Si4dr 6th Gear November 17, 2025 Share November 17, 2025 On 11/16/2025 at 7:58 PM, Lala81 said: Automatic fish feeders are common now. I bought one. But I forgot my CA can just feed the fish haha since it's at work Got WiFi one. This one I bought is considered low tech liao. Since it's internal timer. WiFi timer I am more concern on the water quality......hobbyist (like me) normally overcrowd the tank...😅 Or you may ask someone you trust to feed once/day or two(best with experience in aquarium) ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 (edited) On 11/17/2025 at 9:01 AM, Si4dr said: I am more concern on the water quality......hobbyist (like me) normally overcrowd the tank...😅 Or you may ask someone you trust to feed once/day or two(best with experience in aquarium) mine is planted tank. don't really care too much about changing water. but algae bloom can be a problem. my water parameters is not good also, haha lot of nitrate and nitrite. Too much aquasoil probably. but the fish and shrimp are doing well bar a few weak ones which died along the way. Edited November 17, 2025 by Lala81 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 (edited) I cut down from feeding daily to maybe 4x/wk. Nanofish don't eat much. Actually just a simple guideline is only feed what they can eat finish in 1 minute? Edited November 17, 2025 by Lala81 2 Link to post Share on other sites More sharing options...
Didu Turbocharged November 17, 2025 Share November 17, 2025 On 11/17/2025 at 9:16 AM, Lala81 said: mine is planted tank. don't really care too much about changing water. but algae bloom can be a problem. my water parameters is not good also, haha lot of nitrate and nitrite. Too much aquasoil probably. but the fish and shrimp are doing well bar a few weak ones which died along the way. I'm using a canister filter for my planted tank. I think it's relatively larger capacity for bio media helps keep my Nitrate / Nitrite level down. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic November 17, 2025 Share November 17, 2025 On 11/16/2025 at 7:58 PM, Lala81 said: Automatic fish feeders are common now. I bought one. But I forgot my CA can just feed the fish haha since it's at work Got WiFi one. This one I bought is considered low tech liao. Since it's internal timer. WiFi timer You need to add a WiFi cam to watch the feeding taking place. Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 (edited) On 11/17/2025 at 9:33 AM, Didu said: I'm using a canister filter for my planted tank. I think it's relatively larger capacity for bio media helps keep my Nitrate / Nitrite level down. i stuffed about 150-180gm of biomedia beads in a nylon mesh bag into my HOB. Lol there's so many that my filter flow is slow, and when i dismantle for cleaning, i usually need to readjust the bag at least 2-3 times to get the flow back working Cos I only have one tank, if don't use up the 200gm i bought, just lying around doing nothing. Edited November 17, 2025 by Lala81 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 On 11/17/2025 at 9:38 AM, Volvobrick said: You need to add a WiFi cam to watch the feeding taking place. not into fish porn. 1 Link to post Share on other sites More sharing options...
Didu Turbocharged November 17, 2025 Share November 17, 2025 On 11/17/2025 at 9:16 AM, Lala81 said: mine is planted tank. don't really care too much about changing water. but algae bloom can be a problem. my water parameters is not good also, haha lot of nitrate and nitrite. Too much aquasoil probably. but the fish and shrimp are doing well bar a few weak ones which died along the way. I started with aquarium soil too. (These things are not cheap ) My NH3, NO3 level initially went thru the roof. No wonder those tank cycling videos advocate heavy water changes during initial phase with such substrates. I've since changed to gravel. 1 Link to post Share on other sites More sharing options...
Didu Turbocharged November 17, 2025 Share November 17, 2025 On 11/17/2025 at 10:06 AM, Lala81 said: i stuffed about 150-180gm of biomedia beads in a nylon mesh bag into my HOB. Lol there's so many that my filter flow is slow, and when i dismantle for cleaning, i usually need to readjust the bag at least 2-3 times to get the flow back working Cos I only have one tank, if don't use up the 200gm i bought, just lying around doing nothing. You can put in a 2nd HOB for : Fully deploy the 200g of bio media Improve flow Have a backup in case one of the HOB fails Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 On 11/17/2025 at 1:09 PM, Didu said: I started with aquarium soil too. (These things are not cheap ) My NH3, NO3 level initially went thru the roof. No wonder those tank cycling videos advocate heavy water changes during initial phase with such substrates. I've since changed to gravel. I bought like maybe 15kg and used about 70-80% of it. also 5kg of compost soil and about 5kg of black sand. Sand is bad idea, but it does provide a stable base for my decorative house in the center of the tank. my friend has quite a few tanks with 100% aquasoil. But usually need UV light in HOB according to him. My HOB doesnt allow u to stick things inside, so i got another UV pump. Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 On 11/17/2025 at 1:12 PM, Didu said: You can put in a 2nd HOB for : Fully deploy the 200g of bio media Improve flow Have a backup in case one of the HOB fails no space liao. cos i have a UVP. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 Do share any photos or videos of your own setups. Link to post Share on other sites More sharing options...
denser 3rd Gear November 17, 2025 Share November 17, 2025 On 11/16/2025 at 9:27 PM, Didu said: Yes, this can be challenging. I always ask people to consider when they plan to setup a fish tank. Similar to other pets, tank inhabitant is also a commitment. "Do you need to be away sometime during the year when no one is around to maintain the tank, or feed the inhabitants? They'll probably survive 2 or 3 days without food. More then that, they'll start to stress." no food for few days not the scary, the most scary part is electricity trip or maintenance without power... 1 Link to post Share on other sites More sharing options...
Didu Turbocharged November 17, 2025 Share November 17, 2025 On 11/17/2025 at 1:45 PM, denser said: no food for few days not the scary, the most scary part is electricity trip or maintenance without power... This can be mitigated with a UPS connected to air pump to keep the water moving. Link to post Share on other sites More sharing options...
Didu Turbocharged November 17, 2025 Share November 17, 2025 On 11/17/2025 at 1:24 PM, Lala81 said: Do share any photos or videos of your own setups. Photo dated Jan 2025 7 Link to post Share on other sites More sharing options...
Didu Turbocharged November 17, 2025 Share November 17, 2025 On 11/17/2025 at 1:20 PM, Lala81 said: no space liao. cos i have a UVP. Do you use the UV pump to control algae? or for other reasons? Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 17, 2025 Author Share November 17, 2025 On 11/17/2025 at 2:09 PM, Didu said: Do you use the UV pump to control algae? or for other reasons? Yeah for algae control. I run it occasionally only though. Flow too strong for this small tank. Link to post Share on other sites More sharing options...
Didu Turbocharged November 18, 2025 Share November 18, 2025 On 11/17/2025 at 2:42 PM, Lala81 said: Yeah for algae control. I run it occasionally only though. Flow too strong for this small tank. Btw, what's your tank size? ↡ Advertisement Link to post Share on other sites More sharing options...
SingapoREdiscovers tourism vouchers extended till end of the year!
High mercury fish to avoid
Can recommend aquarium vendor?
What Are You Doing With Your Down Time During This Virus Crisis
What is the most extravagent hobby you have? (excluding Car)
Boats to give away FOC
