Wipers for S60
Chipwee
1 hour ago, Watwheels said:
This type of wiper buy the wiper blade replacement.
Last time my civic FD uses wiper blade replacement. Just pull out the blade like in the video and slide in the new one. Dont throw away the original steel support at the sides.
I bought from autobacs, about $20 each. But later I realised I can just buy those regular $10 wipers(6mm width) and just pull out the blades and use them. The civic ones are rather odd size so I just buy longer and cut to size. Important thing is not to throw away the original flat steel strips. You have to use them back every time you replace the wiper.
Now my suv rear wiper I also use the same method. Buy slightly longer cheaper wiper and pull out the blade. Might have to cut away the tip cos no grooves which acts as the strip stopper. And insert the new piece.
Should be the same for volvo. $150 you can see you are paying a lot of labour. The replacement blade maybe cost $10-$20.
I buy original Toyota wiper inserts from Stockist, only around 20$ per set
I buy NWB wiper blade on Shopee.
$8/pc.
