Lala81 Hypersonic January 27, 2018 Share January 27, 2018 I usually use on track recovery software to recover the data myself, but this work only if the drive recognise 2 disk fail at one time is quite rare, if you plug the drive into the computer directly does it work/read? Maybe the Synology malfunctioned? If it's a standard 2.5 or 3.5 Sara drive best just take the drive out and get a new casing and swap Also for nas setup please get NAS standard drives, there is a difference in reliability Lol my wd reds only seem to last 3 years. Zzz next time get hgst. One of mine is hgst now. ↡ Advertisement Link to post Share on other sites More sharing options...
dcb Turbocharged January 27, 2018 Author Share January 27, 2018 Phew. Link to post Share on other sites More sharing options...
Neutrino Supercharged January 27, 2018 Share January 27, 2018 (edited) Phew. DB29D0B9-96FA-4336-9957-7188373FABB2.png Can't you DIY using a HDD Caddy bought from Challenger quite cheap. 3.5" SATA ExternalHard Drive Enclosure S$ 39.90 Worked for me. Edited January 27, 2018 by Neutrino 1 Link to post Share on other sites More sharing options...
Mercury1 Turbocharged January 27, 2018 Share January 27, 2018 (edited) So far my array had 1 WD Red fail, Seagates NAS usually give SMART warning first then I swap it out. HGST seems okay but runs 6 degrees hotter than the Seagates which is damn odd. Anyway its good to mix the brands in case of any odd failure in one brand manufacturing for that batch. Average Seagate - 37 - 38 Degrees HGST - 44 Degrees WD Red - 42 Degrees I got more seagate nas and (touch wood) no total failure Lol my wd reds only seem to last 3 years. Zzz next time get hgst. One of mine is hgst now. Edited January 27, 2018 by Mercury1 Link to post Share on other sites More sharing options...
Mercury1 Turbocharged January 27, 2018 Share January 27, 2018 No meaning to doubt the guy but the rationale is interesting mainly cause I thought 1. 2 Harddisk have same head failure / platter damage, seems quite coincidental 2. A scratched platter is usually really bad, data recovery usually cost a bomb (or near impossible) cause they will need to either have specialize equipment to remove the platter in a clean room and mount on a reader or get a same hard drive model and swap the platters. Both technique I was told would be quite costly. Maybe the platter damage is not that jialat? Phew.DB29D0B9-96FA-4336-9957-7188373FABB2.png 1 Link to post Share on other sites More sharing options...
dcb Turbocharged January 27, 2018 Author Share January 27, 2018 Am not an IT guy so I have no idea what to do with it. Was hoping someone in here can help me when instarted this thread. Can't you DIY using a HDD Caddy bought from Challenger quite cheap. 3.5" SATA ExternalHard Drive Enclosure S$ 39.90 Worked for me. I have absolutely no idea. No meaning to doubt the guy but the rationale is interesting mainly cause I thought 1. 2 Harddisk have same head failure / platter damage, seems quite coincidental 2. A scratched platter is usually really bad, data recovery usually cost a bomb (or near impossible) cause they will need to either have specialize equipment to remove the platter in a clean room and mount on a reader or get a same hard drive model and swap the platters. Both technique I was told would be quite costly. Maybe the platter damage is not that jialat? Link to post Share on other sites More sharing options...
Mercury1 Turbocharged January 27, 2018 Share January 27, 2018 Am not an IT guy so I have no idea what to do with it. Was hoping someone in here can help me when instarted this thread. I have absolutely no idea. Just looking out for you mate, a lot of these shops just overcharge customers for things that are quite easy to do and overstate the actual issue. But anyway since the shop already has it In your position I would just pay the 500 and be done with it. If the drive was readable without any loud noises (indicates platter damage) you might be able to recover yourself for free is what I'm saying Link to post Share on other sites More sharing options...
dcb Turbocharged January 27, 2018 Author Share January 27, 2018 I get that bro. Just that I have no Idea what and how to do that’s all. Just looking out for you mate, a lot of these shops just overcharge customers for things that are quite easy to do and overstate the actual issue. But anyway since the shop already has it In your position I would just pay the 500 and be done with it. If the drive was readable without any loud noises (indicates platter damage) you might be able to recover yourself for free is what I'm saying 1 Link to post Share on other sites More sharing options...
DACH Supersonic January 27, 2018 Share January 27, 2018 I usually use on track recovery software to recover the data myself, but this work only if the drive recognise 2 disk fail at one time is quite rare, if you plug the drive into the computer directly does it work/read? Maybe the Synology malfunctioned? If it's a standard 2.5 or 3.5 Sara drive best just take the drive out and get a new casing and swap Also for nas setup please get NAS standard drives, there is a difference in reliability Thanks for the advice. I just went to Sim Lim Square change the casing. 1 Link to post Share on other sites More sharing options...
Happily1986 5th Gear January 27, 2018 Share January 27, 2018 My external hard disk USB port has sunken into the internal components inside. Can change the port? https://www.google.com.sg/search?q=2.5+hdd+enclosure+usb+3.0+singapore&ie=UTF-8&oe=UTF-8&hl=en-sg&client=safari Just change the HDD enclosure ↡ Advertisement 2 Link to post Share on other sites More sharing options...
UPS plane crashes at Louisville airport
Anyone tried Jetpac esim from Circles.Life before for trips?
Any recommendation for Malaysia Data Plan
AIRSIM overseas data SIM card discussion
Bill allowing police to collect DNA from more people passed as MPs sound privacy, security concerns
NASA's Voyager 1 is sending mysterious data from beyond our solar system. Scientists are unsure what it means.
Lazada and Shopee payment gateway crashed at 11.11
