it every year. So far its very smooth n no problem. Try some RP 7 lube spray first n do it every few days n see if it recovers to normal. If not then just leave it fully open all the time. Link to post Share on other sites More sharing options...
Rustyz 5th Gear November 6, 2013 Share November 6, 2013 What brand lube u use , won't it stain the car paint? Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 6, 2013 Share November 6, 2013 What brand lube u use , won't it stain the car paint? For lube spray, I use Selleys RP7. Its a real lube spray. U can use any good quality lube or even grease if u can get it into the tiny space. WD 40 is a penetrateing fluid to free rusty parts n wil eat into the metal after some time. When I was at an aerospace company, WD 40 was banned n anybody caught using it at work wil b sacked immediately. So far RP 7 has not stained the paint. After a carwash, u cant see it anymore but its inside lubricating the part. Link to post Share on other sites More sharing options...
Rustyz 5th Gear November 6, 2013 Share November 6, 2013 For lube spray, I use Selleys RP7. Its a real lube spray. U can use any good quality lube or even grease if u can get it into the tiny space. WD 40 is a penetrateing fluid to free rusty parts n wil eat into the metal after some time. When I was at an aerospace company, WD 40 was banned n anybody caught using it at work wil b sacked immediately. So far RP 7 has not stained the paint. After a carwash, u cant see it anymore but its inside lubricating the part. So serious WD40( i thought it is made with fish oil Never mind cover it with plastic bag and save the washing. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 6, 2013 Share November 6, 2013 (edited) So serious WD40( i thought it is made with fish oil Never mind cover it with plastic bag and save the washing. I think WD40 was mostly kerosene last time. Even the smell like kerosene. But now I find it is different. A bit thicker n smell different. Maybe ty changed the formulation after ty got complaints/feedback? But penetrating n lubricating fluid r different n hv different uses. Edited November 6, 2013 by Pisces69 Link to post Share on other sites More sharing options...
Rustyz 5th Gear November 6, 2013 Share November 6, 2013 I think WD40 was mostly kerosene last time. Even the smell like kerosene. But now I find it is different. A bit thicker n smell different. Maybe ty changed the formulation after ty got complaints/feedback? But penetrating n lubricating fluid r different n hv different uses. Fact: Consumers have told us over the years that they have caught some of the biggest fish ever after protecting their fish hooks and lures with WD-40. We believe this legend came from folks assuming that the product must contain fish oil since it appears to attract fish. Sorry Charlie®, it just ain’t so. WD-40 Company has taken steps to respect and conserve the environment, and encourages its users to do the same. While WD-40 can be used to help protect fishing equipment from rust and corrosion, WD-40 Company does not recommend using WD-40 to attract fish. haha Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 7, 2013 Share November 7, 2013 Here is a mini grease gun Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear November 7, 2013 Share November 7, 2013 (edited) its serviceable. Just that you need time to open up to reach the internal. One of my gear inside my side mirror cracked, a worm gear attached to the motor replace it and work like a charm. If you want to grease plastic or rubber parts, please use die electric grease/ Silicon grease as it will not eat away rubber and plastic like multi purpose grease or lithium grease. Edited November 7, 2013 by Ivanpaseo Link to post Share on other sites More sharing options...
Bluepica 4th Gear January 10, 2014 Author Share January 10, 2014 its serviceable. Just that you need time to open up to reach the internal. One of my gear inside my side mirror cracked, a worm gear attached to the motor replace it and work like a charm. If you want to grease plastic or rubber parts, please use die electric grease/ Silicon grease as it will not eat away rubber and plastic like multi purpose grease or lithium grease. I greased it, cannot... now both left and right also got problem... close a bit then stop... but if I use little pressure to help it close and open, it can.... weird.. I can't seem to locate and screw to open up the casing.... :( Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 10, 2014 Share January 10, 2014 (edited) I greased it, cannot... now both left and right also got problem... close a bit then stop... but if I use little pressure to help it close and open, it can.... weird.. I can't seem to locate and screw to open up the casing.... :( You have to remove the mirror with a mini rubber suction cup Edited January 10, 2014 by Yeobh 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear January 10, 2014 Author Share January 10, 2014 You have to remove the mirror with a mini rubber suction cup The mirror need to be removed to access the internal mechanical items? I thought the folding mechanical is located at the bottom angle Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 10, 2014 Share January 10, 2014 The mirror need to be removed to access the internal mechanical items? I thought the folding mechanical is located at the bottom angle The mirror is hold in place by double side tape. Remove the mirrror you will be able to access the gearing components. Link to post Share on other sites More sharing options...
Kurty Supercharged January 10, 2014 Share January 10, 2014 does spraying wd40 really works?i also got this problem.. both side cannot open nor close. ↡ Advertisement Link to post Share on other sites More sharing options...
Foldable bicycle
Foldable bicycle
Blind spot mirror?
Blind spot mirror?
Need Recommendations for a bicycle
Foldable static sunshade
Right side speakers no sound
Need Advice On Honda Fit 2008 (GE) Side Mirror Repair
Foldable stationary bike
Herbal tonic wine (any side effects?)
