Goldenvodka 2nd Gear May 9, 2019 Share May 9, 2019 Greetings to everyone here. After all the DIY journey with various parts of the car. I decided to start troubleshooting my own vehicle’s ac. Anyone has any inputs on where to obtain r134a gas in a canister form? Other tools like pressure gauges and pipes can be easily found in Taobao. However R134a gas is one of the prohibited items to be shipped from China to Singapore. ↡ Advertisement Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 9, 2019 Share May 9, 2019 Greetings to everyone here. After all the DIY journey with various parts of the car. I decided to start troubleshooting my own vehicleâs ac. Anyone has any inputs on where to obtain r134a gas in a canister form? Other tools like pressure gauges and pipes can be easily found in Taobao. However R134a gas is one of the prohibited items to be shipped from China to Singapore. Horme, bigbox basement carpark. https://www.horme.com.sg/product.aspx?id=5824 Link to post Share on other sites More sharing options...
Goldenvodka 2nd Gear May 9, 2019 Author Share May 9, 2019 Horme, bigbox basement carpark. https://www.horme.com.sg/product.aspx?id=5824 Saw in the website, only the big cylinder is available. Do they sell small canister canned version on site? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear May 9, 2019 Share May 9, 2019 https://www.mycarforum.com/topic/2699312-advice-needed-on-car-aircon/?p=5881874 Greetings to everyone here.After all the DIY journey with various parts of the car. I decided to start troubleshooting my own vehicle’s ac.Anyone has any inputs on where to obtain r134a gas in a canister form?Other tools like pressure gauges and pipes can be easily found in Taobao. However R134a gas is one of the prohibited items to be shipped from China to Singapore. 1 Link to post Share on other sites More sharing options...
Goldenvodka 2nd Gear May 10, 2019 Author Share May 10, 2019 https://www.mycarforum.com/topic/2699312-advice-needed-on-car-aircon/?p=5881874Wow thanks! I was only intending to replace the expansion valve. So would be needing to release the R134A and refill it again Big thanks to your resources Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear May 10, 2019 Share May 10, 2019 Er ....... then you should also change the Discharge and Suction pipe lor. Usually Discharge pipe is the first to fail lor due to heat and pressure. Then Suction pipe is because you also want to change the dryer, which is usually integrated. It trap Dust/debris and Water (If any) lor. Best is why fix it when it ain't broken. Wow thanks!I was only intending to replace the expansion valve. So would be needing to release the R134A and refill it againBig thanks to your resources Link to post Share on other sites More sharing options...
Boxster 2nd Gear May 11, 2019 Share May 11, 2019 Wow thanks! I was only intending to replace the expansion valve. So would be needing to release the R134A and refill it again Big thanks to your resources How did you identify the problem is due to the expansion valve? ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Aircon Cabin Filter
Aircon Cabin Filter
Aircon oil renewal necessary?
Car air-con
Car air-con
Dehumidifier recommendations
