Dafansu Turbocharged June 3, 2019 Share June 3, 2019 125 bt merah lane 1 there. some car audio shop at blk 125 this one? https://www.sgcarmart.com/directory/merchant.php?MID=11132 ↡ Advertisement Link to post Share on other sites More sharing options...
jayz89 3rd Gear June 4, 2019 Share June 4, 2019 this one? https://www.sgcarmart.com/directory/merchant.php?MID=11132 correct sir Link to post Share on other sites More sharing options...
Tommisan 4th Gear June 4, 2019 Share June 4, 2019 Bought KR6S at recent PC show. Does anybody have existing set with the black box? Where did u guys put the black box? The sales person suggested below the steering rack but i thought it looks like those sets in a typical taxi... I placed it under the glove compartment. I wouldn't recommend to put it under the steering rack. Link to post Share on other sites More sharing options...
ianest 1st Gear June 4, 2019 Author Share June 4, 2019 (edited) The black box do what one uh? My kr8s dont hv it. Only 6 has.. The box is where the DVR is. In KR8S, the dvr is in same box as the front camera. I placed it under the glove compartment. I wouldn't recommend to put it under the steering rack. Possible to put it in the glove compartment, just so it is hidden from view? Edited June 4, 2019 by ianest Link to post Share on other sites More sharing options...
Tommisan 4th Gear June 6, 2019 Share June 6, 2019 The box is where the DVR is. In KR8S, the dvr is in same box as the front camera. Possible to put it in the glove compartment, just so it is hidden from view? I believe it is possible, just need to highlight to the installer. However, you will need some space to access the memory card in case of retrieval or replacement. By putting it in the glove compartment will also take up some of the storage space. Link to post Share on other sites More sharing options...
Andrew-Chai Neutral Newbie June 19, 2019 Share June 19, 2019 Hi Bro, may i know others brand rear cam image will be same marbella dash cam when view video show the carplate number are display opposite? I am using KR8S which direct connect to Fuse box, did anyone try for wire connect to FUSE holder then plug to fuse box , it looks tidy. TIA Hi Bro, may i know others brand rear cam image will be same marbella dash cam when view video show the carplate number are display opposite? I am using KR8S which direct connect to Fuse box, did anyone try for wire connect to FUSE holder then plug to fuse box , it looks tidy. TIA Link to post Share on other sites More sharing options...
Wlbwlb 1st Gear June 19, 2019 Share June 19, 2019 Hi Bro, may i know others brand rear cam image will be same marbella dash cam when view video show the carplate number are display opposite? I am using KR8S which direct connect to Fuse box, did anyone try for wire connect to FUSE holder then plug to fuse box , it looks tidy. TIA Hi Bro, may i know others brand rear cam image will be same marbella dash cam when view video show the carplate number are display opposite? I am using KR8S which direct connect to Fuse box, did anyone try for wire connect to FUSE holder then plug to fuse box , it looks tidy. TIA The rear cam when wifi to mobile has a option for mirror image to change so it will not show opposite. Link to post Share on other sites More sharing options...
Andrew-Chai Neutral Newbie June 19, 2019 Share June 19, 2019 Is natural for marbella only? Link to post Share on other sites More sharing options...
ianest 1st Gear June 29, 2019 Author Share June 29, 2019 (edited) The rear cam when wifi to mobile has a option for mirror image to change so it will not show opposite. Tried wifi to mobile to watch rear cam video. didn't see and buttons to switch when video is playing eh. May I ask where to find button to switch opposite image for rear cam? i'm using ios (if it matters). Edited June 29, 2019 by ianest Link to post Share on other sites More sharing options...
ianest 1st Gear June 29, 2019 Author Share June 29, 2019 Maybe I suaku, but i just noticed a feature that was different from my previous cam. When link to cam on WIFI, still can access internet via 4G. Interestingly, the wifi to cam wasn't taken by ios as internet access wifi, which is a good thing. Couple of things i found awkward is the UI for viewing video. 1) When login, the default page is downloaded file page and not dvr. So when view, must always have an extra step to click on dvr. 2) the recordings are broken up into 3 different taps of drive, park, events. i was expecting all to be be listed according to time in 1 list and a filter option on the side. Had to switch between tabs to look for particular video image. But above are small issues lah. can record when u want it to record, i happy liao. :) Link to post Share on other sites More sharing options...
