Sarion 4th Gear May 23, 2016 Share May 23, 2016 heard from SE from a different manufacturer, that Uber plans to secure 7000+ COEs. at this rate, wonder when will COE finally go down. someone should really get the financial authorities to stop this nonsense right now where the loan quantum is bypassed... ↡ Advertisement Link to post Share on other sites More sharing options...
SimonChow 1st Gear May 24, 2016 Share May 24, 2016 Jass is good. Want more freebies, book together w frens. Thats how i got 1.9k worth of freebies w 8bid NG n 30k loan. Bro can share her contact ... she's from LK or TPY ? Link to post Share on other sites More sharing options...
Ranchu Neutral Newbie May 24, 2016 Share May 24, 2016 Hi for forester 2.0i, is there a slope assist? If not will it roll back? Saw auto vehicle hold on the spec, not sure what is this Link to post Share on other sites More sharing options...
Iftiee 1st Gear May 24, 2016 Share May 24, 2016 Hi for forester 2.0i, is there a slope assist? If not will it roll back? Saw auto vehicle hold on the spec, not sure what is this Yes, it is called Hill Start Assist, Link to post Share on other sites More sharing options...
Rachdanom 2nd Gear May 24, 2016 Share May 24, 2016 Understand in hill start assist the car applies brake like for 2 sec after brake is released to allow driver time to engage accelerator. I thought in drive mode there is a idling torque...wont that be enough to cover the time right foot switches from brake to accelerate? Link to post Share on other sites More sharing options...
Fungsiong 1st Gear May 24, 2016 Share May 24, 2016 Hi All Please find below notes I took from one of the workshops I attended some time back. Hope this is useful for fellow Forrester owners. Please feel free to add your comments. Rgds ENGINE COMPARTMENT Anything that has yellow colour is the only parts that we can touch. Never allow 3rd party installer to connect to the battery directly It's not recommended to install alarm system; even MI does not provide such option Battery we have in our car is original from Japan - liquid type not maintenance free Wiper fluid - just water, add a bit of shampoo if the wiper is squeaking. The same container is used for both front and rear wiper Radiator coolant - just top up with water if the level is low, only required when driving very long distance. Brake fluid - no need to top up, the technician uses it to assess the thickness of the brake pad If the car is left for more than 1 week (e.g. travel), disconnect the negative terminal of the battery. The EU will not reset, but the clock and audio (radio stations, etc) needs to be re-adjusted There is a row of fuse near the batter (covered) - according to him no need to change anything and if there's any fuse blown just bring it back to MI for checking The engine has a automatic sensor that will not allow high speed if the engine is overheated It's difficult and time consuming to replace the spark plugs. We have four in the car and it'll take easily 1.5 hours. Fortunately this only needs to be done at 80k or 100k. INTERIOR When starting the engine, go through the cycle of push the start button once to activate audio and clock, another time for the full check and then press the brake together with the button to start the engine. He recommended that sequence to ensure all's tested before the engine is started. The coolant blue light is normal, no need to warm up but be aware that the temperature of the engines, oil, transmission etc. is not optimal so the engine will sound a bit rough Air con - auto climate function will open up the external air inlet if the temperature is too low or if the air has been circulating for too long. Cannot be overridden, set up in Japan Type pressure - he recommended 225 front/235 rear or 230/230 for better fuel consumption and longer tyre life There's no way to change the l/100km display. He asked us to ignore it since it's not accurate and just use the standard way of topping up and taking notes of how many km's were driven after that. "Hill assist" is activated when the brake is pressed more than 1 second on a slope. The car will be stationery for 4 seconds without pressing the brake. But this function will not work if the handbrake is activated. The paddle shifter can be used in D or M mode, although he doesn't see any need for that in Singapore traffic The X-mode is useful for downhill or uphill climb; it will limit the speed to about 40 km/h The VDC button (on the bottom right of steering wheel) shouldn't be touched. It's vehicle dynamic control managed by the ECU to compensate any drastic movement and typically deactivated when during dragging :-) The auto-fold mirror accessory can be purchased and installed - S$ 160 with tax included. Well worth it in my view. REAR The spare tyre has a holder for the car jack; tighten the screw of that to stop the thumping noise from the rear when passing a hump. He said this is a common complaint that can be easily fixed The cover (which we can pull to cover the luggage area) can be taken out and there's a placeholder on the spare tyre 7 Link to post Share on other sites More sharing options...
Rachdanom 2nd Gear May 24, 2016 Share May 24, 2016 On bullet no. 3 what is this alarm? Doesnt all cars come with alarm , including Forester, nowadays? Link to post Share on other sites More sharing options...
