Mtortise 1st Gear November 5, 2015 Share November 5, 2015 Hi guys I am currently using tyres 225/65/R18 and is planning to change the front two tyres soon. I called up one of those workshop and was recommended to change the front two tyres to 235/60/R18 instead. That would also mean a difference of $60 for two tyres. My question is whether is this recommended? Will it hurt the car in anyway? Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
Detach8 5th Gear November 5, 2015 Share November 5, 2015 Looking at your tyre profile are you driving a SUV? Is it a 4x4 or FWD/RWD? Firstly, it is bad to have two different make of tyres front and rear as they have different grip and handling characteristics. But if you are changing to the same brand n model, then you need to know if your car is a 2 wheel or 4 wheel drive. Never use different tyre sizes for a 4 wheel drive. You will damage your drivetrain. 3 Link to post Share on other sites More sharing options...
Mason016 Supersonic November 5, 2015 Share November 5, 2015 Hi guys I am currently using tyres 225/65/R18 and is planning to change the front two tyres soon. I called up one of those workshop and was recommended to change the front two tyres to 235/60/R18 instead. That would also mean a difference of $60 for two tyres. My question is whether is this recommended? Will it hurt the car in anyway? Thank you. I assume your rear tyres are 225/65/18? You will lose some sidewall if you change. Secondly, please check your load index of your tyres. Not wise if you change to a lower load index tyres. Link to post Share on other sites More sharing options...
Jtyres 2nd Gear November 5, 2015 Share November 5, 2015 Even if you intent to change all four pieces together, it is recommended to stick to your original tyre size. I PMed you on the choices available for 225/65 R18 Tyres. There is Premium - Michelin Tyres and Economical - Maxtrek tyres available. Hi guys I am currently using tyres 225/65/R18 and is planning to change the front two tyres soon. I called up one of those workshop and was recommended to change the front two tyres to 235/60/R18 instead. That would also mean a difference of $60 for two tyres. My question is whether is this recommended? Will it hurt the car in anyway? Thank you. Link to post Share on other sites More sharing options...
Mtortise 1st Gear November 6, 2015 Author Share November 6, 2015 Looking at your tyre profile are you driving a SUV? Is it a 4x4 or FWD/RWD? Firstly, it is bad to have two different make of tyres front and rear as they have different grip and handling characteristics. But if you are changing to the same brand n model, then you need to know if your car is a 2 wheel or 4 wheel drive. Never use different tyre sizes for a 4 wheel drive. You will damage your drivetrain. Thanks for the advise. Yup, I am driving a Murano. I assume your rear tyres are 225/65/18? You will lose some sidewall if you change. Secondly, please check your load index of your tyres. Not wise if you change to a lower load index tyres. Got it. Thank you! Link to post Share on other sites More sharing options...
Detach8 5th Gear November 6, 2015 Share November 6, 2015 Thanks for the advise. Yup, I am driving a Murano. Murano should be FWD bah, so it is OK to have different tyre sizes but make sure same brand and make of the tyre. But of course best is to change all 4. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 6, 2015 Share November 6, 2015 for a FWD car, is it recommended to put the newer pair of tyres at the rear? Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 6, 2015 Share November 6, 2015 if your original factory fitted (recommended) size 225/65/18 I believe they are quite a few brand in the market. So strongly believe getting the factory size if available. mixing of 2 type (all 4 same size) is acceptable mixing tyre size on all wheel drive vehicle is all along not recommended. but now saw few car came factory fitted front and rear not same size on new car( may be now with new design) Link to post Share on other sites More sharing options...
Shibadog Turbocharged November 6, 2015 Share November 6, 2015 for a FWD car, is it recommended to put the newer pair of tyres at the rear? yes.. bcos less weight at rear, and weight transfers to front during hard braking Link to post Share on other sites More sharing options...