JX83 3rd Gear June 29, 2019 Share June 29, 2019 (edited) Maybe I suaku, but i just noticed a feature that was different from my previous cam. When link to cam on WIFI, still can access internet via 4G. Interestingly, the wifi to cam wasn't taken by ios as internet access wifi, which is a good thing. Couple of things i found awkward is the UI for viewing video. 1) When login, the default page is downloaded file page and not dvr. So when view, must always have an extra step to click on dvr. 2) the recordings are broken up into 3 different taps of drive, park, events. i was expecting all to be be listed according to time in 1 list and a filter option on the side. Had to switch between tabs to look for particular video image. But above are small issues lah. can record when u want it to record, i happy liao. :) Ya the good thing is it won’t have interference with the 4G. Another good thing is u can toggle the recording time. Now I only set auto recording when I am parking outside. Btw do u know how to save the files directly to your iPhone from the memory card? Edited June 29, 2019 by JX83 Link to post Share on other sites More sharing options...
Wlbwlb 1st Gear July 1, 2019 Share July 1, 2019 Tried wifi to mobile to watch rear cam video. didn't see and buttons to switch when video is playing eh. May I ask where to find button to switch opposite image for rear cam? i'm using ios (if it matters). Should be this one.I not sure ios if different as I using android. Link to post Share on other sites More sharing options...
jayz89 3rd Gear July 1, 2019 Share July 1, 2019 no on the rear camera device itself there is a switch on it. just switch it for the non mirror image. Link to post Share on other sites More sharing options...
Naimed 5th Gear July 2, 2019 Share July 2, 2019 Bought KR6S at recent PC show. Does anybody have existing set with the black box? Where did u guys put the black box? The sales person suggested below the steering rack but i thought it looks like those sets in a typical taxi... I installed mine at the driver's right footwell, near the door hinge. Easy to retrieve SD card. Link to post Share on other sites More sharing options...
Naimed 5th Gear July 2, 2019 Share July 2, 2019 Hi guys, Marbella seems to be a up and coming dashcam brand in Singapore. Was looking for reviews on brand but found them in different threads on model specifics. So thought I start a brand thread so all can share their thoughts in one thread for easy ref. My ITB100SPW which have served me 5years (with battery changed in between) seems to be dying. I'm looking at Marbella KR8S / 6S but realised there are very limited reviews on Marbella dashcams. Read in forum they used to have video downloading issues but seems to have been resolved with new app in 2018. Read another user had recording time gap between video files. Wonder if other users experience this as well. Would love to hear your reviews for Marbella. Thanks for your contribution. Had the KR6S for a year plus - chose it due to the smaller size of the front and back cameras and also the recording file format. The KR6S never shut down on me even in hot weather because the control box is installed in a cool place. However, if given a choice again, I will lean towards a Blackvue or iroad, which I had previously and they had better video quality. Price wise, the KR6S is a lot cheaper than the Blackvue (DR750). iroad (V9S2) is in between. Link to post Share on other sites More sharing options...
bwauto Neutral Newbie July 17, 2019 Share July 17, 2019 I used this cam in my car. The recording quality was very clear. I also suggest my friend to use this dashcam. Link to post Share on other sites More sharing options...
ianest 1st Gear July 17, 2019 Author Share July 17, 2019 (edited) Ya the good thing is it won’t have interference with the 4G. Another good thing is u can toggle the recording time. Now I only set auto recording when I am parking outside. Btw do u know how to save the files directly to your iPhone from the memory card? Toggle recording time? Care to elaborate how to toggle? I leave mine on throughout parking with recording when sense movement mode. Edited July 17, 2019 by ianest Link to post Share on other sites More sharing options...
ianest 1st Gear July 17, 2019 Author Share July 17, 2019 (edited) Should be this one. I not sure ios if different as I using android. OIC. Was wondering why the image shift left and right when i click the button, didn't even realise the image was inverted horizontally. QUOTE "no on the rear camera device itself there is a switch on it. just switch it for the non mirror image." Didn't realise there is a button on the rear cam as well. thanks for the note! Edited July 17, 2019 by ianest ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommendations for a good dashcam for new drivers?
Reverse/backup camera with dashcam recording function
Thinkware F800 pro dash cam optimised settings to prevent draining car battery
DIY Dashcam Installation vs Poor Worksmanship from Installation Workshops
Dashcam with GPS
Dashcam with GPS
