tomicacars April 4, 2019 Share April 4, 2019 Which engine oil should use for subject car? ↡ Advertisement Link to post Share on other sites More sharing options...
theory_87 3rd Gear April 4, 2019 Share April 4, 2019 5w30 or 5w40 ACEA C2 or C3 engine oil will be fine. I will suggest 5w40 oil to slow down the oil consumption issue. You can try Fuchs Titan GT1 XTL C-3 5w40 5L from MXTrading for $60. the 1.6thp Prince Engine need 4.2L. The left over 0.8L engine oil can be use to top-up between servicing interval should the need arise. Link to post Share on other sites More sharing options...
tomicacars April 4, 2019 Author Share April 4, 2019 5w30 or 5w40 ACEA C2 or C3 engine oil will be fine. I will suggest 5w40 oil to slow down the oil consumption issue. You can try Fuchs Titan GT1 XTL C-3 5w40 5L from MXTrading for $60. the 1.6thp Prince Engine need 4.2L. The left over 0.8L engine oil can be use to top-up between servicing interval should the need arise. I tried 5w40 but the exhaust black smoke coming out. Link to post Share on other sites More sharing options...
theory_87 3rd Gear April 4, 2019 Share April 4, 2019 I tried 5w40 but the exhaust black smoke coming out. Which engine oil are you using now? Under what situation do the smoke appear? After long idling? Link to post Share on other sites More sharing options...
Beregond Supersonic April 4, 2019 Share April 4, 2019 I tried 5w40 but the exhaust black smoke coming out. black smoke?? your car diesel or petrol?? i never heard petrol car ot black smoke. white smoke alway have Link to post Share on other sites More sharing options...
Watwheels Supersonic April 4, 2019 Share April 4, 2019 Just Google can already mah. https://www.google.com/search?client=firefox-b-d&q=the+exhaust+black+smoke+coming+out Black exhaust smoke means the engine is burning too much fuel. The first think you should check is your air-filter and other intake components like sensors, fuel injectors and the fuel-pressure regulator. Other reasons could be a clogged fuel return line. ↡ Advertisement Link to post Share on other sites More sharing options...
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Hybrid cars 0w8 engine oil