Detach8 5th Gear November 8, 2015 Share November 8, 2015 for a FWD car, is it recommended to put the newer pair of tyres at the rear? If you are concerned about tyre wear, then put new tyres in front since all the work is being done on the front wheels - acceleration, steering and braking. But if you really are concerned about safety, place new tyres at the rear prevents your car from losing rear traction and spinning in the wet since new tyres have more thread depth. if your original factory fitted (recommended) size 225/65/18 I believe they are quite a few brand in the market. So strongly believe getting the factory size if available. mixing of 2 type (all 4 same size) is acceptable mixing tyre size on all wheel drive vehicle is all along not recommended. but now saw few car came factory fitted front and rear not same size on new car( may be now with new design) Having a wider rear tyre is known as a staggered wheel setup and is commonly seen in RWD drive cars (BMW, Mercedes, Porsche, etc.) Most FWD and AWD drive cars have a square setup, i.e. all 4 tyres are of the same size. Mixing of 2 different brands is NOT acceptable. That is actually quite dangerous as every tyre handles differently. You won't know what will happen UNTIL you lose traction, and by the time that happens it's to late. Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 8, 2015 Share November 8, 2015 Mixing of 2 different brands is NOT acceptable. That is actually quite dangerous as every tyre handles differently. You won't know what will happen UNTIL you lose traction, and by the time that happens it's to late. Actually in the long past days, my father always put new tyres into the rear and move existing rear tyres to front... and sometimes it is different brand/model. Usually the tyre shop will say as long as left and right is the same, front and back different brand, but still same size is ok. But that was for B&B jap saloon, usually don't every go near the handling limits, so I guess will seldom kena problem. My current ride is SUV, I will rotate front/back every 10k km and change all 4 together into original factory size and all 4 same brand - just to be safe. Link to post Share on other sites More sharing options...
Detach8 5th Gear November 8, 2015 Share November 8, 2015 Actually in the long past days, my father always put new tyres into the rear and move existing rear tyres to front... and sometimes it is different brand/model. Usually the tyre shop will say as long as left and right is the same, front and back different brand, but still same size is ok. But that was for B&B jap saloon, usually don't every go near the handling limits, so I guess will seldom kena problem. My current ride is SUV, I will rotate front/back every 10k km and change all 4 together into original factory size and all 4 same brand - just to be safe. Well most of us don't drive at the limits of our tyres anyway, but when time comes that require your tyres to perform at the limit, e.g. e-braking in wet weather while negotiating a bend, then it will be too late. I used to have "eco" tyres in my old car and it was quite a drastic difference in grip especially in wet, and the tyres lock up very easily when braking. Different brands may perform similarly in the dry, but between them they do perform very differently in wet -- how it grips, how it cuts water (aquaplan) and how it deforms under load. Of course, most of the time it will be fine... but try not to use two different brands if possible. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 9, 2015 Share November 9, 2015 guys, many thanks for your input. safely is of paramount importance, so the general understanding is the newer pair of tyres should be placed at the rear. Link to post Share on other sites More sharing options...
13177 Hypersonic December 9, 2015 Share December 9, 2015 Anyone know where can buy used car tyres which is in condition? Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 9, 2015 Share December 9, 2015 Anyone know where can buy used car tyres which is in condition? try asking around , best go to your regular shop. only beware is the re-cut tire ( I am total can not tolerate this kind of tyreshop selling this re cut tyre) I cant imaging the tires are already worn down and cut deeper (this is already very thin up there) is boil down to business ethic. now aday Uber is so popular and some of this car is running on this re-cut tyre (hopefully LTA should step in for the safety of the Uber customersss Link to post Share on other sites More sharing options...
Caldina 1st Gear December 9, 2015 Share December 9, 2015 Actually in the long past days, my father always put new tyres into the rear and move existing rear tyres to front... and sometimes it is different brand/model. Usually the tyre shop will say as long as left and right is the same, front and back different brand, but still same size is ok. But that was for B&B jap saloon, usually don't every go near the handling limits, so I guess will seldom kena problem. My current ride is SUV, I will rotate front/back every 10k km and change all 4 together into original factory size and all 4 same brand - just to be safe. Always fit new tyres at the back Recommended by major tyre manufacturers. Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 9, 2015 Share December 9, 2015 guys, many thanks for your input. safely is of paramount importance, so the general understanding is the newer pair of tyres should be placed at the rear. well said, I supposed if the other old tires still have thick you should still able to place the 2 new in front do remember , some car or case you may not allow to do so (2 new tire in front) Link to post Share on other sites More sharing options...
13177 Hypersonic December 9, 2015 Share December 9, 2015 try asking around , best go to your regular shop. only beware is the re-cut tire ( I am total can not tolerate this kind of tyreshop selling this re cut tyre) I cant imaging the tires are already worn down and cut deeper (this is already very thin up there) is boil down to business ethic. now aday Uber is so popular and some of this car is running on this re-cut tyre (hopefully LTA should step in for the safety of the Uber customersss How would you know whether the tyre is re-cut? ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Washing machine front loading
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