Jaris32 1st Gear May 24, 2016 Share May 24, 2016 Bro can share her contact ... she's from LK or TPY ?Reckon all if not most of the MI SE have rosters to move between TPY and LK. Link to post Share on other sites More sharing options...
Fungsiong 1st Gear May 24, 2016 Share May 24, 2016 On bullet no. 3 what is this alarm? Doesnt all cars come with alarm , including Forester, nowadays?Not on Forester. In fact they said any car with keyless starter is not recommended to have alarm. Link to post Share on other sites More sharing options...
Tohto Hypersonic May 24, 2016 Share May 24, 2016 Not on Forester. In fact they said any car with keyless starter is not recommended to have alarm. I also think it is not necessary. Most of the alarm installed are after market from AD or owner itself, not from factory. Without the key fob, basically you cant't start the car. Link to post Share on other sites More sharing options...
Sarion 4th Gear May 24, 2016 Share May 24, 2016 Hi All Please find below notes I took from one of the workshops I attended some time back. Hope this is useful for fellow Forrester owners. Please feel free to add your comments. Rgds ENGINE COMPARTMENT Brake fluid - no need to top up, the technician uses it to assess the thickness of the brake pad INTERIOR The coolant blue light is normal, no need to warm up but be aware that the temperature of the engines, oil, transmission etc. is not optimal so the engine will sound a bit rough The paddle shifter can be used in D or M mode, although he doesn't see any need for that in Singapore traffic use brake fluid to assess brake pad thickness??? wah piang... use eye and check visually lah! or better still, measure the brake pad thickness on collection day to monitor actual usage... coolant blue light on my current Leggy means you should not drive hard until the temperature has warm up enough to clear this warning... paddle shifter no need in Singapore traffic? try filtering lanes/joining expressway in a hurry in I-mode and see if you really don't need those... 2 Link to post Share on other sites More sharing options...
Swaku 1st Gear May 24, 2016 Share May 24, 2016 @Fungsiong, regarding the "Battery we have in our car is original from Japan - liquid type not maintenance free", does it mean that we have to top up the liquid now and then? Where to get this liquid? Eventually,can we replace this battery with those maintenance free type like from Amazon? Thanks. Link to post Share on other sites More sharing options...
BenTong Turbocharged May 24, 2016 Share May 24, 2016 On bullet no. 3 what is this alarm? Doesnt all cars come with alarm , including Forester, nowadays?Car alarm is necessary if you drive a Harrier and mark X.. Esp when u go massage in JB Link to post Share on other sites More sharing options...
Icecube187 2nd Gear May 25, 2016 Share May 25, 2016 Understand in hill start assist the car applies brake like for 2 sec after brake is released to allow driver time to engage accelerator. I thought in drive mode there is a idling torque...wont that be enough to cover the time right foot switches from brake to accelerate? Yes, it all depends on the inclination of the slope. For gentle slope, I don't need to step on brake and the car holds its position. For steeper slopes, eg HDB carparks ramps, the hill assist will hold for about 2s before car rolls back. Link to post Share on other sites More sharing options...
wheelogist 2nd Gear May 25, 2016 Share May 25, 2016 My new KIA sorento has a auto hold function which is very useful on elevated slopes. Once activated, it will automatically hold the car stationary once you apply the brakes a little harder after car stops. It release itself once you step on the accelerator. It function like the handbrake. Very useful especially on steep slope like car park exit in Ngee Ann city where Jam always occur. Even on flat road, it helps to hold car in position, thus no need to step on brake pedal with gear in drive mode. This is very useful when you are caught in a traffic Jam. All cars should have this feature! Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear May 25, 2016 Share May 25, 2016 @Fungsiong, regarding the "Battery we have in our car is original from Japan - liquid type not maintenance free", does it mean that we have to top up the liquid now and then? Where to get this liquid? Eventually,can we replace this battery with those maintenance free type like from Amazon? Thanks. battery water aka distilled water.... available for sale in most petrol stations Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 25, 2016 Share May 25, 2016 Car alarm is necessary if you drive a Harrier and mark X.. Esp when u go massage in JB Car alarm is useless as ppl tend to ignore. It is useful if: 1. 2 way alarm; or 2. Siren sound is some horny making out sound. Link to post Share on other sites More sharing options...
SJGDKK8 1st Gear May 25, 2016 Share May 25, 2016 What does the 2 bars previous and current mean? What are they measuring exactly? Can some kind bro advice? ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
